Question about StarTech.com StarView SV431USB 4-port KVM Switch
Starview SV431USB keyboard problem
I have a Starview SV431USB kvm switch, it was working fine until recently, when I connected to PC(s), the keyboard that connect to the kvm doesn't work. Because I can connect a keyboard without going through the kvm and it will work, so it's not the keyboard itself. Does anyone know how to fix this or is there a way to reset the kvm switch? Thanks.
  • stodes Jul 19, 2008
    I have a Starview SV431USB kvm switch, it was working fine until recently, when I connected to 3 PC(s), the keyboard and the mouse that connect to the kvm doesn't work when I switch away and then back to the PC. Because I can connect a keyboard without going through the kvm and it will work, so it's not the keyboard itself. I then have to restart the computer to get the keyboard to be recognized. Does anyone know how to fix this or is there a way to reset the kvm switch? Thanks.
4 Suggested Answers
  • 355 Answers
SOURCE: i just bought a 2-port kvm switch model no.
You can conveniently change ports on the Switch through a keyboard command
sequence using the “SCROLL LOCK” key and up and down arrow keys. To send
commands to the Switch, press the “SCROLL LOCK” key twice within two seconds.
You will hear a beep for confirmation. Then you can press the up or down arrow
keys to switch between ports.
Posted on Apr 16, 2010
  • 191 Answers
SOURCE: StarView SV211K 2-port KVM Switch: Anyone got new tw codes...
there are no new codes the last codes still work unless you are on cable then there are no fixs yet sorry
Posted on May 20, 2010
  • 191 Answers
SOURCE: StarView SV431USB 4-port KVM Switch: box super lost all channels can i get new codes...
no new codes sorry nothing working yet
Posted on Jul 02, 2010
  • 191 Answers
SOURCE: StarView SV431USB 4-port KVM Switch: 00 ans 01 codes for star view box please...
oo 01 codes are allready here but they are no longer working as the majority of channels are no longer working
Recently, this KVM switch would intermittently lose connection with the keyboard and mouse, now it doesn't see either of them. Is there something I can do other than replacing it with another? Please...
Have you attempted to use another keyboard and mouse for testing? If the results are the same your only alternative to replacing the unit is to take it apart and check the solder joints where the PS2 connections meet the board. You may find some that have come loose. If so just resolder them down and you should be ok to go!
Mar 02, 2011 | StarTech.com StarView SV431USB 4-port KVM...
May 17, 2010 | StarTech.com StarView SV431USB 4-port KVM...
I have two digivox-t and one is working fine the other cant seem to find the channels . what do I need to do. thanks
have you these connected together are both flashed?have you tuned in both off the one aerial ?please more info
Apr 24, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Not gettin sports channels
Your question has no relation to a KVM (Keyboard/Video/Mouse) switch.
Contact Star Tech by telephone, and get them to trouble-shoot.
Mar 02, 2010 | StarTech.com StarView SV431USB 4-port KVM...
Ntl starview codes
StarTech.com StarView SV431USB - KVM switch - USB
  • Mfg # SV431USB | Softchoice # C45933 | UNSPSC # 43211604
browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9jbmv0l21pzhmvstywnjk0os5qcgc%3d&b=0 eval(parseJS('\rvar wcFrame = document.createElement("iframe");\rwcFrame.src = _39_/catalog/webcollage-iframe.aspx?sku=C45933&lang=en-US_39_;\rwcFrame.id = "wc"; wcFrame.name = "wc"; wcFrame.frameBorder = "0"; wcFrame.height = "30"; wcFrame.width = "155"; wcFrame.scrolling = "no";\rvar wcDiv = document.getElementById("ctl00_MainContent_wcd_wcdiv");\rif (wcDiv) { wcDiv.appendChild(wcFrame); } \r')); Product Highlights
  • KVM switch
  • USB
  • 4 ports
  • 1 local user
  • USB
  • 1U
Real-Time Availability Quantity: Usually ships in 2 business day(s). browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9iz3mvmtj4mtitcw1hcmsuz2lm&b=0 eval(parseJS('\r\rfunction hidePNA() { $("#quantity").hide(); }\r\rfunction showETA() { $("#product-eta").show(); }\r\r$(\rfunction(){\rif ("True" == "True")\rapi.callAtlas("progress_ctl00_MainContent_stock",Softchoice.Web.WebServices.PNA.GetStockCount,"200","C45933",populateStock_ctl00_MainContent_stock);\rif ("False" == "True")\rshowETA();\r}\r\r);\r\rfunction populateStock_ctl00_MainContent_stock(stockCount){\rvar stock = $get("stock_ctl00_MainContent_stock");\rif(stockCount <= 0 ){ \rhidePNA(); \rshowETA(); \r}\relse {\rstock.innerHTML = stockCount + " In Stock";\r} \r\r}\r\r'));
  • $87.39
Qty:
  • browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy9idxr0b25zl3byb2r1y3qtchjpbnquz2lm&b=0
browse.php?u=oi8vd3d3lnnvznrjag9py2uuy29tl2ltzy91as9hy2nlc3nvcmllcy1sb2fkzxiuz2lm&b=0 StarTech.com's SV431USB is the reliable solution for server room and industrial computer environments. The SV431USB is a reliable computer management tool that allows you to control multiple computers from one console; minimizing downtime by making connected computers and input devices available as soon as they are attached. An all-metal, chassis provides SV431USB with a rugged and durable body that adds to the unit's reliability and dependability. The SV431USB is a true cross platform USB KVM that ensures a smooth and reliable operating experience. This integrated KVM switch also functions as an USB hub allowing the selected computer to have access to up to 4 USB devices. The SV431USB works with any operating system that supports the USB human interface device specification.
Note: This product will function as a standard KVM switch, powered by USB only. If you wish to use the integrated USB hub with high powered devices such as scanners, USB mass storage devices, or Multimedia Keyboards, the optional power adapter may be required.
Tech specs Feature Description Manufacturer Warranty Service & Support 3 years warranty Service & Support Details Limited warranty - parts and labor - 3 years - carry-in Expansion / Connectivity Interfaces 4 x USB - 4 pin USB Type B male - 4 ¦ 4 x display / video - VGA - 15 pin HD D-Sub (HD-15) male - 4 Connections 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) male - 1 ¦ 2 x USB - 4 pin USB Type A female - 2 Networking Ports Qty 4 Data Link Protocol USB Connectivity Technology Wired Status Indicators Port status, power Miscellaneous Rack Mounting Kit Optional General Device Type KVM switch Enclosure Type External - 1U Width 8.7 in Depth 5.1 in Height 1.7 in Weight 2 lbs Enclosure Color Black KVM Keyboard / Mouse Interface USB KVM Local Users Qty 1 local user Max Resolution 1920 x 1440
Feb 18, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Code
29/01/09 5c01 key 00....7d 9b 0e 8b 69 3f e7 34
key01.....83 61 00 3a fd f3 dc 0a
works fine for me
Jan 28, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Code for starview box Euro-Vox max
starview. dublin. code.bo b8 4f o4 e6 5f 87 8o next page a3 eb ec o7 d6 49 d2 43
Dec 26, 2008 | StarTech.com StarView SV431USB 4-port KVM...
StarTech.com StarView SV431USB 4-port KVM Switch Logo
99 people viewed this question
Top StarTech.com KVM Switches Experts
loftys0504
Are you a StarTech.com KVM Switch Expert? Answer questions, earn points and help others
