Question about Siemens WFXD5200UC Front Load Washer
When doing laundry, it keeps coming up E01 or E02, basically its not draining....What can I do? Anne annedechiro@msn.com
    President:
  • 2,468 Answers
There is a lower access panel below the front door,it is usually held on by 2 to 3 screws at the bottom of this panel,remove these and then lift up and outward to remove this,then the pump is just inside this panel below the wash tub,remove the hose clamps from the drain pump and remove any debris clogging the pump and hoses from the tub and on to the drain hose,this will solve both the error codes and drain issue,these machines wont run if plugged to keep from ruining the pump and associated components
Posted on Oct 03, 2010
  • 1 more comment
  • annedechiro Oct 03, 2010
    Thank you so much! That was disgusting! BUT, it worked! THanks
    preemptive celebration... now saying E04
  • Rachael Wood
    Rachael Wood Jan 28, 2014
    hello Anne, I know it's a long time ago now, but just wondering if you did get the washing machine fixed, as I have the same E02 problem now :( Many thanks, Rachael
My F09 and my E01 codes keep coming on in mid cycle and shutting down the cycle
F09/E01 are related codes.
LONG DRAIN: If the drain time exceeds 8 minutes without reaching reset level in pressure sensor, the valves are turned off and the drain pump will stop running. NOTE: Suds can cause delays in draining. Washer drains for 4 minutes, pauses 5 minutes, then tries again for 4 additional minutes of draining. F9E1 will display if washer does not drain. (Normal drain takes less than 2 minutes)
Possible Causes:
Verify that the drain hose is not blocked or kinked.
Make sure drain hose is not sealed into drain pipe.
Make sure the drain hose height does not exceed 96" (2.4 m).
Check/clean drain pump filter of foreign objects.
Check connections from tub to air trap, air trap to pressure hose, and pressure hose to pressure sensor.
See TEST #8 (Drain Pump) on page 19. Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?Is pressure hose pinched, kinked, plugged, or leaking air?
Oct 03, 2016 | Whirlpool Washing Machines
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
Codes error e000
Might be e01 e02 check paper jam.
Feb 03, 2014 | Toshiba e-Studio 161 Copier Copier
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
EO3 COMES UP ON MY CDPLAYER CAUSE I HIT A BUMP IN THE RODE
Hi there:
Here are the listing as to what the error codes refer to:
- E01 - Focus Error - Disc is not loaded correctly, or condensation on disc
- E02 - Disc Error - Disc is dirty, scratched, or deformed; or excessive vehicle vibration
- E03 - Mechanism error - Loading or eject error. Pickup-up is out of position.
The E03 error typically occurs when the CD player mechanism is damaged. Try different types of CDs; a new music CD would be the best to try. If that also gives the same E03 error, your CD player probably needs to be replaced.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | Cars & Trucks
Casio tk 1300 error showing E03 - can't fix it with advice from manual
For those about a manual with error code solutions, C-tech has the one that covers these codes: E01, E02, E03, E04, E06, E07, E08, E09, E10, E11, E12, E13, E14, E17, E18, E19, E25, E26. It has remedies for each of the codes. You can find it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_operation_manual.html
Jun 30, 2008 | Office Equipment & Supplies
Drain pump runs constantly:Error code E02
Suggestions: First see that the exit hose behind your machine is inserted at a particular height, ie about 3 feet above ground level, then into the standpipe in your wall. If things dont work plug off the wall, open up behind, you will see a thin pipe coming down from the pressure switch to the drain area. Disconnect this pipe carefully from the top and blow into it, it should be free. If blocked clear, if broken or damaged change. Refit carefully.
Pl rate me helped.......
Dec 28, 2007 | Bosch WFMC 3200 Front Load Washer
Breadman TR555LC
Yes, that just happened to me. The book says E01 means the Breadman is too hot - remove Bread Pan with ingredients, and wait until the Breadman cools down - about 20 min - before preparing a new loaf.
E02 means the Breadman is too cold. Unplug machine and allow it to heat up to room temp. and try again.
For E03,4,5,8 - unplug the Breadman and contact customer service.
Nov 30, 2007 | Breadman TR555 Deluxe Rapid Cool Touch...
Siemens WFXD5200UC Front Load Washer Logo
1,811 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
