Question about Vacuums
My Roomba Discovery 4210 seems to be dead. Specifically, with or without a battery, and whether on the charging station or plugged directly into the charging unit, I see no lights on the display whatsoever. This unit has a history of killing batteries, but now seems like it is completely dead. I understand that the batteries themselves contain fuses; is there some way to bypass the battery (for now) to verify whether the unit itself is completely dead? I should also note that this is the second unit to exhibit this exact behavior, and both units were used in an environment with a high amount of dust and cat dander. Any thoughts from anyone?
  • 3 more comments
  • namxat Oct 03, 2010
    I have tried connecting the Roomba directly to the charger (i.e., plugging the adaptor in directly below the serial port cover) without a battery in the unit, but still do not see any lights on the display panel (the charger lights up, though). I will, however, attempt what you say overnight (a 24 hour charge, actually). So the Roomba has an internal battery in addition to the yellow battery unit then?
  • namxat Oct 06, 2010
    Okay, so I have two Roomba Discovery 4210 units, same symptoms on both. Per your instructions I removed the batteries from both and plugged both directly into the charger and the AC outlet and let both sit for 24 hours. After 24 hours the power button on both units was pulsing red. I then placed batteries in both units and let them charge directly from the charger for another 24 hours; both power buttons are still pulsing red. If I remove both units from the chargers the power buttons go dead; pressing them does nothing. Is this indicative of batteries that are completely dead, or is there something else going on?
  • namxat Oct 07, 2010
    It was good to have someone experienced to guide me.
  • namxat Nov 02, 2010
    Okay, I haven't had time to follow up on this, but I am still having difficulty. I purchased a new battery, swapped it in, and plugged the charger directly into the Roomba for 24 hours. After 24 hours I had green lights across the board, except for the power light (it was still pulsing red). I unplugged the charger and all lights went out. Hitting the power button (with the charger unplugged) did not power the unit back on. I don't doubt that the battery needed replacement, but it seems that there's a bit more going on here. Any thoughts or suggestions?
    Genius:
  • 1,478 Answers
I will advice you remove the batteries from your Roomba Discovery 4210, after removing the batteries, plug the Roomba Discovery 4210 directly with the charger to an AC outlet, see if charges, if it does, it means the batteries are dead and will need to be replaced.
Take care.
Posted on Oct 03, 2010
  • Jimoh Adeleke Muyideen Oct 03, 2010
    Let me know the outcome after charging it.
  • Jimoh Adeleke Muyideen Oct 06, 2010
    The battery of your device is completely dead, you will need to get a new battery for your device.
I noticed my run time was getting shorter and shorter, within the first 6 months. I checked my charger and base with a V.O.M. okay. About 4.4 volts on the base about 14 volts on the direct line. I bought...
To extend Roomba's battery life and keep Roomba cleaning at peak performance: • Always keep Roomba plugged in when not in use. • Recharge Roomba as soon as possible. Waiting several days to recharge Roomba can damage the battery. • For storage off the charger, remove the battery from Roomba and store in a cool, dry place. • Blue or black batteries should be stored after Roomba has been used. • Yellow batteries should be stored after being fully charged.
16-Hour Refresh Charge If Roomba has been left off the charger for an extended period, Roomba will initiate a special 16-hour charge cycle. This extensive charge refreshes Roomba's battery and extends the battery life. While charging, Roomba's "Clean" button will pulse quickly. Note: For best results, do not interrupt this Refresh Charge.
Happy Holidays The FixYa Team
Dec 18, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba Discovery series wont charge
You should check the dock if there is an output voltage at the charging terminals.
Jan 02, 2018 | iRobot Roomba Discovery SE Bagless Robotic...
Roomba Battery (existing and brand new one) Not holding a charge.
The Charging circuit on the main board is dead. Either replace the main board or repair it if you have the skills and equipment.
Jan 06, 2010 | iRobot Roomba Discovery SE Bagless Robotic...
My Roomba will not charge, the light on the charger is on and when you plug in the roomba the light goes out and nothing happens. Can anyone help. It is a Discovery Model 4210
Are you using the home base or are you plugging the charger directly into the Roomba? If you are using the base, give plugging directly into the unit a try.
You might also try resetting the battery. With the battery out of the unit, press and hold the power button for 30 seconds or so. After this is done, plug the charger directly into the unit, and let it charge for 3 days (no kidding, 3 days). After that, if you still have issues, it might be time for a new battery, or time to send the little guy in for repair.
Sep 30, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
When I push the clean button. (roomba discovery) it just makes a 'quack' sound and doesn't move.
the battery on your roomba is dead, try charging it for 16 hours, after that if it still does not work. you need to replace the battery.
Jul 12, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
4210 and 4230 won't charge-new batteries.
I've been having the same problem myself. The charger is apparently built into the roomba main board. From what I've read there are two MOSFETs U2 & U4 that can go out and require replacement to fix the problem. More info here
http://www.robotreviews.com/chat/viewtopic.php?f=1&t=3909
Roomba 4210 replaced aps battery still does not work
Try cleaning the silver contacts on the battery as well as the charging station with a small amount of rubbing alcohol such as an alcohol pad.
Also check to make sure the dirt reserve is completely empty. Also check that the briushes are clear and can move freely.
This 'not charging' is a very common problem with the Roomba and the manufacturers continue to sell rechargable batteries that are no good even though they are aware of the problem.
Mar 29, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
280 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
