Question about Velodyne VRP-1000 Subwoofer
Hi, My son needs help with a VRP-10 velodyne subwoofer. It doesn't work. We did a basic check of the transfformer and there was no power coming out. Unless we're missing something, we suspect the transformer is bad. Are we correct with our diagnosis or are there other defective parts that may cause to transformer to stop working? Thanks
xMadx
  • 64 Answers
SOURCE: Major buzz/Humming sound coming from my subwoofer
Well there are only a few reasons i can think of that just might be the reason behind said buzzing.
1. It may be connected to another power source ( amplified or powered supply ) or incorrectly connected. It may also be too close to said power supply.Try letting the dog (sub) out on his leash a little Drag out the manual that came with the sub, and check the correct procedure for your type of setup.
**People do read manuals still don't they ?**
2.The only other problem i have heard of is port noise in low registers. Keep the the port area clean, as it may suck up dirt, or even worse, small children!
3. However, if you're considering placing this subwoofer in a cabinet, I'd recommend allowing ample breathing room for the heat sink. This can also be done by drilling smaller holes in the cabinet ( 8-12 mm holes - with the owners permission of course) but please do remember to keep the port area clean.
4. The product ie: Velodyne DPS-12 Subwoofer, came with a bad power supply, presuming it is new, check your warranty.
(not very likely - see also scenarios 1, 2 or 3.)
Velodyne has been making subs forever and do it well.
Posted on Jan 17, 2008
  • 151 Answers
SOURCE: how to connect pioneer reviever to velodyne subwoofer
Look for the sub pre out on the back of your amp and connect a sub cable to this and next to the LFE or phono type input on the back of the sub ,if it has two inputs left and right pick the left side ,set the cross over to suit your system and speakers,if you are not sure set the cross over to 80 hertz,this is a thx standard.
hope this helps.
CABLE GUY.
Posted on Jul 03, 2008
  • 15 Answers
SOURCE: need amplifier for velodyne vrp
You might try the BASH amps at www.partsexpress.com.
Posted on Dec 02, 2008
  • 124 Answers
SOURCE: My Velodyne CT 80 powered subwoofer does not power on?
Fuse in amp may be blown or the amp is dead
Contact Velodyne, the replacment amp is not very expensive
Posted on Jan 04, 2009
  • 124 Answers
SOURCE: No sound for Velodyne ct-100 sub woofer
Sounds like a dead amp. You could check the xformer output and the amp IC's with a VOM.
These amps do not cost a lot, about $40.00. and are easy to replace.
Contact Velodyne
Posted on Mar 26, 2009
My CHT-10 SHUTDOWN AFTER 1 HOUR OF OPERATING
need to have the amp rebuilt, possibly the power supply best to have them both serviced
Jan 21, 2010 | Velodyne CHT-10 Subwoofer
When i turn the balance to the left the speaker works but the sub doesnt. velodyne fsr12
Not sure what you are posting about.
Need to have more info on your question.
How do you have the sub connected to your system?
Dec 24, 2009 | Velodyne VRP-1200 Subwoofer
I hear noises when DD-10 is turned on.. even without signal to i
If it is a low level white noise, you may have some form of RF noise that is being picked up by the driver mounted servo system.
Then it could be something else as well.
Best to contact Velodyne to see about service for your unit.
Oct 03, 2009 | Velodyne DD-10 Subwoofer
SPL8R Velodyne sub - Same probelm
Go to the Velodyne web site and check the service center locations.
They may have one in your area.
It sounds like the amp may be the problem. That may be all you need to send.
Best bet, Contact Velodyne.
Jun 08, 2009 | Velodyne HGS-10 Subwoofer
Right side audio valume not working
Do you mean that the right speaker which is routed through the subwoofer's Speaker Level In and Out is not working? Did it all start when you added the subwoofer?
Perform some isolation and connect that speaker directly to your receiver to see if it works.
YES? Recheck the speaker connections. After all, the sub is only connecting your receiver to the speakers after borrowing LFE information. Observe matching + and - polarity throughout.
NO? Either the speaker or the Receiver channel have a problem, but that isn't likely if the problem appeared just from putting the subwoofer into the mix. You can swap speakers to eliminate them and swap source amplifier channels to isolate them.
May 16, 2009 | Velodyne VRP-1200 Subwoofer
Woofer,s outer ring is ripped.
To fix this problem, you will need to contact Velodyne.
They may be able to replace the surround or recone this driver.
Because this system has the "servo" control, you need to have the accelerometer conected to the amplifier. With out it, the amplifier will not operate.
Jan 03, 2009 | Velodyne VRP-1200 Subwoofer
Crackling coming from Velodyne DD-10 subwoofer
Velodyne is known for good service, i think in this case it is best to contact your vendor and have it solved.
I think internally there somethign wrong with the electronics, most likely the amplifier.
Aug 08, 2008 | Velodyne DD-10 Subwoofer
Velodyne VRP-1000 Subwoofer Logo
109 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Matthew Spark
Matthew Spark
Jerry Greenberg
Jerry Greenberg
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
