Question about Canon Cameras
The zoom lens won't close. It says to restart computer, but won't do anything when I try to turn it on. It's a canon power shot SX100 IS
  • Canon Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 28, 2008
Dropped my canon power shot a1000is...now lcd says lens error, restart camera (lens won't extend now)...Is this an easy fix or expensive?
Hello
Thank you for using FixYa for your problem
Zoom les is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 20, 2009 | Canon PowerShot SX100 IS Digital Camera
My Canon Power Shot SX100 IS says lens error. restart camera. Help
Aug 24, 2009 | Canon PowerShot SX100 IS Digital Camera
Lens error, restart camera
Ny power shot camera SX100IS says lenserror, restart camera. How do I fix this problem
Aug 16, 2009 | Canon PowerShot SX100 IS Digital Camera
I keep gettin lens error restart camera on my canon powershot sx100 and the lens wont retract. I have turned it on and off several times now. Is there anything i can do to get it working again?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 21, 2009 | Canon PowerShot SX100 IS Digital Camera
Have a Canon Power Shot SX100 IS...Lens error, restart camera... I have changed the batteries, etc., however, the lens will not "colaspe"... PLEASE HELP!!! Thank you...
If the lens does not extend/retract when the camera is powered on, then lens assembly is damaged.
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solutio is to replace the whole lens assembly.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
Best regards,
Jun 27, 2009 | Canon IXUS V2 Digital Camera
Lens Error!
Same problem. The lens is stuck in the zoom position. When the camera is turned on, the lens moves a just afraction like it want to fully open or close, then the camera beeps and prompts with the "Lens Error" Restart Camera. Solutions?
Dec 05, 2008 | Canon PowerShot A550 Digital Camera
Canon PowerShot SX100 IS Lens Stuck
Unfortunately, such Canon SX100 (and the SX110 too) has a very fragile lens assembly, and it's damaged very easily. Most of the times the internal gears, the plastic post guides and the motor are damaged at the same time, so the only solution is to replace the whole lens assembly.
Best regards,
Oct 14, 2008 | Canon PowerShot SX100 IS Digital Camera
Lens Error
Unfortunately this Canon SX100 (and the SX110 too) has a very fragile lens assembly. Once you have this lens error problem, there are only four solutions: 1) If it's under warranty, contact Canon to make it valid; 2) If not, then have a repair center to replace the lens assembly (either the internal lens motor or the gears are damaged) or, 3) Sell it for parts or 4) send it to the trash can.
Jun 28, 2008 | Canon PowerShot SX100 IS Digital Camera
Cameras Logo
48 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
