Question about Gateway FPD2275W LCD Monitor
KDS K717s = Radius-73 Model 700P
How does one crack this case open? 4 screws seem easy enough, but it won't pry open without marring or breaking tabs. Gotta be a trick there!
Thank you in advance.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Gateway Master
  • 848 Answers
KDS K717s = Radius-73 Model 700P? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
860 AB0 170DTLAPH PI 170DTLA 200 000 170DTLA AH 860 AB0 170DTLAPH Power...
Posted on Jan 03, 2015
  • 40 Answers
Most are snapped at the corners and center of each side.  A plastic ipod pry tool will usually get the process started, and you just work your way around the frame.  Starting at one corner is best.
srich
Posted on May 27, 2008
Change radio in 99 cavilier
You have to remove the dash. 2 screws on each side, u can see them w doors open and take off side panels to get to them. Then u can open glove box and I believe there is 2 more screws there..carefully pry on dash to see where other screws may b..mostly just pins holding it on after that..the 2 side panels on each side of radio come off very easy..can't remember if they are tabs or 2screws on each..but then it's pretty self explanatory from there..
When I say pry, I really mean Carefully! Easy to break tabs or a old dash
Jan 22, 2014 | 1999 Chevrolet Cavalier
Necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
necesito el diagrama de conexion interno para lcd kds 700p. i need de pinout tech info for lcd monitor kds model 700p myy wire is broken........ i just adapt a new part used,,,?
Dec 12, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
Power supply filter caps will be he first thing to check, look for leaking/bulging tops.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
May 11, 2010 | KDS K717s 17" LCD Monitor
Kds 700p monitor
The most common problem with LCD monitors is the capacitors that are on the power pack. the pack usually looses or pops as we say 2-6 of them after 3-5 years. its almost a certainty after 5 years. a component repair tech can replace these but unless you can find some one like me who will do it for cheap to save the landfill you most likely will buy a new one.
Mar 19, 2010 | KDS K717s 17" LCD Monitor
Any tips on openong the 917s case?
Front and back of most LCDs shap together. Must be gently pryed apart.
Some KDS LCDs that have screws on the edge need to slide the front cover up a half inch to release from the back cover.
Monitor Mike
Feb 17, 2009 | KDS K717s 17" LCD Monitor
Monitor Life
Instructions follow, RESULT "Replace and never buy a KDS USA Monitor again (less than 3 years usage)."
Dec 29, 2008 | KDS K717s 17" LCD Monitor
Can my KDS (#K717S-700P) monitor be wall mounted?
This monitor can be wall mounted but I do not know what bracket you would use.
If you look on the back of the monitor you should see 4 indents in the sticker near the corners. If you don't then rub around near the corners of the sticker. With a sharp knife or pin you should be able to lift out these tiny stickers. You need to measure the distance between these on the horizontal, vertical and diagonal then you should be able to ask somebody at your local TV dealer for help locating the correct bracket.
I'm sorry i can't be more helpful.
Nov 24, 2008 | KDS K717s 17" LCD Monitor
Dell monitor
Tantong's description is correct -- press on side tabs and pry apart the face while working from the middle of the sides to the top. Once the sides are separated, remove the top, and remove the bottom last.
Photo of removed front faceplate
Photo of monitor side (with face plate removed)
Feb 07, 2008 | Dell UltraSharp 1907FP 19" LCD Monitor
HOW TO OPEN cASE
After you remove the stand, there is a metal plate under it which will come out. Underneath that there is one more screw, (the last one). After that, carefully pry the case apart.
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
444 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
