Question about Toshiba Computers & Internet
Toshiba Satellite 1135-S125: Battery (new and Old) discharge while plugged into AC, then laptop shuts off eventually
  • 981 Answers
If the battery is running down at a normal rate, that's a relief, because at least that much is working. Otherwise, this isn't all there is to it...probably something in the supply overheated and that section will need some refitting in general; there may be a replacement module you should seek from Toshiba as a simplest method.
It seems that some part of the power supply and battery management system has gone amiss; either something is dissipating power which should not, or the circuits in the laptop tend to disfavor AC over battery power, because whatever detects steady power from AC is not triggering ON (perhaps because a power brick is bad?) So it could be circuits in the charger or the laptop itself, or both; hunt down the lines that need to be asserted to run off AC and:
1- Isolate them so you can force the line and it will run off AC, then
2- Replace the faulty circuit that should have been driving that line appropriately
Does the battery recharge in the laptop under any conditions, I wonder?
Posted on May 30, 2008
    Sergeant:
    Champion:
  • 326 Answers
Besides checking and cleaning the battery and charger terminals. Boot up and go into bios. Look at the status of the battery in bios and there is a calibrate function. Follow directions and calibrate each battery. If the battery is bad (wore out) pitch it. the new battery should be ok durring calibration.
On laptops it is highly recommended that U do not leave the power cord plugged in for very long periods of time. A laptop should be turned off when not in use and run on battery to keep the operating circuits (along with battery live) functional. In this case change is good. Always provide good ventilation. It's called a laptop, but that is the worst place to use it. flat solid surface with lots of airflow.
Ur power supply may already be damaged from adverse use as described above. If the calibration does not correct the problem, repair shop time. Over heating can shorten the life of the processor also.
Good Luck
Posted on May 28, 2008
Need driver : PCI modem, video controller for a toshiba satellite 1135 s125
here is the link for all the device drivers on the webpage.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=430235&rpn=PS113U&modelFilter=1135-S125&selCategory=2756709&selFamily=1073768663
go there and modem/display drivers are on the 1st or 2nd page.
click on the link and download and install for your laptop.
Aug 07, 2011 | Toshiba Satellite 1135-S125 Notebook
Toshiba A135-S4527 laptop ** Battery not charging!
Check the power input jack soldered connections for cracks, resolder them as necessary.
May 15, 2009 | Toshiba Satellite 1135-S125 Notebook
Wont Reinstall Software
They Only thing that could do that During Format is a Bad Harddrive.
Feb 04, 2009 | Toshiba Satellite 1135-S125 Notebook
Laptop won't turn on/stay on
Is the fan blocked?
If no air goes in, CPU could overheat.
Aug 26, 2008 | Toshiba Satellite 1135-S125 Notebook
Removing the hdd in my toshiba 1135-s125
OK, This is a big undertaking if you are completely new.
1st, if you can get a static guard wrist band - great!
2nd You will be dealing with plenty of screws so keep track
In Toshiba notebooks most screws are marked. Here are some examples:
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
I have .a Toshiba Satellite 1135-S155. It should be a similar configuration, same family/1135-S1xx series.
You will have to remove a total of 9 Phillips screws.
Place the underside of the PC up.
Disconnect all power, cables and Battery from Laptop
The first screw is located just under the Toshiba Serial Number / Bar codes, just above where the DVD/CD-ROM combo drive is located.
Mine is labeled (F5). Unscrew it and place in a safe place.
Pull DVD/CD-ROM combo drive out it is an assembly.
The Hard Drive is located under the DVD/CD-ROM combo drive.
The Hard Disk Drive (HDD) is enclosed within a caddy containing the remaining eight screws.
There are four screws holding the caddy rails to the Laptop and four screws holding the rails, caddy and Hard Drive as an assembly.
Unscrew and place in a safe place/ container they are small. Disassemble the HDD from caddy assembly; place your HD in the caddy and reassembly.
Here is another Toshiba HDD access that is slightly more
straightforward than my 1135 series
So you get an idea of where a HDD is visually:
Above is a photo of the Battery sliding out
Below is the Hard Drive Removal
I hope this gives you an idea of how to go about it for your
particular Laptop
If you need further assistance, let me know
Feb 21, 2008 | Toshiba Satellite 1135-S125 Notebook
Satellite 1135-S125 dvd upgrade
Could you post a picture if the drive and show front and rear of it? Most are standard drives but some toshibas are different.
Jan 05, 2008 | Toshiba Satellite 1135-S125 Notebook
Toshiba satellite 1135
There should be some loose connection or a broken power cord. You may have warranty for the laptop and accessories, replace immediately
Oct 27, 2007 | Toshiba Satellite 1135-S125 Notebook
Computers & Internet Logo
292 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
