Question about Rheem Tank Water Heater G76-200, 76 Gallon
My Rhem Ruud G76-200 water heater leaking from below? Can this be repaired?
  • 760 Answers
If it is actually leaking from the bottom of the heater, then it cannot be repaired. Have you looked to see exactly where the water is coming from? Sometimes a leak at the top of the heater, will then leak through the insulation and out the bottom. Another possible source could be from the temperature/pressure relief valve leaking and coming out of the down pipe that goes near the floor or drain. Try to find the source of the leak. It is not practical or safe to repair a tank that is leaking.
Posted on Oct 04, 2010
Anode replacement. where is the anode rod located on a ruud g100-200 gas water heater
either in the anode port on top of water heater, or connected to hot water nipple as a combo ... or both if unit has 2 anodes
http://waterheatertimer.org/Replace-anode-rod.html
Gene
Sep 25, 2014 | Rheem ruud g100-200 water heater,gas,100...
Ruud hot water heater
Best thing is to replace it as it might be rusted inside in the bottom
Dec 07, 2013 | Water Heaters
RUUD PVP75E-1 Gas Water Heater short cycling
1) Copy following link to troubleshoot by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) Otherwise Rheem-Ruud does not post service manuals
http://www.ruud.com/products/tank_water_heaters/gas_water_heaters/
3) Sound like bad gas control valve thermostat.
Newer Honeywell electronic controls can be replaced without draining tank.
Older mechanical controls are replaced by removal from tank after tank is drained.
Feb 01, 2013 | Water Heaters
Changing thermostat on ruud water heater
1) Copy following link to adjust water heater temperature.:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Add a comment if more help is needed. Jan 2013
Jan 26, 2013 | Rheem Ruud Commercial Electric Water...
Replacing a rheem power vent water heater
1) Avoid Rheem.
http://waterheatertimer.org/pdf/Which-is-best-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html
2) Maintain water heater. Pay yourself 10$ a month in future replacement costs.
http://waterheatertimer.org/How-to-maintain-water-heater.html
3) Read product manual for power vent specifications.
Keep in mind that power vent on top of heater can sometimes cover access to anode rod located on top of tank.
Dec 21, 2012 | Water Heaters
Ruud p40-7 water heater
You can get a sudsy water solution and brush it on all over the place especially around joints and look for a leak via tell tale bubbles. If it is the water heater that has the leak there aren't too many places where you can have the leak and it should not be all that hard to check out.
Mar 24, 2017 | Water Heaters
Ruud PVP75E-IP Water Heater
Rheem-Ruud does not post service manuals.
Tank-type?
Copy following link to troubleshoot by type of gas control valve.
Tankless? Don't buy a tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Oct 06, 2012 | Water Heaters
How to drain ruud pacemaker water heater
Turn off water, turn off power, drain tank:
Copy following link for illustrations
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Aug 26, 2012 | Water Heaters
Hi we have a Ruud monel gas water heater, size 72-60 type m tank size 60 .. problem is pilot light is on but heating burner not igniting , NO HOT WATER
Sorry to read about your problem, I hope this helps you out.
you have a defective gas control, thats the big metal unit, with the dial on it, it needs to be replaced, no repairs can be made to it.
THIS IS A GAS PRODUCT, INCORRECT REPAIR CAN CAUSE A EXPLOSION, AND DEATH CAN OCCUR. IF YOU DO HAVE THE PROPER TOOLS SUCH AS MANOMETER AND LEAK DETECTORS, I SUGGEST YOU CONTACT A SERVICE COMPANY
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem Tank Water Heater G76-200, 76 Gallon Logo
453 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
