My Onkyo SKW-520 subwoofer has not worked well for the last year or so. I have to keep the gain turned all the way up on the sub and the subwoofer output at +12 db on the Onkyo HT-R520 receiver just to hear a moderate level of bass response. This was not the issue for the first few years I owned the system.
  • rpettit63 Oct 03, 2010
    Are you basically telling me I should replace the subwoofer? It's a < $100 sub, so I'm not sure how much cost / time I want to put into troubleshooting a serious internal issue.
    One of the experts suggested I need to open up the sub and troubleshoot all the electrical components. Does anyone have any other possible solutions here? When I put my finger on the end of the coax cable, I get a lot of feedback / volume out of the sub. It's just not nearly as loud as it used to be when connected to the receiver.
  • 3,083 Answers
If the sub-woofer has any electrolytic caps in it, you should change those first. Electrolytics dry out in a few years' time, and fail or lose their effectiveness.
Same thing with them in the main unit. If replacing the electrolytics doesn't work, the unit will have to be troublshot to locate the bad part.
Good luck, and hope this helps.
Posted on Oct 03, 2010
  • 11,800 Answers
This is caused by the aging of a component from the amplifier - as they age the capacity gets lower = the resistance to the lower frequencies increases = the sound gets weaker.
To fix that you must open the subwoofer and check all the electrolytic capacitors from the signal path - all the way from the input RCA jack to the output of the integrated amplifier.
  • Azrael SRL Oct 03, 2010
    Yes, the background noise has to pass thru the same circuit so it will also sound lower.
    Personally i would have fixed it myself, it's a 2 hour job. If you don't have the knowledge to do it, or you value your free time more, then yes, just get a new one.
How do you connect the skw 360 subwoofer to the onkyo tx-sr505 av receiver
Hi Kenny, sorry you can't. The TX=SR505 requires a powered subwoofer. The SKW-360 is passive. Thank you, Onkyo USA
Dec 02, 2016 | Onkyo Audio Players & Recorders
Onkyo skw 591 subwoofer...blue light is on and no sound? any thoughts?
Hello, To test the subwoofer when the blue light is on if you apply your thumb to the end of the subwoofer cable (the end that you would plug into the receiver) there should be feedback from the sub. If there is no feedback then the sub is not working correctly. Thanks, FJD
Apr 27, 2016 | Onkyo Audio Players & Recorders
Onkyo sub will not power up?
does the green light power up on the back? If not the power supply is bad
Aug 25, 2011 | Onkyo SKW-200 Subwoofer
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
My onkyo skw 200 sub woofer is blowing fuses as soon as i plug it in
The amp output stage or the power supply is shorted. Service shop type repair.
Mar 03, 2010 | Onkyo Audio Players & Recorders
Onkyo skw 150 powered subwoofer output code
whatisthe codewriten behindtheoutput of the onkyo subwoofer skw 150my ou6666088.jpgt put is bad in sucha way that ican not retrieve the the code
Feb 12, 2010 | Onkyo SKW-200 Subwoofer
My onkyo subwoofer does not turn on the green ligth is not on, what could it be? is a swk-200
My Onkyo S/W did the same thing untill I unplugged it from the surge protector that all the other A/V devices are plugged into. I plugged the sub into it's very own wall recepticle with it's very own new surge protector. Maybe cleaner power is the answer.
Subwoofer issues
The fuse blows when the current that passes through it are beyond its rating. This could be brought about by excessive consumption of the load, in this case the amplifier powering the sub-woofer.
Repairs would involve component level and require that you be familiar with electronic components and circuitry, use of a DVM and a soldering iron. Often it is just the finals that needs to be replaced. Of course we cannot discount the possibility of other components or section such as the power supply.
The smoke indicates something heating up such as a resistor or diode or a capacitor.
Should you be uncomfortable opening the unit and doing a DIY (do-it-yourself), then perhaps you need to seek the services of a qualified professional.
Should the downtime and cost of repair be no longer economically reasonable, purchase of a new unit might save you further trouble.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 23, 2008 | Onkyo SKW-200 Subwoofer
486 people viewed this question
 Grubhead
Grubhead
