Question about Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model
Drive belt came of my craftsmans ztr. How to put the belt back on. Did not break but hard to see where you are working
  • 3 Answers
Drop the blade cover
Posted on Oct 03, 2010
Testimonial: "No"
  • tishc9212 Oct 03, 2010
    Write a testimonial (150 Characters max)
    No what does that mean do I drop the whole mower deck
How to stop craftsman rear tiller from breaking drive belts.
belts too tight,1. pully out of round or warped,2. bad pully bearing,3. incorrect install,4.wrong belt ,5. lol.
Apr 27, 2014 | managemylife.com
Craftsman GT3000 - After placing in gear, wheels don't turn
I think there is a safety or shear pin in the drive wheels and it probably needs replacing.They are inside the shaft and are put there so if you hit a stone or something the pin will break instead of breaking an expensive part.
Jan 27, 2018 | Craftsman Garden
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
How to put on drive belt onmy mower
Based on experience with MTD and AYP products: 1) remove mower to deck belt, 2) remove deck, 3) have helper press brake pedal down which puts slack in drive belt, 4) pull drive belt first from front engine pulley or rear transmission pulley then remove entirely. Reinstall in reverse order.
CAVEATS 1) If a pulley is grooved then the narrow part of the belt goes into it, if the pulley is flat then most likely the back of the belt goes against it in a tensioning function. 2) There are often guides or keepers which hold the belt in place, these can be hard to see and if the belt is not routed inside them it may well not work or hop out under load.
Jun 30, 2010 | Craftsman Garden
Replacing a the belt on a portable air compressor - craftsman
hi mate if the pump is connected then it doesnt have a belt its direct drive and if the motor is seperate from the pump unit then it belt driven i dont understand as the picture is a direct drive (no belt)
Aug 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
My cub cadet ztr 50 keeps breaking drive belts the 1st after 130 hours and now after 4 hours
there can be a rough edge on the drive pulleys that cause the belt to get cut
Aug 06, 2009 | Garden
Need a diagram for a sears craftsman 42 inch deck drive belt and
I don't have a deck diagram but you should be able to figure it out it you put the back part of the belt (flat) up against the pulleys that are wide and the narrow part (v) into the smaller pulleys. It might take a couple of times but it is not that hard to figure out. Also put the (flat) side of the belt on any tension idlers. Hope this works.
Jul 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Belt drive replacement
First you have to remove the top cover over the belt. If it's still on, work it off the pully. Then you have to remove the blade, blade adapter and cover underneath. Put the new belt on the pulley underneath and push it out the slot to the pulley on top and put everthing back together. Hope that helps.
Apr 29, 2009 | Craftsman Garden
Headlight Kit for my Craftsman ZTR Lawnmower
Without your model number, I can not access information to see if they made a light kit for this mower. I have seen very few ZTR with light kits.
However I have seen a couple of mowers with lights on them. They got creative; they put some fog lights from an automotive store. They hooked up to the battery on the mower with a switch in line. It may be the way you have to be creative yourself. Hope it helps; Keep cutting
Good Day.
Apr 16, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 21 HP 42 in. Zero Turn Tractor Mower - CA Model Logo
100 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
