Question about Canon PIXMA iP6700D InkJet Photo Printer
CANON IP 6700D ERROR6A00
HI WHAT CAN I DO TO FIX THIS PROBLEM
  • MR FIX ALL May 31, 2008
    THANK IT WORK
  • Anonymous Feb 03, 2009
    what's the purged unit?
  • 3 Answers
  1. Problem similar on canon ip4300 was solved by removing semi dry ink from black sliding rail. White plastic slide was stuck to the right side (spring was still stretched when printing head I moved to the left). Slide the white plastic slide to the left and clean the rail. This slide must be free to move left and right.
Posted on Apr 10, 2009
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 77 Answers
1. Open the cover and wait for ink carriage to center
2. Pull out power cord
3. Pushed carriage to far left (should slide easily)
4. Used paper towel and wiped purge unit a lot of times (press down to soak paper towel with ink). Repeat until the paper towel is relatively clear.
5. Used diluted napisan (oxygen-based cleaning agent in the ratio of 1:3 with powder:water) and soaked paper towel
6. Repeat step 4 with wet paper towel. Repeat until purge unit is near-white.
7. Pulled and pushed clear plastic wiper (north of purge unit) and wiped it down
8. Slided carriage back to original position
9. Removed Print head cartridge and wiped out excess ink stuck on bottom.
Posted on May 28, 2008
Is pixma 6700d wifi enabled thanks
No. It only has Infra Red, Bluetooth and USB2.
Jun 19, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Error6a00 canonip6700d
Hi dina,
This error code is for a sheet feed error so in english a paper jam.
Canon will offer you 2 choices if you contact them, send it or take it to be repaired at a hp store or let them swap it for a refurbished version.
There are no guaranteed fixes for this but you could have a look to see if there is any paper stuck inside even small bits and you could try to gently move the print head left and right, it will resist but just be gentle and wiggle it a bit, if that doesn't work use a little bit more force it will probably make a loud clicking sound but that's nothing too much to worry about as its just the cogs inside releasing and slipping.
Check carefully for paper as even small torn pieces could cause this error.
I hope this helps
Myke
Feb 22, 2011 | Canon PIXMA iP6700D InkJet Photo Printer
Error 5b00 canon ip 6700d
Hi hamedan_nsr,
The 5B00 error code for Canon printers is the "Waste Ink Error Full" error. This means that the printer needs service, and will stay locked down until the Reset has been applied. Please be informed that Canon has changed all new printers over to the point that special "Service Tool" software is required to reset or "Service" anything in the printer. In the old days you could have easily and manually entered the Service Mode and manually reset the waste ink counter. Now you have to have the software to do this. The very bad news is that Canon is very tightly controlling and distribution of their Service Tool, and there is a different one for each model printer. Your only option is to take it to an authorized Canon service center and have them reset the printer. Most problem is that some people just apply the reset and never service the printer and sooner or later this will cause much bigger problems.
Hope it helps.
Thank you for using FixYa.
Nov 20, 2010 | Canon PIXMA iP6700D InkJet Photo Printer
How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Nov 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Error messages: U150 + Ink tank errors have occured
Reset Canon MP600 to the Factory Setting
  1. Press the HOME button.
  2. Use the Easy-Scroll Wheel or the right/left arrow to select Settings, and then press OK button.
  3. Use the Easy-Scroll Wheel or the right/left arrow to select Device settings, then press the OK button.
  4. Use the Easy-Scroll Wheel (B) or the up/down arrow to select Reset settings, then press the OK button.
  5. Use the Easy-Scroll wheel or the up/down arrow to select Yes on the confirmation screen and then press OK.
  6. Press the HOME button to return to the HOME menu.
Jul 12, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error U130 Cannon ink tank
it is possible that the ink chip is damage. try to buy another. or you can buy original ink to make sure the printer is ok.
Apr 16, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Waste ink absorber on canon iP 1600
Try reading THIS .
Hope that fixed ya...
Geno
Apr 04, 2008 | Office Equipment & Supplies
ON THE CHIPS, TRY CLEANING THEM WITH ALCOHOL (70%)
SOME BRANDS YOU CAN SHAKE THE CARTRDGES TO RESET THE INK COUNTER
Feb 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  iP6700D InkJet Photo Printer Logo
1,161 people viewed this question
old marine
old marine
