Question about Frigidaire ATF6000ES Front Load Washer
Have a code ebf or e6f coming up? - Frigidaire ATF6000ES Front Load Washer
  • 17,970 Answers
EBE and EBF are console control problems. This error could be solve replacing the control board, rewiring, or replacing a part on the washer. It is always best to consult or hire a professional when you want to repair an appliance.
Hope this helps; just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Jose.
Posted on Oct 19, 2011
I have an error code "EF" for my Electrolux
Generally, EF error is showed with an additional number on your display... EF 1, EF 2, EF 3, EF 5, EF8, or EBF.
Each error code will depict a different cause and solution. Out of these solutions, the most common is the control board and possibly the UIB (User Interface Board), or too higher mains voltage coming into the house, causing damage in this UIB device.
Test and check voltage, if this isnt solve it, relace UIB device.
Hope this helps.
Mar 05, 2012 | Electrolux EW1200i Front Load Washer /...
Tip
Activation Code for Crysis 2 video game.
Hi friends,<br />Here are some free serial keys or activation codes for crysis 2 video game.. Enjoy!<br /><br /><br />05AS-W20S-PIRA-RTEB-AY01<br /><br />3NLU-YVYB-ZR2Z-8RU5-EBFE<br /><br />956A-29AH-M4LA-0M0K-1BDE<br /><br />Bye.<br />
on May 15, 2011 | Televison & Video
Once the plug is on the bolt (Fig 3 in instuctions) is there anyway to get it off again??
rcdodge posted the same problem on Aug 15, 2011. I've just posted a solution aginst his question, so try that (it's a bit tricky though).
Oct 25, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
Ltf700es1 erroe ebf ?
EBE and EBF are console control problems. This error could be solve replacing the control board, rewiring, or replacing this part on the washer. It is always best to consult or hire a professional when you want to repair an appliance.
Jose.
Oct 17, 2011 | Frigidaire ATF6000ES Front Load Washer
My son put the cocking bolt together before attaching it to the gun. We can't get it apart! Do you have any ideas or do we have to get replacement parts?
Warning 1: this is a procedure for adults, not children - you may accidentally stab your own fingers.
Warning 2: this procedure might ruin the cocking bolt completely.
You'll need a small phillips head screw driver, two small flat-blade screw drivers, dental floss and four hands.
1) One end of the cocking bolt is fixed - leave this alone.
Remove the two screws from the inside face of the rotating end cap - this allows the outer cap to be removed.
The inner cap (still on the bolt) has four teeth that protrude into a recess around the metal bolt.
Warning 3: be extremely careful during the next step as the teeth may snap off completely and fingers could get hurt.
2) Using one of you four hands, hold the bolt upright on a sturdy table (with the fixed cap down) .
Simultaneously use the two flat-blade screw drivers to carefully lever one pair of opposite teeth out of the recess.
Whilst holding the levered the teeth out, firmly push the inner cap further down the bolt (down toward the fixed
end).
3) Wrap dental floss (or similarly stout, fine cord) around and around the recess to pack it out until it is flush with the outer diameter of the metal bolt - this is to stop the teeth locking back in place.
4) Slide the inner cap up and off.
Reassemble the cap.
Remove the dental floss.
Remind your son about the importance of reading the instructions first (just as you've always done yourself ;-).
Aug 15, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
I put my battery pack in backwords and i cant get it back out
Can you try wedging something in there to use as a lever, like a screw driver or a butter knife?
Mar 14, 2011 | Hasbro Nerf N-Strike Vulcan EBF-25 Blaster
Where is the battery compartment for a nerf havok nstrike fire ebf-25.
There is a gray battery cover a little bit above the trigger. You will see a screw hole
Jan 02, 2010 | Nerf Secret Strike As 1
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
Dec 13, 2009 | Nerf Secret Strike As 1
Code E 70 on a 6000
Here are all the Fault Codes on the 6000/7000 but i dont see a E70 on here are you sure?
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E52 Bad signal from tacho generator. Refer to test (8)
E56 Highmotor current. Refer to test (9)
E57 High current on inverter. Refer to test (9)
E58 High current on motor phase. Refer to test (9)
E59 No tacho signal for 3 seconds. Refer to test (10)
E5A High temperature on heat sink. Test first if bad replace
speed control board.
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E75 Water temperature sensor circuit. Refer to test (12)
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
E97 Console control problem Replace the control board.
E98 Console control problem Replace the control board.
EB1 Incoming power frequency out of limits. Refer to test (15)
EB2 Incoming line voltage above 130 VAC. Check voltage at the outlet.
If below 130 VAC replace the
control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at the outlet.
If above 90 VAC replace the
control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Tomuch soap. Advise customer to reduce
the amount of soap they are
using.
EBE Console control problem Replace the control board.
EBF Console control problem Replace the control board.
EF5 NTC temperature for the hot water valve over the limits. Hot and cold water hoses
switched.
May 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
211 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
