Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a front tire that is flat. How Do I remove it?
  • 3 Answers
Pop the plastic nub of and there is nut under it
Posted on Oct 03, 2010
How do I take a front tire off a craftsman lawn tractor
some have a plastic hub cap that you pry off then either a cotter pin or a c clip that needs to be removed .
Aug 26, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What's wrong with the front end of my truck?
caliper malfunction brake fluid leak onto the pads causing it to slip and smoking from the brake fluid burning
Jul 06, 2014 | 2005 Chevrolet Silverado 1500 2WD
Flat front tire
you probably have alloy wheels. take rubber headed hammer and hit one side of the wheel, be careful because the wheel could hit you when it comes off.
Sep 24, 2013 | Chevrolet Impala Cars & Trucks
How do I get the front tire off Poulan riding mower to fix a flat
DO IJUST PULL THE CAP OFF OR DO I HAVE TO MOVE THE CAP TO A SURTAN SPOT, I DONT WANT TO BREAK IT THIIS IS ABOUT TAKING THE FRONT TIRE OFF.
Apr 28, 2012 | Poulan Garden
I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire. How do I raise it up and take the tire off/and put another one on?
Bird If you have help you can tilt the chair to the side of the good tire and place a block under the frame behind the flat tire set it down on the block to lift the flat tire off the ground enough for you to remove the bolt holding the tire on the axle remove the tire assembly and the rim is a split one remove the 4 nuts holing it together and remove the tire and tube to patch the tube then reverse the procedure to get it back together. Put grease or vaseline on the axle before you put the rim back on and then tighten the nut you should be rolling again Hope this helps
May 04, 2011 | NRS Hoveround MPV 5 - Used Power...
Right front tire has gone flat 3 times in the last
You can remove the tire from the vehicle, make sure it is properly inflated, and spray with a soap and water solution. Carefully look around the bead, check the tread for bubbles, could be a puncture, and don't forget to look at the valve stem. Any bubbles indicates a leak. Good luck.
Steve
Jan 02, 2010 | 2007 Pontiac Solstice Convertible
Removing front wheel (flat tire)
The lug nuts are the only thing holding the wheel on, aside from a little rust in some cases. Stand in front of the tire facing away from it, try giving it a swift kick on the edge. Of course, you must exercise caution when doing this. Be sure the vehicle is properly supported and won't fall the jack stand.
Nov 30, 2009 | 1994 Ford Escort
Flat front tire need to remove from craftsman 13.5hp ohv riding mower
Remove the plastic dust cover, remove the E clip holding it on the spindle, remove the spacer/thrust washer, slide wheel and tire of
Sep 09, 2009 | Craftsman Garden
Change front tire
Before you start make sure you have the following:
- jack or any other instrument to lift the car
- tool to open the tire bolts
- spare tire
- if you ar eon the side of the road a warning triangle or any other object to make sure the oncoming traffic can see you.
step 1 - Open the tire bolts, remove all of them but two. The bolts left on the tire should be left quite loose (you should be able to open then with your hands).
step 2 - Position jack underneath car & lift car. VERY IMPORTANT to make sure the jack if proparly positioned & that the car is stable (for a car that has one wheel in the air...), so it won't fall on you. Don't stop lifting once the flat tire is in the air, remmber you have to fit in a new tire. Lift it so the new tire can fit in.
step 3 - Remove the last to bolts with your hands, while loosening secure the tire with one hand so it won't fall on you.
step 4 - Remove flat tire, while doing make sure not to damage the bolt which the tire sits on.
step 5 - Fit new tire in, screw 2 bolts by hand to secure it place.
step 6 - Screw rest of bolt by hand so secure tire in place. Make sure to "push" the tire as firm as possible to the car.
step 7 - Lower car. Do this slowly incase the tire isn't sitting properly.
step 8 - Tighten all the bolts properly, don't over tighten them, cause the next time you have to change the tire, you won't be able to open them.
step 9 - After driving a bit with the car, retighten the bolts, just to make sure nothing is loose.
This only sounds a bit complicated it's much simpler in practice then on paper.
Good luck & congretulations,
Eitan.
May 28, 2008 | 1999 Chevrolet C/K 2500
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
56 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
