Question about Concord Camera Eye-Q 3045 Digital Camera
MY STARTUP DISK IS CRACKED IN TWO AND NEEDS TO BE REPLACED
    Guru:
  • 377 Answers
I have a question mark sign on my screen please help
sounds like your hard drive has come unplugged, you will have to remove the battery and possibly the "L" shaped metal strip then you can push the hard drive back in
Feb 14, 2015 | Apple MacBook Pro Laptop Computer with...
Why is my macbook air a1466 showin a file with a question mark when i turn it on and how do i fix it
http://support.apple.com/kb/ts1440
A flashing question mark appears when you start your Mac Symptoms
If you see a flashing question mark when you start your Mac, it's probably because it can't find the system software it needs to start up. Usually, all you have to do to get your Mac back up and running is remind it where its software is.
Resolution
If your computer starts up normally after a brief delay, you probably just need to reselect the startup disk in Startup Disk preferences. It's normal to see the flashing question mark when a startup disk has not been selected. In most cases, reselecting the startup disk is all that is required to resolve the issue.
Sometimes, your computer may not start beyond the flashing question mark.
Tip: If your computer has a gray screen (with no flashing question mark) startup issue, see Mac OS X: Gray screen appears during startup.
Check the mouse and keyboard
This issue might occur if a mouse or trackpad button is pressed during startup. Make sure the button isn't pressed.
If the issue persists, shut down your Mac with its power button, disconnect any external mouse and keyboard, then turn on your Mac with its power button. If the flashing question mark issue persists, reconnect the keyboard and mouse.
Additional steps
If your Mac still starts to a flashing question mark, follow the steps below. If any step resolves the issue, you don't need to continue to the next one.
  1. Select your Mac OS X startup disk with Startup Manager by restarting and holding the Option key. After your Mac starts up, restart again to verify that the flashing question mark does not appear.
  2. If the issue persists, insert your Mac OS X installation disc. Be sure to either use the disc that came with your Mac, or, if you installed a later Mac OS X version from disc, use the newer disc.
    MacBook Air note: On a MacBook Air, there are two options for starting up from Mac OS X media: Either connect a MacBook Air SuperDrive to the MacBook Air via the USB port and restart the computer, holding down the C key during startup, or use Remote Install Mac OS X to startup from a system software DVD that's located on a partner computer. Once started up from Mac OS X media, skip to step 3.
  3. Restart the computer, then hold the C key during startup.
  4. From the Utilities menu, choose Disk Utility. Don't click Continue.
  5. Select your Mac OS X disk (named "Macintosh HD" by default) in the left side of the Disk Utility window.
  6. Click the First Aid tab.
  7. Click Repair Disk to verify and repair any issues with your Mac OS X startup disk.
  8. After repairing the disk, try to start up normally.
    Important: If Disk Utility finds issues it cannot repair, you may need to back up as much of your data as possible (or use Time Machine to back up to a different disk), then erase the disk and reinstall Mac OS X. You should back up important files and data before erasing a drive. Erasing deletes everything on the hard disk (including things on your desktop). Also, you can install Mac OS X onto an external disk, start from the external disk, and use Migration Assistant to transfer items from your usual internal Mac OS X startup disk to the external disk, then erase the internal disk and reinstall Mac OS X.
  9. If the issue persists, and Disk Utility didn't find any irreparable issues, quit Disk Utility, quit the Installer, select your disk when prompted, and restart.
  10. If the issue continues, reset PRAM. Note: After resetting PRAM, if the computer starts up normally, reselect the startup disk in the Startup Disk preferences.
  11. If none of these steps resolve the issue, start up from the Mac OS X Installation disc and reinstall Mac OS X.
Last
Mar 30, 2014 | Computers & Internet
Hp pavilion g6 wont startup
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Mar 25, 2013 | Computers & Internet
Reformat unmountable flash drive on mac?
Instructions
    • 1
      Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    • 2
      Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
      • 3
        Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
      • 4
        Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
      • 5
        Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
      • 6
        Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    May 27, 2012 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    My computer says there is no disk or please insert disk
    disk, are you referring to a cd/dvd disc or are you reffering to a harddrive disk??? If you are reffering to a harddrive disk, then your hard drive is either damaged/ or inproper loose connection or if it s usb/network disk, make sure it is plugged or configuration is changed in the bios menu. If this is a harddrive disk, and after POST or startup, it is giving you this error message, then before we pressume it being damged, check in your bios menu to see if the bios reconized the hard drive disk, if not, your hard drive is damaged and needs to be replaced.
    Jan 20, 2011 | Computers & Internet
    My wii is not reading the disk
    Try this. Take out the disk and put it another. If the other disk is being read, then you have a scratched or cracked DVD. If it's scratched you can try cleaning it (http://www.ehow.com/how_2302469_clean-scratched-cd.html), but if it's cracked, there's nothing you can do.
    If the other disk doesn't work, you have a problem with the Wii Lens and it needs to be cleaned. Information on cleaning the lens can be obtained from:
    http://www.nintendo.com/consumer/systems/wii/en_na/acc/cleaningKit.jsp
    Hope that helps.
    Jan 02, 2011 | Video Game Consoles & Games
    Hi, i HAVE A 2003 HONDA ACCORD COUPE. MY TOUCH SCREEN WAS SAYING DVD DISK ERROR SO I UNPLUGGED THE BATTERY AND NOW IT IS SAYING CHECK DISK. PLEASE HELP HOW DO I GET MY TOUCH SCREEN BACK UP.
    Dvd disk error and check disk error both are same error.The name is different.In both cases the lens in the dvd unit needs to be checked.The lens is either moved from its position or getting blocked by any dust or any dirty stuff got stuck up on the thin lens glass internally.
    In some cases the lens is cracked so the lens assembly needs replacement.But first try cleaning the lens with a dry tissue.You can also try blowing air from air blower first.Blow air in the unit where the disk is inserted/placed.Then check.If still same then the unit needs to be removed out to disassemble to clean the lens manually and also this will help to know if lens is cracked or faulty.
    Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
    Jun 11, 2010 | Car Audio & Video
    My laptop gave me no problems except for occasionally going into hibernating and not being able to wake it so i would have to manually shut it down and turn it back on. but last week i dropped it and...
    The BIOS update could have caused the unit's fan regulation to fault.
    the check disk and actually fixing errors woudl point to the Hard Drive being damaged and needs to be replaced. A full diagnostics is what needs to be done to determine this, i would tell you how but multiple hard disk brands are used on these systems.
    The BIOS update may have also changed the performance settings on the unit, this will cause the system to use the CPU maxxed all the time. This will kill the battery quicker. You can check this setting in yoru BIOS.
    Jun 03, 2010 | Acer Aspire 4720 Notebook
    When i trun on the laptop it will display only blinking floder with question mark on white blackground
    Either the pram battery on the motherboard needs replaced or the hard drive has gone bad. Find a startup disc and boot from it. If it sees the hard drive with the startup disk then its your on board battery. May need someone to install that for you.
    Jul 10, 2009 | Computers & Internet
    Concord Camera Eye-Q 3045 Digital Camera Logo
    62 people viewed this question
    Top Concord Cameras Experts
    isaac johny
    isaac johny
    Ron Dufek
    Ron Dufek
    Robert McCord
    Robert McCord
    Are you a Concord Camera Expert? Answer questions, earn points and help others
