Question about HP OfficeJet 7410 All-In-One InkJet Printer
HP Officejet 7410 AIO keeps saying out of paper when plenty of paper loaded
Have had machine several years - often annoyed us with pulling paper from upper tray even though we set lower tray everywhere we could. Now will not feed paper - gives us error message that paper tray is empty when both trays are fully loaded.
  • fixya-cd Jul 31, 2008
    Have almost exactly the same problem. (Although I only use the bottom tray.) Mine may print the first sheet of paper, but will say its out of paper when it tries to print any additional sheets, even though it is fully loaded. Have had this printer since early '06.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Once remove both the trays and insert them again and if the problem persists, power cycle and semi-full reset the all-in-one.
Posted on May 28, 2008
I have the same unit. There are many issues with it. First when you install the software you may need to add something to the registry.
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Print\Printers\HP Officejet 7400 series\PrinterDriverData and create Key HPDJEnableSecondTray as DWORD with Value of 1
Once you've done this here is the biggest issue and one I've found to fix this issue PERIOD.
You need to go to your Printer Driver then to Properties of it then Device Settings Tab - you will see Form to Tray Assignment in the list and like 5 options, you have to make all but the one you want to NOT AVAILABLE. Example mine is set to Upper than Lower (Letter) all the rest are set to NOT AVAILABLE. Problem solved.
Posted on Apr 15, 2009
How do I set up the 7410 for wireless printing?
Please click on the below link which provides the installation instruction for setting up 7410 AIO printer on a wireless network.
SETUP Instructions
Regards,
Riztech
Mar 21, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My hp 7410 pulls multiple sheets at one time I
remove paper and try to blow thru the papers so they a loosen from each sheets...then put it back...do a test print.....
Oct 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
7410 HP MFC Shows no power.
If you mean that the power light isn't on, but the screen is stuck in boot-up mode, try this partial soltion; it's worked for nearly everone who's tried it. It's in reference to the officejet 7410 all-in-on, but I think it's worked for other machines. Unfortunantly, you lose your wireless capabilities, but at leat you're not left with a $500 paper weight:
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
(It's interesting that the majority of posts with this issue have occured on numerous sites during the last two months).
Apr 02, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Adf pulls 2- or more pages in feeder.
open the ADF and clean the rollers and wooden cork pad and unplug the machine and press and hold the ON button for 1 min and release the button and plug it bak and it should resolve ur issue........
Regards raj_p5983
Jan 21, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Clear Paper Jam, then Press OK
Have you checked the access door in the rear of the machine?
Jan 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
7410 keeps saying it's jammed but it's not??? Please help!!!
try seeing at the censor feeder of your printer, may be it has small piece of paper which unnoticeable. see to it its turn off before you pull everything.
Dec 17, 2008 | HP OfficeJet 7410 All-In-One InkJet...
My HP Officejet 7410 All-in-One keeps giving me the error message - Scanner failure - Turn power off then on. Turning power off then on, even disconnecting power cord, repeatedly does not solve problem.
Our HP Officejet L7780 displays the "Align Printer" message and then does it automatically wasting several sheets of paper aligning, then the next time we print a page the same message comes back. Is there a way to turn off the "align Printer" message. It is printing ok otherwise.
Jul 31, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
7410 officejet
Sounds like the printer isn't passing the self diagnostics. Check for paper jams, pull the paper out and put it back in, check the ink cartridges.. unplug the equipment for about 30 minutes.
Mar 20, 2008 | HP OfficeJet 7410 All-In-One InkJet...
HP7410 Print Problem
http://h10061.www1.hp.com/ccsearch/search?cc=us&lc=en&dlc=en&sni=391194&opname=HP+Officejet+7410+All-in-One&pname=HP+Officejet+7410+All-in-One
copy and paste the above link into your address bar and search for the answers.
Nov 09, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
751 people viewed this question
Seeker5211
Seeker5211
