Question about D-Link AirPlus DI-524 Wireless Router
Connecting two networks
I have Dlink DL 524 wireless router and i enabled DHCP withthe IP range of 192.168.1.X for the WI FI users
Other LAN users are using the Series 172.16.30.X
can i know the solution how i can enable access between the WIFI users and LAN users
Regards,
Vinu
    Sergeant:
  • 336 Answers
Yes. For your router go to the computer that has the router attached. Open up Internet Explorer and in the address bar type in the IP 192.168.0.1 That will open up your router configuration. Just be warned that you should NOT play with any of the numbers that are there unless you know what they are.
Hope This Helps
All The Best,
RCF
Posted on May 28, 2008
Talk talk, technical assistance
How did you connect the computer to the router. If you are using a DSL modem it will have a DHCP server in it that is allocating IP addresses across your network. If you added the router to the computer via a hub or network switch what is the computers ip .
address. Remove the WI FI router - turn off P.C and then Go to cmd or dos prompt if windows based system and type in ipconfig and press enter to see if ip addresses are 10.0.0.2 if they are your dlink router uses 192.168.0.1 so you need to make the dlink router ip addressand subnet setting to match the Modem ip addresses of the DHCP server. Change the ip address of the dlink router to be 10.0.0.2 and change the modem to allocate DHCP IP addresses from 10.0.0.10 to 10.0.0.255. Only do this if IP addresses are 10,0,0,1 to 10.0.0.,254 on the desktop p.c with the dsl or cable modem connected.without the router being involved. (you may need to ask the ISP what the user name and password is of the modem and it should be ip address xx.xx.xx.1 so type this into a browser to change the modem settings. 10.0.0.1 or 192.168.0.1 just remember if the modem is 192.168.0.1 so is the Wi router from d-link and you will have an ip clash problem)
. How do you do this by ethernet connection from only the desktop directly with only the Wi FI . router. Go to a internet browser and type in the URL 192.168.0.1 and then change the router ip address to match what the DSL modem DHCP issues..
Page 14 of Router instructions see http://files.dlink.com.au/Products/DIR-615/Manuals/DIR-615_C2_Manual_v3.10.pdf
in the manual it states to use a direct ethernet connection for the setup program but you need to be connected to the internet for it to work but if the IP addresses are wrong or clashing will have no internet. You also want to set the modem as the DCHP server and disable the DHCP server in the set up of the wi fi tand set the WI FI router default gateway as the ip address of the Modem. if any DHCP server options in the WI FI router sert to the modem ip address. .
Sep 08, 2014 | D-Link D Link Dir 615 Wireless Router...
I can't connect to the internet with dlink router
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jun 06, 2010 | D-Link DIR-625 (790069292637) Wireless...
How configurate this router? I lost the CD with configuration. Please ask me. Mabey in Polish language?:)
http://192.168.0.1
or
http://192.168.1.1
When you connect vpn router to wireless router set in wi fi lan property as your vpn network range set vpn router ip as gateway ip of wireless router.Then save settings and restart it.
May 20, 2010 | NetGear WGR614 Wireless Router
I have a laptop dell with vista windows, i want to make it wireless , using my wireless router ,how do it using the model of birght house step bystep. thank you.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then in vista make sure wireless lan driver installed then right clickc on wi fi icon and click on view available wi fi then you can connect it.
May 05, 2010 | D-Link AirPlus DI-614+ Wireless Router
Configure the modem without cd installer
http://192.168.0.1
or
http://192.168.1.1
Apr 22, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Hard drive crashed lost my dlink disc how would i put my dlink router on my new computer
http://192.168.0.1
or
http://192.168.1.1
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Jan 13, 2010 | D-Link High-Speed 802.11g Wireless PCI...
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
Can not connect to internet
My first guess is that your Dlink ADSL modem is really a modem router, so you are getting double routing. Sometimes this works just fine, though, so I'm not confident that's the whole explanation.
You'll need to setup your IP plan carefully
set the D-Link modem(router?) to bridging mode & the DLink wireless router does the login to Exetel.
DLink wireless router WAN side: DHCP + login to Exetel
DLink wireless router LAN side: 192.168.0.1
Subnet 255.255.255.0
DHCP on: range 192.168.0.10 to .20
DNS Servers: 220.233.0.3, 220.233.0.4
with PC's wireless adaptor set to DHCP
so picks up eg:
IP address: 192.168.0.10
Gateway address: 192.168.0.1
Aug 03, 2009 | Computers & Internet
Using just the VOIP part of a Belkin all in one router??
You will probably need to set it up differently, I do not know the belking router, but normally the VOIP functions only work on the wan port of these routers so you should make the connections as follows:
INET ---> (wan) DLINK (lan) -----> (wan) BELKIN (voip) --> Phone
|--------> Wired Computers
|--- ) ) ) Wi Fi computers
On the DLINK enable DHCP and set a fixed IP for the Belkin router, either by setting the belkin in an IP outside the DHCP pool or setting it from the DHCP server.
This configuration workd well with a DLINK and a Motorola (vonage) router I have.
Apr 23, 2008 | Computers & Internet
Router cannot get IP with cisco 675 modem
The issue may be due to the existence of two (2) DHCP servers; 1 in the Cisco 675 and the 2nd in the DLink DI-524. You need to disable the Cisco's DHCP server function and assign static IP add & config to the DLink WAN config. This way it will only be the DLink handing out IP adds to the network.
The workaround. Install your original configuration/setting without the DLink DI-524 - PC direct to the Cisco 675 (I am assuming through Ethernet ports). Verify that indeed you are connected to the Internet and can surf the net, check e-mails, etc. Check your Networking Connection Status. Log down your PC's IP Add, Subnet Mask, Default Gateway, DNS. For purposes of discussion, let's call this "N1".
After your Internet connection has been verified with your PC directly connected to the Cisco, remove the direct connection and connect the DLink DI-524 in between the Cisco router and your PC.
Log in to the DLink and modify WAN parameters using the "N1" configurations/settings.
It might be of help to disable any security (WEP WPA, MAC etc) at least while configuring.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 01, 2008 | Cisco 675 Router
D-Link AirPlus DI-524 Wireless Router Logo
44 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
