Question about Hotpoint First Edition FEW12 Front Load Washer
Broken door on few 12 - Hotpoint First Edition FEW12 Front Load Washer
  • Hotpoint Master
  • 3,463 Answers
To replace any part that has broken on the door, you will have to seperate the 2 halves of the door, undo all screws and prize the 2 halves of the door apart.
Posted on Oct 03, 2010
What is wrong when electric mirrors and drivers side door lock doesn't work.
Since both issues are in the same door, you may have some broken wires,. Check the wires where they are exposed in the door opening. There is a rubber boot that protects the wires, but your vehicle is 12 years old.
Feb 15, 2016 | 2004 Dodge Dakota
Door falls open, no restraints
Yes, I've fixed a few, and was unable to fix a few. You may need to remove the whole cover of the dishwasher to get to the insides. You should find either the springs are broken on both sides of the bottom of the door, or even more likely, the plastic parts between the springs and the body or the door have broken. The parts can be ordered from "Sears Parts" on the inter-net. You will need to provide the model number to look them up.
Be blessed.
May 21, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Why 97 mitsubishi glant tail light fuse broken
The 10A DEDICATED fuse 12 in the engine compartment relay box feeds power to numerous circuits: the ABS-ECU, the LF power window switch, the radio, the key reminder switch, the door lights, the cruise control, the ECM, the transaxle control module, the trunk room light, the motorized antenna, the combination meter, the clock, the sunroof switch and dome light, and the garage door opener. A short in any of these can blow that fuse
Oct 07, 2012 | 1997 Mitsubishi Galant
TAPE DOOR WILL NOT CLOSE
mechanism is faulty.flex cable (FP-031-12) is broken. replace complete mechanism or flex cable (FP-031-12) by any service person.
Apr 12, 2010 | Sony Handycam DCR-HC28 Mini DV Digital...
My garage door will only open about 12 inches and then stops. I have stanley electric door with a craftsman 1/2 electric starter
Check the door springs. Sounds like one could be broken. You might also remove the cover to the opener and check the drive gear. It could be stripped.
Nov 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Model 139.53930DM I adjusted the chain and now door only goes up 12" (too tight?)
The chain might be to tight but I think you should check for broken door springs or a bad drive gear. The gear is white nylon and is just in front of the motor. The chain should sag just a bit.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door does not open all the way stops @12 inches
You most likely have a broken door spring. Release the door from the opener and try lifting it by hand. Look above the door for the springs.
Mar 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
The garage door will not open past 12" and one of the photo sensers is constantly yellow it will not adjust
THE YELLOW SENSOR IS OK
YOU PROBABLY HAVE A BROKEN SPRING ON YOUR DOOR.LOOK FOR A GAP IN THE SPRING.
I DON'T RECOMEND DOING YOUR OWN SPRING.(YOU NEED ALL YOUR FINGERS)
IF IT IS BROKEN CALL IN A PRO.
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Nikon Coolpix 2100/3100/3200 battery compartment door latch broken (again)
I just purchased a new battery door for $15 with shipping from nikon. They sent a simple assembly diagram and I was able to replace the door in 30 minutes. I used a dremel to cut the old door off, but you dont have to do that. I got a little impatient.
Just buy the plastic piece and u can reuse the metal parts for your old battery door.
Oct 15, 2007 | Nikon Coolpix 3200 Digital Camera
Hotpoint First Edition FEW12 Front Load Washer Logo
51 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
