Question about Whirlpool LER4634J Electric Dryer
My Whirlpool wed5540sq0 stopped responding to pressing the on/start button. It still 'acts' right, as you can feel/hear the clicking difference between being between cycles or ready to start. I was rotating the cycles knob and pressing the on button when it finally started after 20 times or so. Can't get it to know.
jumptrout51
  • 3361 Answers
SOURCE: Won't run. Can hear clicks when changing settings, but won't run when push start button.
Check the door switch for continuity.
Remove the rear panel and check the thermal fuse attached to the exhaust vent on the lower left side. It is 1 and 1/2 inches long by 1/2 inch wide and white in color.
If it is blown you must correct the air flow problem also.
Posted on Apr 29, 2009
SOURCE: Whirlpool Calypso - Will not start
We just experienced the same problem with the buttons! I just kept pushing all the buttons until it switched over-delicate cycle was actually the one that got it going-what a piece of work this machine is!
Posted on Dec 17, 2007
exspert
  • 55 Answers
SOURCE: Dryer stopping in middle of cycle but timer continues to run.
oK " It's your timer, it has to be replaced
it's not going threw all it cycles, will start but will not finish
not a big job, unscrew plate on back at the top you will see
timer , take it out and replace it
( can not stress enough that you have to unplug the electrical cord from the wall socket before working on a dryer or any appliance )
Posted on Jan 24, 2008
SOURCE: LTE6234 Whirlpool Twin Thin Timer Broken?
The problem I have with my Whirlpool ThinTwin is that when I pull the washer knob the water does not start filling even though there is water in the apartment unit. The dryer works so i know there is power and not a circuit breaker issue as I have checked that as well.
When I turn the knob and pull in any position nothing happens. Any suggestion would be greatly appreciated.
Posted on Feb 03, 2008
SOURCE: My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Posted on Dec 27, 2008
How do I fix a whirlpool washing machine with the 'door locked' light blinking?
The door lock needs to be replaced. I would recommend using a technician to replace the part just to be on he safe side.
Sep 28, 2015 | Whirlpool Washing Machines
Start button wont work
did you feel the clicking sound when button is press ? if no clicking sound , then it's the switch broken/wire loosen, if you cann't feel the clicking, then the plastic behind the button broken
Apr 21, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I start a Whirlpool duet HT washer?
plug it in, press power button (blue button on left) turn dial to desired cycle then press and hold the blue button on the right until u hear a click then relese. if it doesnt light up the display when u press power the washer is broken.
Mar 11, 2013 | Washing Machines
My whirlpool dryer will not run, it was fine one load then notta on the next.
Have you checked for a broken drive belt or non functioning motor? Not likely, but the drive belt may have slipped off the drum.
Feb 10, 2013 | Whirlpool Dryers
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Maytag Dryer - funny buzz sound and then nothing
my dryer makes a buzzy sound bt it wnt start just make a buzzy sound
Jul 10, 2009 | Whirlpool LER4634J Electric Dryer
Dishwasher won't start
jamcdani Most likely the problem with your dish washer is bad key pad. It is not repairable and has to be replaced. Whirlpool does not sell it separate and you have to by the whole console assembly. The price range is between $95 and $115 (different colors) and it is not very complicated to replace it. I can help you with the complete step by step instructions and, if you provide the complete model number of your dish washer, I get the part number and the best price for you. Gendos post back...
Jun 29, 2007 | Whirlpool 24 in. DU915PWP Built-in...
Trouble starting Cycles
Jonsey, sounds like you have a keypad issue here. Do this test: press the following keys in this order soak-cycle signal-soak-cycle signal. If done right the display should show dt. Now press start, all the led's will light up. Now test them by pressing each one, you should hear a beep for each one. If some of them are not responding, check the P-11 and P-12 harness on the control board. You can also put this machine in the automatic test mode by pressing the keypads in this order; soak-soil level-soak-soil level. The display will start counting down from 99 to 0 testing different aspects of the machine. Any errors will be shown in the display. Catriver..post back.
Nov 13, 2006 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool LER4634J Electric Dryer Logo
390 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
