Question about Pantech C120 Cellular Phone
Brand new phone - fully charged but will only stay "on" if it is plugged into the charger...Please help !
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Tell this problem to the store you got from. Show your warranty card also if you have one. They will solve it.
Posted on Oct 22, 2010
HTC Wildfire Battery is not charging fully
i am using an htc wildfire and it is not getting fully charged and when it reaches 30% the battery discharges even when the charger is connected. need help urgent
Jan 05, 2012 | HTC Wildfire Cell Phone
I have had 4 pantech jest phones and it wont charge!!!! i had it plugged in then i thought it was charged fully cause the bars were full when i took it out.....BAM!!!! i shutt of!! im sick of it i had 4...
Make sure you're using the Pantech charger you got with your phone. I had this problem, got a new one, and realized I'd been using my old charger charger. Plugged it in with the wrong charger, it wouldn't work. Plugged it in with the Pantech charger, it started charging up and worked fine again.
Dec 27, 2010 | Cell Phones
Wheelchair battery charger will flash red and not complete charge. new batteries -- just got them last week. The charger behaves well in front of the tech. I've looked for a brand name on the charger, but...
You didn't mention what brand & model of wheelchair/scooter you have. To properly check to see if the charger is working correctly is testing the total voltage of both batteries together while the charger is plugged in to the controller joystick. First check the total voltage of both the batteries together before you plug the charger in. The total voltage of both fully charged batteries together should be around 24.5 to 26.5 volts. Plug the charger into the charging port on the powerchair/scooter. Now with the charger on, the voltage should read at the very least 1+ volts more than the total voltage measured earlier. If less the charger is bad and will need to be replaced.
Hope this helps, if so please rate this solution which will help others who may have the same answer and thank you for using FixYa.
Flavadave75
Jan 21, 2010 | Health & Beauty
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
Player won't turn on
It sounds like you may have a faulty battery. I would return the mp3 player for a new one.
Jun 18, 2008 | Coby MP-C7085 MP3 Player
MOTOROLA H500
I CHARGED MY BRAND NEW MOTO H500 HEADSET FOR 3 HRS CAME BACK AND BLUE LIGHT WAS OFF. THAT MEANS FULLY CHARGED. WHEN DISCONNECTED FROM CHARGER. I TRIED TO TURN IT ON AND NO LIGHT OCCURED. FLASHING.. STEADY... PULSING... OR ANYTHING
Jun 15, 2008 | Motorola Mobility H500 Wireless Headset
Charge/in use light
Typically the charge light will stay on as long as the phone is on the charger. After 16hrs, the battery should be fully charged. Leaving it on the charger constantly can actually overcharge the battery, shorening it's life. The best thing to do is use it until it tells you the battery is getting low, then charge it uninterrupted for about 8-12 hrs. Of course, that's ideal and can't always be done, but the more you can do that, the better.
Hope that helps, and please rate my answer, good OR bad.
Feb 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Lg chocolate
hold the end key to turn on.. if nothing happens plug it in.. i had to charge mine for abour 2 1/2 hours before it would work
Dec 25, 2007 | LG KG800 Cellular Phone
Battery won't charge.
hello,
normally many cell phones requires 6-10hrs for its batter to fully charge up. also i have seen it where battery can be brand new but doesn't have enough juice to hold the charge.
now as far as red light on charger, remember even if you have 99% charged batter and you plug in the charger it will show you red light on phone/cradle.
FYI- all brand new phones are covered with 30 days of warranty replacement with new phone. after 30 days it covers upto 1 year from the date of purchase with refurbished phones.
In your case i think it is just the battery, try having your provider replacing new battery if no luck again then my suggestion will be to replace your phone with new battery with in 30 days.
TY
Dec 22, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Pantech C120 Cellular Phone Logo
26 people viewed this question
Top Pantech Cell Phones Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Abdul Mannan
Abdul Mannan
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
