Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
The freezer freezes and collects ice on top shelf, but other shelves are only cool. What is wrong?
  • 98 Answers
Adjust the thermostat switch to different positions and see.
Posted on Oct 04, 2010
The top two shelves are not freezing and the food on those shelves and that area of the door have defrosted. The bottom seems to be freezing. I can hear the fan running and do not feel any drafts from
Obviously that freezer is not achieved the required temperature. There are several reasons for that:
- Defrosting system is not working, which leads to accumulation too much ice on the evaporator that prevents heat transfer and reduces air circulation despite the fan is running.
- The problem with draining condensate after defrosting cycle which also leads to accumulation of ice.
- Leaking gas from the cooling system (reduced cooling capacity)
- Faulty compressor
Dado
Jan 05, 2015 | Electrolux Freezers
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
Top of freezer not freezing
your cooling matchine get damaged,there having a cooling matchine.
Mar 25, 2013 | Daewoo FRSU20IA Freezer
I have severe ice forming in my freezer.
On this unit the shelves are the cooling coils and carry the refrigerant (freon) through the system. They will attract the warm moist air by design, so if you have an air leak in the door or elsewhere it will tend to build up there first.
This being said you need to check something else first. Make sure the other shelves are cold. If they are frosted and cold like normal then you most likely have a door that is not closing all the way or a bad seal. If the lower shelves are not cold then you have a system problem, typically a refrigerant (freon) leak that is causing the top shelf to absorb most of the work and not enough refrigerant to flow to the bottom shelves.
I hope this helps
May 06, 2010 | Frigidaire 16.7 cu. ft. / 473 liter...
Upright freezer-only top shelf gets frost
it may be that the door is open a lot witch lets in warm air that go's to the top of your freezer and turns into ice so there maybe nothing wrong with your freezer, in winter we heat the house up and close all the windows this holds in the damp air,, in the summer it should be ok, but to test it place a thermometer in the freezer is should be about -21*f or there abouts for a 4 star freezer
Dec 29, 2009 | Freezers
The top shelf in my upright freezer ices up badly; but the rest of the freezer is great - no ice! What causes this and is there something I can put on that shelf to keep the ice from building up.
If this is the type of freezer where the shelves are the evaporator coils, the coolant goes through the shelves(tubing) and the formation of frost is normal and has to be manually defrosted.All the shelves should be as cold asd the top one. The fact that just one has any frost may indicate that it is low on freon. If this is the case you should notice that the freezer doesn't get cold enought.
Sep 02, 2009 | Freezers
Top shelf of frigidare manual defrost freezer only freezing, other shelves are not cooling.
Is the condenser clean? If it is you may have a refrigerant leak or an inefficient compressor.
Jun 28, 2009 | Frigidaire Freezer Refrigeration White...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Upright freezer not cooling
The model number would help but it sounds like a sealed system leak or restriction. If thats the case I would not suggest trying this yourself. The water should freeze overnight and the frost should keep going to all the shelfs that have coils in them.
Apr 16, 2008 | Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
120 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
