Question about HP Color LaserJet 3500 Printer
HP 3550color laser jet printer
Deensity sensor out of page..show @ even log....?
could be fuser problem pls suggest
  • 138 Answers
Could be a couple of differnt things and the complete run down would be extensive. Here's a link to the complete service manual in PDF for free. You can look it up and even repair it once you download the manual. Hope this helps: :)
http://www.feedroller.com/Store/Service%20Manual/Color%20LaserJet%203500-3550-3700.pdf
Posted on Aug 03, 2008
HP Laser Jet 3525dn printer shows lines every 1/4 inch on each page after printing?
If the lines are always the same color then likely you have a bad cartridge, that or it might be a failing fuser.
Mar 15, 2015 | HP Office Equipment & Supplies
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
Hp Laser Jet P2055dn printing black line down the middle
The line in the middle of the page is caused by a damaged or worn fusing assembly in the printer. Here is a link to an article showing this issue on the Laserjet 2100 printer and how to replace the fuser unit. Your printer just needs to have the fuser replaced, it is part number RM1-6405 and is available from Amazon
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jul 19, 2012 | Ricoh Aficio CL3500N Laser Printer
Could you please show me the scanner motor for hp laser jet 2420.
Figure 7-14. ECU wiring
1 FM1, main fan motor (J509)
2 Tray 1 pickup solenoid (J508)
3 Tray 1 sensor (J503)
4 Laser/scanner motor (J402)
5 Memory tag reader (J510)
6 Fuser motor (J501)
7 Main motor (J407)
8 Door switch (J408)
9 FM2, sub fan motor (J512)
10 Thermistors, rear-output-bin sensor, delivery sensor (J405)
Jul 03, 2011 | HP LaserJet 2420 Printer
50.2 fuser fault on a HP laser jet 4350dtn
Indicates that fuser is not cycling properly. Usually caused by a failed fuser. If your page count is anywhere near 200,000 pages, your best bet is to purchase a maintenance kit which will come with a new fuser, as well as the feed/separation rollers.
May 27, 2011 | HP LaserJet 4350dtn Printer
How do I clean the rollers on my laser jet printer, it prints with a long black strip in the middle of the page. Hp laser jet 1320
Most likely the heat roller is breaking down in the fuser. The fuser must be replaced. But before going that far, replace the toner cartridge, as it may have a bad cleaning blade. 85% of all print quality defects are cartridge related. This particular model of machine has a very brittle heat roller that more often than not wears out prematurely. This is true across the board for all of the newer HP low end laser printers unfortunately.
Sep 30, 2009 | HP LaserJet 1320 Printer
Install fuser
please reference the service manual from page 89 shows how to remove and reinstall the fuser unit, download from:
http://www.google.ca/search?hl=zh-CN&q=HP+2420+laser+jet+service+manual&btnG=Google+%E6%90%9C%E7%B4%A2&aq=f&oq=
choose second one PDF file and download for a while. then go to page 89.
hope help you to fix it , and please take a rating let me know how much helped you thanks!
May 16, 2009 | HP LaserJet 2420 Printer
Color Laser Jet 3800 leaving roller marks on paper
Pull out the fuser at the rear of the machine.
Feb 07, 2009 | HP Color LaserJet 3500 Printer
Fuser Error 50.1 Fuser is hot. What is a fuser?
error 50 means your fuser assembly has gone bad or its not getting power to be functional. you need to replace the fuser unit.
Aug 17, 2008 | HP Color LaserJet 2600n Printer
Hp Laser jet 4 plus
Bad toner cartridge or fuser is burned out.
Aug 15, 2008 | HP LaserJet 4 plus Printer
HP Color LaserJet 3500 Printer Logo
150 people viewed this question
Seeker5211
Seeker5211
