Frigidaire FAC126P1 wall/window Air Conditioner Logo
Posted on May 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Frigidaire Air Conditioner - FAC102P1A Compact II th
When I unpacked the air conditioner from the box, there was some packaging taped to the sides. There is also packaging INSIDE of the unit and cannot figure out how to get it out. It's really hot and humid and I need to install and use the air conditioner. However, I can't' use it until I can get the packaging material out from inside the unit.
Please help!!!!
  • 2 more comments
  • Anonymous Jun 09, 2008
    I too have had the same problem with removing the packaging from my air conditioner. The manual states to remove all packaging from inside the unit, so we took the air conditioner apart and removed some of the heavy foam material and some just lifted right off and yet there are other parts we are having to cut away to get it out of the air conditioner. My question is, does this all come off and is it in there to support it during shipment, and, I actually have half of it off, should I continue or will it work the way it is????
    Confused!!!
  • Anonymous Jun 30, 2008
    The instructions were not clear on what constitutes packaging inside the aid conditioning unit. Is it better just to leave all the packaging in the unit instead of taking it all out? Will it harm the unit leaving all that packaging in there in the long run?
  • Anonymous Jul 24, 2008
    Do we or do we not remove any packaging from inside the unit? If so what specifically do we remove?
  • flawedplan May 08, 2009
    Dealing with this very issue right now, and am amazed no one mentioned it at the Amazon review page. Consumers need to know about this nonsense. I sent a hot note to Frigidaire, never have I come upon such idiotic ambiguity. I'll post their response, provided I get one.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 15, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
697
Points
6
I spoke with the Frigaire support line 706 374-4432. They said that the large piece of styrofoam, that extends from side to side and nearly top to bottom, is part of the unit. It should not be removed.
Anonymous
Level 3:
  • Master 828 Answers
  • Posted on May 27, 2008
Anonymous
Master
Level 3:
Answers
828
Questions
0
Helped
454875
Points
1944
Packing you may observe to be inside the unit may be there to prevent vibration during operation. Generally speaking manufacturers do not put packing in unaccessible places for home owners to remove.
Why must I use the cercut breaker button to turn off
Good Morning Friend,
I understand you have to turn off your Frigidaire air conditioner, model# FAC126P1A, at the circuit breaker. You should not have to use the circuit breaker. You should be able to turn it off at the control panel. I suggest contacting the manufacturer directly, for further assistance. They should be able to point you in the right direction of having your appliance functioning correctly. Hope this is helpful.
-Best Regards-
WP
How many btu is this air conditioner model #FAA067P7A
Good Afternoon Friend, this is Z. That's a great question!
I show that your Frigidaire air conditioner FAA067P7A has a cooling capacity of 6,000 BTU's. I hope this information helps to some degree. If you need further assistance, please feel free to reconnect.
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
1helpful
My window is only 18-19" wide. I need to know the
You can find the information you're looking for, as well as the Owner's Manual and Installation Guide at the following link.
http://www.frigidaire.com/products/air-conditioners-dehumidifiers/window-air-conditioners/fra052xt7
Hope this helped you.
FAA067P7A AIR CONDITIONER RUNS BUT DOES NOT COOL? I DO NOT UNDERSTAND THE CONTROLS IT HAS THINGS LIKE TIMER, AUTO TEMP, ETC.
Auto is for fan meaning fan will only run when compressor starts and the tempature you want the space.
Air Conditioner not blowing cold air . I cleaned the filter. What is wrong?
cleck the coils if they are dirty the system wont cool is the compressor running when the coil is dirty it increases the head pressusre or lower the suction pressure does it freeze up
Carrier package unit. 48SS series. Condenser fan continuously runs even when T-stat is off.
The one side of the contacotr in the condenser electrical box is welded closed...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Window Air Conditioner Sweats
You need to seal the portion of the air conditioner that is inside the window from the portion that is outside the window, Sweating is caused by moist outside air leaking in and contacting the cold portion of the air conditioner. Do not use duct tape, buy aluminum tape which is what professionals use to seal air leaks on ducts. Home Depot sells the tape. Buy the smallest quantity you can find that will do the job ( it can be expensive ) unless you plan to go into air conditioning duct installation.
For best results use some form of insulation over the accordian like side baffles ( cut to fit) . Styrafoam from packaging or silver backed insulboard (Home Depot). Now tape the sides of the insulation to all sides of the window frame, bottom of the window, the sill, and the air conditioner.
Unless you enjoy doing this every year - plan on this being a permanent installation. It is a tedious job because the aluminum tape is not very forgiving and has a peel off backing but it sticks forever.
Top Frigidaire Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
