Question about E-Machines eMachines Desktop PC
How do i flip my screen 180 around on a emachine
    President:
  • 2,571 Answers
In your display properties. depending on your OS and graphics card it will be slightly different.
Look in control panel or right click on the desktop and click on display control panel, you are looking for the orientation option
Posted on Oct 03, 2010
How to get screen back upright on an act flip down
Going to assume your desktop is flipped 90 or 180 degree's and that you have an Intel graphics card.
Push SHIFT + an Arrow Key until you're screen is in the right position. Try CTRL+SHIFT+Arrow if the above doesn't work.
Apr 14, 2015 | Computers & Internet
I have a RCA tablet model# RCT6272W23 the screen was broken. I replaced the screen with one that my friend had. Everything but the brand was the same . I mean everything perfect to the point. It turns on...
Greetings.
Not all screens are interchangeable even same Make and Models can have problems. What is the make of the screen tablet you used to replace on your broken one? It may have some issues with size or your tablet may have been damage when you cracked the orginal screen.
Try if you dare flipping it 180 degrees around to see if it fixes the issue.
Good luck
chadman
Mar 10, 2015 | Tablets & eReaders
Gateway laptop computer screen is upside down and can not use mouse
Shortcut Key To Flip The Screen In the Windows TO 180 Degree..
The shortcut is (or should be, read below**)
for normal windows : Ctrl + Alt + <Up arrow> (or shift+alt+<up arrow>)
and for 180 deg it is : Ctrl + Alt + <Down arrow> (or shift+alt+<down arrow>)
However, you should know that these are default shortcuts for
Intel Extreme Graphics Controller, and you can change them. To
check / change or disable these keys go to control panel->Intel Extreme Graphics->Hot Keys.
**sometimes the shortcuts do not work. This happens when you have not enabled rotation
feature in Display Settings under Intel Graphics Media Accelerator media. You need to
enable rotation in order to be able to Rotate / Flip your windows screen upside down / 90 / 180 / 270 degrees.
Mouse: with mouse, do you mean a usb mouse or the mousepad? if the mousepad isnt working, check ur "F" keys for an icon that looks like a mousepad icon. Then press the "Fn" key + the corresponding mousepad icon key and see if it works.
Oct 15, 2013 | Gateway CX2610 Notebook
My screen does not flip 180 degrees when i turn the screen around
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
Emachines 180 desktop reinstalling windows xp
Your trying to reinstall Windows XP from cd on your emahcine computer and from what I understand part of the way through the installation of XP you recieve a blue screen? Am I correct?
If so then their can be a couple of things wrong here.
One your cd drive is not reading the cd correctly try cleaning the lense on your cd drive or change the drive and use a different drive. Second your Windows XP cd is bad, screatched or smudged. Try cleaning your cd or make a copy of it on a friends machine and use the new one. If you tried all of these and you are still getting the blue screen repost for more help.
Thanks
Sep 24, 2009 | E-Machines eMachines Desktop PC
Screen keeps flipping around
Re-install the software used to flip screen...
Oct 31, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Flipped Screen in TI 84+ Silver
A simple removing of the batteries did the trick... and is probably the solution for many oddities like mine
Jun 20, 2008 | Texas Instruments TI-84 Plus Calculator
Screen has rotated 180 degrees
I have lots of Dell monitors and none of them has the ability to flip the screen orientation built into them. What I suspect has happened is he accidentally hit a keystroke combination that activated a feature in your video card driver. If you have the built-in Intel Extreme Graphics read this link and let us know if it helps. http://engtech.wordpress.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Dec 30, 2006 | Dell E173FPc 17" TFT LCD Flat Panel...
LCD wont display when opened
It's either a broken position switch or more likely a torn ribbon cable. It can be fixed by any competent dhop that services Sony cameras.
Aug 26, 2006 | Sony Handycam DCR-DVD403 DVD Camcorder
E-Machines eMachines Desktop PC Logo
78 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
