I am getting an error on a Xerox 8200 phaser it is 7.000.47:57749 please explain what it is and how to resolve this error. Thanks
  • yan dikshteyn Oct 04, 2010
    The lamps are turning on its not a lamp error code
    very helpfull thanks
  • 857 Answers
This a common fault code with Xerox
07,005.47:
Typically indicates that the lift pins on the maintenance drawer are worn (this is the black tray labeled "A" visible when the front door of the printer is open). When the lift pins are worn, the maintenance roller does not properly oil the print drum before each page is printed. The solution is to replace the maintenance drawer. A temporary solution is to place plastic sleeves over the lift arms.
15,004.45:
Typically indicates that one or both of the light bulbs in the drum heater have burned out. See below to order (2) replacement bulbs and installation instructions, and tool sets. A set of TORX screwdrivers is needed to perform this repair (sizes 10, 15, 20). If replacing the bulbs does not correct the problem, the drum heater needs to be replaced.
Posted on Oct 04, 2010
    Genius:
  • 1,478 Answers
From the error code posted, i think that is a drum heater fault code. The drum heaters are 2 ,150 watt halogen lamps. One or both have burnt out.
You can verify this by shutting the machine off, then turning it back on and look into the fan opening at the right side of the machine. See if you see a glow inside the machine. I doubt you will. if not you will need to replace the lamps
Take care.
Posted on Oct 03, 2010
Xerox 8200 printer error 15.004.45. How do I
If this is your first rodeo, contact www.inktechnologies.com. They can walk you through it and provide the parts.
Jun 28, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Error xerox Phaser 8200 15004,45:12318
Hi erniec420:
Hope that this helps.
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850 and 860 have a pre-adjusted head.
Apr 03, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Where in Belgium Europe can I find Heating halogen ligths for a 8200 phaser printer.On the old continent we use 220 volts. Xerox asks 200? plus a heavy repair fee ... Thanks for help
If you are able to do the repair yourself, then remove a lamp from the preheater assembly and look at the voltage and wattage on the bulb itself...on some there is also a lamp part number.
you can also order a repair kit from e-bay. The same lamps are used in the Phasers 840, 850, 860 & 8200
Here are 2 links that have what you need (if the internal voltages for the printer are the same in europe as in usa):
http://cgi.ebay.com/Xerox-Phaser-840-850-860-8200-Drum-Heater-Repair-Kit_W0QQitemZ230320054253QQcmdZViewItem?hash=item230320054253
http://cgi.ebay.com/XEROX-PHASER-860-PREHEATER-ASSEMBLY-650-4228-00_W0QQitemZ350139954330QQcmdZViewItemQQptZCOMP_Printers?_trksid=p3286.m20.l1116
Dec 14, 2008 | Xerox Phaser 8200 Laser Printer
Xerox phaser 8200 Won't warmup properly
Does it diaplay a fault code? It may take 20-30 minutes to display. I suspect if you leave it on long enough it will come up with a 15,004.xxx code.
I suspect you have bad drum heaters, but please leave it on for an extended period of time and see what fault code comes up.
Thanks.
Sep 30, 2008 | Xerox Phaser 8200 Laser Printer
jasbo
jasbo
