Question about Panasonic NNT995SF Stainless steel 1250 Watts Microwave Oven
Was using Microwave to reheat for several minutes. Job well done. Put in a Pampered Chef stone square dish to continue heating . Oven started making electric sounds, didn't see sparking, terrible electric smell. Turned off. Put in a small glass of water, same results. Unplugged and put outside to air. The light and display panel looked OK and on. But onlly made the "electric" sound. Now afraid to use.
    Sergeant:
  • 224 Answers
Probably a bad inverter, by now you have probably replaced. which is what you needed to do. Too expensive to repair.
Posted on Aug 24, 2017
Illeagle
  • 525 Answers
SOURCE: Panasonic NN-T994SF 1250 watt countertop microwave stopping
From my research, this sounds like a fairly new model. Consult your user's manual to see if this is a user, or common issue. If nothing is descibed then I would seek possible warranty service, or dealer replacement
Posted on Jun 03, 2008
ginko
  • 19396 Answers
SOURCE: when microwave wss turned on, there was no heat but smoke
Test the high voltage capacitor, the rectifier diode.or the magnetron. If all this are fine, test the control board.
If it additionally does not spin and no light, then check also the door switch and fuse.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Posted on Apr 27, 2009
  • 150 Answers
SOURCE: sparking behind the wave guide in model NN-T664
The antenna on the magnetron is wearing out becuase it is damaged. Replacing the antenna from another magnetron normally solves his problem.
Posted on May 13, 2009
caroldon
  • 17130 Answers
SOURCE: Panasonic NN-T785SF microwave smoking and popping
Not to worry ,Please use a good torch light or lamp to look inside the microwave cabin. On the side where the magnetron is fixed look for any food particles which could have stuck while heating. Use a good cleaning solvent to do this job. You must remove all the roller and plates and clean dry. Once you have done this open the top cabinet with the mains wires disconnected. Look inside the side panels for dirt, insect which have got entangled and cooked. use a good brush and blower to clean dry. If the main capacitor has leaked replace with a similar type. Get help if you are not able to do this as it is a dangeorus section with high voltage. You will get to the smelling part once you had inspected these areas. Replace the part in question, can be even the surge protector at the mains end. Hope this helps. Good day
Posted on Jul 19, 2010
  • 11800 Answers
SOURCE: Gday I have a Panasonic
The timer is defective. Unfortunately the timer is part of the control chip and the chip is soldered on the board and can't be replaced on its own.
You need a new control board and you can find one only at a dealer.
Posted on Nov 27, 2010
How do you use the kitchen timer and cook at the same time?
If you have the kitchen timer set for instance for 10 minutes and it is counting down, and then you want to reheat you coffee for 2 minutes. You would hit either time cook or reheat button and enter 2 minutes ten hit start. The microwave will heat your coffee and show the 2 minute countdown for that. When done it will revert back to what is left on the 10 minute kitchen timer without missing a beat on most microwaves.
Feb 26, 2015 | Microwave Ovens
How do I reheat frozen lasagna
Microwave ovens are not meant to cook food, except in a very few situations. If the lasagne has already been cooked before it was frozen, then you'll need to weigh and to reheat it in accordance with the manufacturer's instructions in order to ensure the dish is heated through, though it's better to use a food thermometer.
The temperature you should aim for throughout the dish is 83C. Only at that temperature can you be sure that any bacteria in the dish will have been severely depleted.
Feb 21, 2015 | Microwave Ovens
Panasonic NN-H965WF Microwave oven
We recommend the microwave is evaluated by an authorized service center by using www.panasonic.com/repair Welcome to Panasonic Online Repair
Apr 13, 2014 | Panasonic Microwave Ovens
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
Arcing
What is the wattage of the microwave oven? This device is rated for 800 watts or less. Tupperware Contact Us About Us
Dec 13, 2017 | Frigidaire Over-the-Range Microwave
My Magic Chef over the range microwave won't even pop popcorn without shutting down. Was told to put dish on sensor but it still shuts down. Any answers?
Magic Chef customer support recommends placing a glass of water inside the oven to absorb some of the energy. It works for us..Jan 1, 2010
Mar 31, 2009 | GE JVM1653 Microwave Oven
Microwave is on when you shut the door
I tried all the things on your website. Holding the clear button , unplugging,...
So I went back to the last operation that I was doing when the problem started.
I was using "reheat" so I put a glass of water in the micro turned on reheat 1 serving.
It started and then I hit clear after a few minutes and the problem went away.
Dec 15, 2008 | GE Advantium 120 Convection/Microwave Oven
When starting to reheat a loud crack, explosion, sound occurred,
As long as the door latches correctly there should be no danger. Some items will cause loud "explosions" in a microwave, such as whole potatoes when the skin has not been pierced. If the food contains pickling spices for example, the seeds will explode with a very loud sound like a gun.
As long as the oven continues to heat, there may be no other problem. But I suggest you stay near the unit when using it. Watch for smoke and be alert for strange odors. You don't mention the age of your oven but if it is new you can call GE customer care at 800 432 2737.
Ray
Nov 25, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave/convection oven problem
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 25, 2008 | Microwave Ovens
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
Panasonic NNT995SF Stainless steel 1250 Watts Microwave Oven Logo
56 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
