Question about Hitachi 57F59 57" HDTV
When watching baseball or football the field is brown not green. I have Dish Network.
  • aasingle Oct 04, 2010
    Would dirty mirrors have an effect on the color?
    I have used the remote and I tried to adjust the tint--it did not seem to do any good. This is a rear projection TV so I wonder if the mirrors are dirty. I don't feel safe taking the back off.
  • Hitachi Master
  • 11,800 Answers
This is a CRT projection tv - one in which the colors are generated individually by some small tubes. If the refracting lenses would have been dirty you would have seen a general loss of image, not what's happening here.
In your case the tube that emits the green color has aged and doesn't emits so well. So when it's supposed to emit on its own (like when you see a field or any other green object) it can no longer do it 0 and the remaining colors (that also emit a little) there take precedence and change the color.
Since this is caused by old age it can't be fixed - the tube must be replaced. As a precautionary measure you should replace all 3 tubes, the other 2 can't be in a much better shape.
This is a shop job only - the adjustments for the new tubes must be done with special equipment - and it will cost you about $500.
Posted on Oct 04, 2010
    President:
  • 1,961 Answers
Try to adjust first the tint or hue adjustment from the remote control acces it by opening the color adjustment.
there are 3 colors lamp from the TV the red green and blue you can open the back cover of your tv and check whether this lamps are working or lit.Check this first and post a message to proceed with trouble shooting
  • Danilo Baraquiel
    Danilo Baraquiel Oct 05, 2010
    yes dirty mirror has effect on color and picture quality.dirty mirror and dusty lamp will produce a blured picture you need to wipe off the dust accomulation atleast twice a year.It is not dangerous to open the back cover as long as you unplug the unit for the outlet.Just remove the four screws at the upper cover not the bottom cover after removing the cover you can easily reach the lamps and the mirror use a soft clean cloth to wipe off the dust.do not youse excessive force this might break the glass.after cleaning do not return the cover plug inn the tv and power on and check if the green lamp is working if not then you need to check the pcboard of the green lamp or the itself is busted.or the signal from the SIGNAL from the CPU is
  • Danilo Baraquiel
    is not recieve by the green lamps probably a brocken connection.this will require a skilled personel to do it.Thank you sir and you can try first the cleaning....
  • 10,865 Answers
Hello. Turn on the set, get a picture that has brown grass and then go into the menu, select the color function and make gentle changes in the color until it is more to your liking. J.
Posted on Oct 03, 2010
RCA D52W136D 52 inch has no green.
most likely its the Green CRt drive board you should be able to get a new CRT Drive board for about 30.00 at the following link. www.tvrepairworld.com
Aug 14, 2009 | Televison & Video
No green
green crt weak? poss demod circuit prob.
Dec 10, 2008 | Hitachi 57F500 57" Rear Projection...
Color problem
i no this might be no help but have you tried to calibrate the brightness contrast gamma and colour settings to get the right colour also may like to check your scart it could be a faulty scart just double check your wiring but if none of that works i am sorry hope you get it fixed soon only trying to help
Dec 03, 2008 | Hitachi 51F59 51" HDTV Projection...
Hello sjustinh,
It sounds like your color processor may have gone bad or at least the circuitry connected to it. To solve this problem you will need a schematic, a digital storage oscilloscope, a signal generator, and a multimeter. Now if you don't know what these devices are and do not have a background in electronics, I would suggest that you take the TV set to a qualified TV repair person. I am not trying to put you down or anything its just that this problem requires that you open up the set and using the schematic trace down the signals that control the LCD screen and find out the condition of the signals that display green. Since green is the result of the algebraic addition of red and blue, you may have a problem in the circuitry that controls that function.
I hope this helps,
Thank you,
Shuttle83
Sep 18, 2008 | RCA D52W136D 52 in. TV/DVD Combo
Green looks brown
Maby its not tuned in the channel right
maby its the way the picture is
or try
turning the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
Color problems
if you have hd cable or satellite box make sure the component cables are properly connected(green red and blue) and matching same color in source (cable box or satellite and tv as well)
also make sure in tv menu that color and tint are 50%
Jul 03, 2008 | Sony KP-57WS500 57" Rear Projection...
Hitachi 57F59 57" HDTV Logo
77 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
