Question about Pantech Duo Smartphone
I have a few problems with my duo
1. dropped calls2. hangs up call 3. dust under the window
  • 20 Answers
Check ur sim card. if it doesnt have the 3g fireball on it, you need to update it.
Posted on May 30, 2008
..................My system config is : Intel C2D E7500 with 2.93 GHz CPU MOBO is Intel DG41RQ and 2gb DDR2 RAM OS is Windows XP - 32-bit (Service pack 3) .Problem is iwant to buy a new graphics card
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Mar 10, 2013 | Intel DG41RQ Motherboard & Core 2 Duo...
I'm trying to boot up Windows 98 and it hangs up at the Windows 98 logo. When I
test all leads that attach to your hard drive including electrical extensions IDE SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even the electical extensions
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
make sure the CPU has a secure dust free seating with thermal paste
make sure your ram modules are securely seated with no dust in the sockets also the Cmos battery has charge with no dust in the socket
on some motherboards cmos batteries are soldered in
hope this helps
Jun 03, 2012 | Microsoft Windows 98 Operating System Ms...
I've zebronic 845 gl mother board, p4 2.4 ghz intel processor, samsung 80 gb hard disk,256mb hynix ram. when i run any program in windows xp sp2 , my system is hangged after few minutes, i press c
First you might need to have service pack 3
XP Service pack 3
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
a slight overhaul of your computer
second clean your computer of dust using a fine air blower from a compressor specifically around your CPU central processing unit making sure there is no MOISTURE in the airline
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
test or replace all the leads that attach to your hard drive including electrical extensions IDE SATA the ones that attach from your motherboard to hard drive make sure they have secure dust free connections
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
then click start run type cmd then type chkdsk/r/f which will automatically scan for and attempt to repair bad sectors and fix any corrupt files this will schedule to happen on restart
another way of running the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
you should not do anything while the chkdsk utility is in progress any input may damage your computer your hard drive then defragment your hard drive
you have to keep a computer very clean & free of dust and give it regular maintenance
also you might download and use this registry cleaner it is 100% totally free to use
http://download.cnet.com/ccleaner/
and you might need to uninstall some unnecessary programs
right click in the bottom toolbar select task manager applications you will see whats running
also in processes see whats ticking over
do have any tune up programs installed on your computer
hope this helps
Apr 26, 2012 | Intel Computers & Internet
Spacebar key and right arrow key of my MX duo keyboard was not working.
First: Have you spilled any liquids on the keyboard? If so, you may not be able to fix this.
But try a few things...
1) Get an air canister, compressor or vacuum with a nozzle. Try and ****/blow any grit and grime from under the keys.
2) Carefully remove the spacebar and arrow keys using a small flathead screwdriver. Slide the blade of the screwdriver under the edge of the key and lift it up. Be gentle, as the small mechanisms holding the keys in place can break. Once the keys are removed, clean out any dust or grime using a lint-free cloth.
3) If nothing works, go get a new keyboard...you can get a nice one for under 30 buckaroos.
Mar 10, 2011 | Computers & Internet
Computer hangs regularly, usually after just over an hour. But occasionally after a few minutes. Attempts to check 1TB disc unsuccessful (Extended WinDlg122) because computer freezes half way through...
Sounds like 1tb hard drive is passing quick test and then freezing extended test. And if it doesnt freeze during the 200gb test then I would guess the 1tb is going bad. Check the event viewer in windows under system and see if there are any Disk errors with a red X and that ideall will say disk drive 1 or 2 cant read it and yeah that would help confirm it is failing.
Mar 03, 2011 | Intel Core 2 Quad Q9400, 2.66 GHz...
My pc hang after I logged in into the desktop,what is the problem?
1. you have dust build up around the CPU and the cabinet needs cleaning.
2. Your hard drive is full and there is no more space on it for data storage
3. your temp files, History files, and cookies need to be deleted in the browser under
"internet tools" in Internet Explorer
4. you have a virus
Oct 05, 2010 | Intel Computers & Internet
New HP desktop goes through Post and starts Win 7 splash screen, then the monitor drops off.
1. Restart the Computer
2. Press F5 or F10 a few seconds after POST (and before Windows tries to load) to access SAFE MODE
3. In SafeMode head straight to Control Panel - System - Device Manager
4. Remove all drivers under Display Adapters
4b. Remove all drivers under Monitors
5. Restart the computer
If u are able to get into windows using generic video drivers, then the problem is resolved. It's time now to reinstall the video drivers for u video card.
Mar 15, 2010 | Princeton Digital VL173 Monitor
Sound card Driver problem under Win XP
download new drivers from driver detective..
or click bharatgulati.blogspot.com.
i do hv 1 problem..
"iam getting yellow vertical lines at startup screen..the lines are moving.system hangs after few sec. & sometimes it works perfectly.cant even format the system as it hangs.help"
Jul 22, 2009 | Computers & Internet
System is very very slow
There are many causes to that simptom (assuming you are using any version of windows):
1 - a disk full of temporary internet files, and loads of other junk used once by the operating system;
2 - a disk that has not been defragmented for a long time
3 - dust! it gets in all the crevices of the machine, and it overheats, making it slower and slower. Recently I vacuumed a computer at work and brought it from 85 centigrade degrees to 41 degrees, just by removing dust in the cpu cooler, and it brought a major improvement in performance.
And some other causes, but these are the most typical.
Oct 12, 2008 | Computers & Internet
Pantech Duo Smartphone Logo
Top Pantech Computers & Internet Experts
Computer Repairing
Computer Repairing
Jax Planet
Jax Planet
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
