Question about Toshiba Satellite A60 Notebook
Won't turn on
My daughter overheated my Toshiba A60 and now it won't even tun on at all. Is it fried? or maybe the cord is dead. Help!
    Scholar:
  • 139 Answers
Use the power code for yr toshiba and power some other persons toshiba to see if it will power on if it does then yr problem will be from the board i suggest u look for an expert around yu for this might really be a technical problem
thank u
Posted on May 27, 2008
Toshiba Regza 55zu655u won't turn on no lights
If its total dead with nothing suspect the fuse the power cord goes to inside the set, if other let me know what it is doing or not doing in more detail.
Dec 04, 2012 | Televison & Video
My Toshiba Satellite L655-s5107 won't turn on.
More than likely the power cord/charger is dead or the battery is. Bring it to a tech store and see if you can test out a new cord/charger and battery......
Jun 29, 2012 | Toshiba Satellite L655-S5107...
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Satellite C660-2DL won't turn on
Hi
Try replacing the battery.
Also check whether it charges,could be a faulty charger too.
Feb 22, 2012 | Toshiba Satellite A60 Notebook
It won't turn on
hi; try to check the power cord ,
if power cord has no problem it has standby light coming from the TV
when no light or dead set. there a fuse blown on the power supply section.
if there's standby light wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Mitsubishi LT-55265 55 in. HDTV LCD TV
My laptop cord fried wen i plugged it into my laptop, i can't see any damage too the cord itself but the laptop won't turn on. I removed the battery and tried powering on the laptop that way, but...
It could very easily be either a fried motherboard, a broken connection on the DC jack within the laptop, or a fried DC Jack. It is typically at least a $200 fix if you go through GeekSquad or the manufacturer - maybe more if the motherboard is fried. Unfortunately, there isn't an easy solution to this one.
Aug 23, 2011 | Compaq Presario CQ56-115DX Laptop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
My Toshiba BDX 2500ku won't turn on...Ive used it before...now it won't even open...please help....its only about 4 months old and we've only watched about 2 movies....
check the back of the player to see if the power cord has come loose, some units have a removable cord and it can get pulled.
Jun 20, 2011 | Toshiba BDX2000 Blu-Ray Player
ALIENWARE DESKTOP LOST ALL POWER
In a laptop, you can lose power in three ways.
1. Dead battery 2. Dead Power cord. 3. Bad motherboard.
ther first two should be rather obvious, as the battery won't work or it won't hold a charge, but if it won't turn on at all, even while plugged in, chances are that you're going to need a new motheboard. This can be expensive in the M--x laptops, unfortunately.
Sorry for the bad news, mate.
Apr 29, 2011 | Dell Alienware M11x Gaming Laptop Computer...
Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
Jan 19, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satellite A60 Notebook Logo
74 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
