Question about Saeco Coffee Makers & Espresso Machines
Saecco Taleo Touch Espresso Machine
Hi
I have purchased the Saecco Taleo Touch Machine in April.. I find when I am making the coffee once it has brewed in the ceramic cup it is not warm. Why is this happening? The temperature is set to high... I am using distilled water at room temperature. I have even allowed the machine to warm up for 60 minutes and still the same results. Please help me out.
Thanks
  • vincar Aug 05, 2008
    the water is not hot how do i fix this problem
  • 74 Answers
Make sure you preheat the cups, as that can make the world of diffrence.
if that dont help send it in to a offical Saeco repair station for upgrading of the software, or change of termostat or boiler.
Posted on Jul 11, 2008
Saecco
When the red light comes on as soon as we start the machine and starts the grup and grup stops or moves very slow then the problem is at the board which leads grup.Usually is transistor TIP33C.
May 04, 2014 | Saeco Coffee Makers & Espresso Machines
How do I remove the plastic shield over the grinder on saecco Vienna
a) Remove the water tank and the coffee bean container cover.
b) Remove the two fixing screws of the coffee bean container.
c) Remove the housing screw under the water tank (Torx/T10).
d) Remove the housing screw under the coffee bean container.
e) Remove the two bottom housing screws . Pull the housing left of the electronic system slightly forwards and lift.
f) Move the upper housing slightly to the left so that the notch of the steam dial is visible on the right side of the machine. Release the steam dial using a sharp object and remove.
g) Remove housing and pull water hose off.
May 02, 2014 | Saeco Vienna Espresso Machine
Hi there, I just purchased a Jura S9 One Touch. I've used it for a week, maybe making 10 coffees/day. Just yesterday an ERROR 6 message popped up. I don't know what to do, please help?
Hi, Error 6. Haven't come accross that one before. It sounds like brew unit problem.I do know error 7&8 are brew unit problems and 1 to 5 are water flow and heating errors. Try turning off the machine at the main power button and unplug it from the wall for a few minutes. This will reset the machine and right it self. They can do this from time to time. Dazza
Sep 23, 2011 | Jura Capresso Impressa S9 Coffee...
I have a taleo touch, it worked perfectly for the first 40 brews but now as soon asw i turn it on it starts brewing a double long coffee without me pushing anything!! once it is finished, it doesnt allow...
This sounds like a new unit. Phillips suggests returning it to local store for replacement.
Link to Phillips/Saeco website
Phillips Customer Care Number: 1-888-744-5477
Monday - Saturday 9:00 AM - 9:00 PM EST Sunday 9:00 AM - 6:00 PM EST Excluding Major Holidays
May 02, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
Hi , I have a Saeco Taleo coffee machine and have problems with brewing. The coffee get ground and then the brewing fails . Anu tips on what I need to look for ? Thanks Christina
Follow the below procedure to troubleshoot your Saeco Taleo coffee machine.
You go with the visual check first. Check on the electric cords, switches, timers, fuses, thermostats and heating elements to see if there are any damages components.
If there are some damages that are visible visually, get it replaced or repair it, if not, then you would have to dissemble the coffee maker to assess the thermal fuse.
Unplug the unit from the electrical receptacle.
Remove the carafe and filter basket. Also remove the water reservoir lid
Turn the coffee maker over and remove the screws that secure the case. Remove the case.
Take a look at the control cavity and assess. If it is a a case of disconnected wire, debris etc. simple fix, reassemble and test. If it is not so, continue to the step 7.
Use a multi-meter to test the warming and heating elements, the switch, thermostats and timer.
For any parts that is defective, work out the costing and if it worth the while, replace it.
Reassemble the appliance and reinstall the carafe and basket.
Top up the water reservoir to 50%, then test it by turning on the coffee maker.
The problem should be solve with the above troubleshooting.
Take care.
Jun 06, 2010 | Saeco Talea Giro Espresso Machine
Saeco taleo grounds are very wet - almost fluid! this hase started recently when i changed my beans. i have changed the grind to course but with no effect. any ideas?
Try adjusting the amount of coffee and then the grind to finer. If there is not enough coffee in the chamber then it gets over extracted and you get a soupy puck at discharge, if the grind is too coarse, you might also get the same result. Think of your coffee grind as rocks and sand and that will give you a better feel for the proper setting for your machine.
Jan 29, 2010 | Saeco Talea Touch 14-Cup Coffee Maker
Hi, we have aa Saecco Cafe Grande an automatic Espresso Coffee machine. We purchased over 1 year ago from Future Shop. The machine only recentlly started to leak from the bottom, I did some...
Possible areas are the steam valve leaking or the boiler valve housing is leaking. I suggest Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 05, 2008 | Saeco Vienna SuperAutomatica Coffee...
Just bought the Saecco Incanto s-class de luxe machine
lol there is a water button on it. Press that first and than turn the steam knob
Mar 19, 2008 | Saeco Incanto Classic Espresso Machine
Saeco vienna superautomatica
oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Jan 23, 2008 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
289 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
