Question about Kodak EASYSHARE M1063 Digital Camera
Continues ask me to formatt memory card, when I say ok, it says it is formatting, but keeps coming back and saying it needs formatted
    Guru:
  • 377 Answers
Go through this web site address and see how you can format your memory card
http://www.digicamhelp.com/accessories/memory-cards/erasing-and-formatting-a-memory-card/
Posted on Oct 03, 2010
Keeps saying card needs formatted - ok continue to format - hr glass come up and then in a few seconds I get same messase -card needs formatted
There are several possible causes for "memory card locked", "memory card error", formatting problems, or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed in this linked article.
Sep 18, 2011 | Kodak Cameras
Tip
Sony Memory Stick Formatter Software If your Sony Memory Stick has stopped...
If your Sony Memory Stick has stopped working in your digital device,
Sony's Memory Stick Formatter Software may be able to format your Memory Stick in a more compatible way for your device.
Compatible operating systems include:
* Windows® 7 Starter / Home Basic / Home Premium / Professional / Enterprise / Ultimate
* Windows Vista® Home Basic / Home Premium / Business / Ultimate
* Windows® XP Home Edition / Professional
* Windows® 2000 Professional
Preparation
* Confirm that the write-protection switch of the Memory Stick is set to the "Write enable" position.
* Insert the Memory Stick into the Memory Stick slot of the device or computer.
* If you are using a file recorded on Memory Stick with another application, quit the application before beginning the formatting process.
The Format Process
Note: Formatting will erase all files in the Memory Stick. Always double-check the Memory Stick contents before formatting to prevent loss of important data.
* To start Memory Stick Formatter, click Start->Programs->Memory Stick Utility->Memory Stick Formatter.
* At the "Drive List" screen, click to highlight the drive letter that represents the Memory Stick device/slot.
* Click the Start Format button.
* At the "Warning..." screen, confirm that you wish to format the Memory Stick, and click OK. Note: To quit the process, click the Cancel button.
* Do not remove the Memory Stick from the Memory Stick slot during formatting, as this may cause corruption.
* At the "Format was successful" message, click OK.
* To quit the Memory Stick formatter utility, click the Exit button.
Download the Sony Memory Stick Formatter Here.
I hope that helps.
____________________________________
Click here for Sony's Memory Card File Rescue software.
on Apr 18, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 2GB Memory Stick PRO Duo Memory Card
Can't get to set up menu with my new memory card in camera to set it up to use the memory card instead of the internal memory. Camera keeps saying memory card needs formatted-continue or cancel-I go to...
1. with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory.
2. insert the card and do the "format" thing again from the menu as you just did for the internal memory.
Sep 24, 2010 | Kodak EasyShare C743 Digital Camera
Can't write onto my card through adapter, only works through the phone. "write protected" keeps coming up. No lock on adapter.
this the great solution... try low level format..
1. plug ur usb flash
2. run Formatter v2.9.0.9.exe
3. follow the instruction and wait for the format (might take 5min for 4GB)
4. after complete, may the small volume (about 2MB...here the solution
5. plug your usb flash on other computer and format like regular (make sure u untick quick format) and click on "restore device defaults" then click format
6. now your usb flash drive was like a new one
>>>>DOWNLOAD FORMATTER CLICK HERE <<<<
Jul 14, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Tip
Preparation
The Format Process
I hope that helps.
on Apr 18, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
My memory card for my phone says it has an unrecognized format
have you tried formatting it in your phone and in the computer
Jan 14, 2010 | SanDisk 4GB microSDHC Memory Card
I purchased a PNY 4GB SDHC memory card to use with my Kodak EasyShare Z612. The camera indicates formatting required. How do I format or are they compatible?
You simply insert the memory into the camera, switch it on, go to the menu and then scroll through to Format and then accept. This will then take a few minutes and format the memory for use in the camera. Make sure that the batteries are fully charged before doing this.
Nov 12, 2009 | Kodak EasyShare Z612 Digital Camera
I wan noe if i formated my n70 memory card ..the system inside the memory card will deleted? after format do that memory still can function ? thx
look if you deleted the stuff it's not ok...but if you went to the option which says formatt memory card here it's completly safe...
Jul 31, 2009 | Nokia N70 Smartphone
Memory card format
Try take the card out, then put it back in fully. I've seen this problem before on an Official Nintendo GameCube 251 Block. If there are saves on it, and it still asks you to format the card, just take the card out, and put it back in. You could also try a different slot... Chances are, you just have to take the card out and put it in again for some odd reason. I've seen this fixing that issue. I don't think any of the hardware, i.e. the GameCube or the Memory Card are damaged in any way. Hope this helps.
May 28, 2007 | Nintendo GameCube Console
Kodak EASYSHARE M1063 Digital Camera Logo
256 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
