Question about Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop charging. The old charger (Lead Acid battery charger) used to keep charging until you unplugged it from the socket keeps but the cable is has been loosened by people yanking it out holding the cord so much it has become unusable.
  • 692 Answers
Ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Posted on Oct 03, 2010
VETERANS HOME JUST GAVE ME A USED QUANTUM WHEELCHAIR AND PRIDE MOBILITY CHARGER. HAS AGM BATTERIES. CHARGER MODEL EA11488 SAY LEAD ACID BATTERIES ONLY ????
AGM batteries( absorbant glass mat ) batteries have a different charge rate to ordinary lead acid batteries
it is all abiut the charging rate or charging volts so the charger you have may not be suitable for the AGM batteries in the chair
the difference in the lead acid battery and the AGM battery is the construction
Lead acid batteries will spill acid if tipped over where as a AGM the acid is absorbed in the glass mat or is an acid gel
to get a read of what it is all about go www.batteryuniversity.com and you will see what I am refering to
next best thing is to ring your local battery shop and ask then what charger you should be using for AGM batteries and if a normal lead acid battery is suitable for the job
Jan 24, 2017 | Pride Health & Beauty
Can I charge ev warrior with standard battery charger?
Yes, But. 2 pack so 6volt each, I will assume standard lead acid batteries as the is common, and that is what the pic shows. depends on what you call standard charger, I would not do it with my 40 year old standard charger, although at a push, it will still charge them, but need to keep a check on them, later chargers, monitor the battery voltage, and adjust output to suit. All chargers work the same way, so basically yes, but keep a check on them, not running to hot etc. check voltage if you can. But they all work the same way, just later cells are used to the controlled cct of later chargers. especially with them being so called sealed, they still let gas escape, via a pin hole, If they get hot, to much gas, going out, reduces the effiency of the electrolyte, so will reduce the life, BUT as long as you keep checking them and stop if they get hot no problem, they will get warm anyway.
Jul 29, 2014 | UPG 12V 18AH Electric Bicycle Co EV...
I own a Vector Industrial Series 900 to jumpstart system and power. When we recently moved the cord was lost and now I am in need of buying the new cord. Is this availale?
I advise caution when using a standard battery charger to charge a jumpstarter via the main leads. Firstly if there is polarity protection it probably won't work and secondly the heart of the jumpstarter is a sealed lead acid battery which does not usually tolerate high charge currents without shortening the life of the battery.
This type of battery needs either the low charge current supplied by the original charger or similar or a sophisticated regulated charger.
If using a standard charger avoid using a high performance type and use only the type that provides a trickle charge.
Apr 07, 2014 | JUMP START SYSTEM
Where can I purchase a charger and manuel for a EZ Rider Wild Child Motorcycle
you could try the original supplier or ebay and failing that you could try searching online for a pdf manual and just buy any charger that is the correct type voltage and most importantly polarity, having looked at the bike its a childs harley type bike and is 6v 4ah and likely a sealed lead acid type so i would buy a 6v 500ma lead acid charger, if there is a charge port you will need a plug to match and you will need to check the polarity is correct or if there is easy access to the battery terminals you could just use the crocodile clips to the corresponding terminals on the battery itself there is a selection of chargers here 6V Lead Acid Battery Charger eBay a 500ma charger will charge the bike in 8hrs the higher the ah the faster it will charge but i wouldnt go much higher than 500ma without checking with the vendor that it is suitable for a 4ah battery hope this helps
Feb 22, 2014 | Toys
Blackberry Charger / Sealed Lead Acid Battery
Depends mostly on the voltages and how long you want to wait, but you will have to accept the risk of frying the charger by exceeding the 700mA rating. If the voltage output of the charger is about 10 or 20% higher than the nominal voltage of the battery then it might be OK. If the output of the charger is less than or equal to the battery voltage, then it won't work at all. The smaller the differences in the voltages, the less the risk of overheating the charger, but the longer it will take. If you are in the "sweet spot" it will probably take 6 -8 hours to charge the battery.
Jun 21, 2012 | Toys
I need to find where I can get a battery charger for Model # PL3-01 Motorized scooter
Is it a sealed lead acid scooter battery? Youcan get the replacement battery as per your scooters model number at http://www.monsterscooterparts.com/scooter-trickle-battery-chargers.html.All that you have to do is just search with the model number and you will getthe battery charger. Hope thiswill help you. Good Luck.
Jul 11, 2011 | Pride Luxury Line Maxima Scooter - 4 Wheel...
My Vector model #VEC117FS has a battery that is dead and will not recharge. The replacement battery is VEC 191 according to the owner's manual. Where can I buy this battery or is it best to just buy a new...
There are many companies on the Internet that offer Sealed Lead Acid Batteries, which may be less expensive than replacing the light. I would suggest identifying the particular battery your light has and then check what's available on the Internet to make a decision on whether it is cheaper to replace the battery or the light.
http://www.batterywholesale.com/battery-store/SLA-batteries
http://www.batterymart.com/c-sealed-lead-acid-batteries.html
http://www.atbatt.com/sealed-lead-acid-batteries.asp
http://www.zbattery.com/Batteries/Sealed-Lead-Acid
http://www.planetbattery.com/product.asp?id=10
Nov 10, 2010 | Vector 1 Million Rechargeable Spotlight
Replace AC charger for Campbell Hausfeld CC2300 Cordless Compress
After opening the unit up, this info I found out about the rechargeable battery.
*GS Rechargeable Lead-acid Battery (Portalac) PE12V7A (12v 7Ah) - sealed lead battery*
I hope that info help you, or someone, if you got a 12v 7AMP tip positive DC wall adapter, that thearadacly(sp?) will charge the battery, but I'm doing guess work since I don't know much about the AMP in voltage stuff.
I tried my best.
Jun 28, 2010 | Campbell Hausfeld CC2300 Cordless 230 PSI...
When I plug in the charger is shows green, but the scooter does not run. Should I replace the battery or the charger? E100 razor.
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Mar 28, 2010 | Razor E100 Electric Scooter
When I plug the battery in to be charged the light on the charge stays green. The light never changes to orange/amber. This is not a new battery I have had it for a while.
Your SLA (Seal Lead Acid) battery is must likely past its useful life due to Sulfation and internal mechanical damage (corroded plates): your charger, like for most car lead acid battery charger is indicating that only a very small charging current is flowing just like when a battery if fully charged ... or the terminals are not connected (no current)! You can check if the charger is working by preferrably using a multimeter or connecting a know good battery unit to the charger.
May 17, 2009 | Peg Perego 12 Volt Rechargeable Battery
Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver Logo
430 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
