Question about GE JVM3670 Microwave Oven
Where is the fuse located for the GE Profile Spacemaker microwave JVM3670?
  • GE Master
  • 3,051 Answers
Hello there:
if you first remove the power to the unit.
then remove the outer cover by removing the screws that are lovcated on the back and the sides the cover will come off then if you look at the right side looking from the front you willl see the electrical board and the fuse is on the board now take the fuse to a autozone or even radioshack and they will have this fuse ok
Hope this is very helpful for you
Best regards Mike
Posted on Oct 03, 2010
GE Profile microwave # nm1851dm2bb lost all power while heating something. Could it be the internal fuse? Anything else?
If you're lucky it's the internal fuse. Otherwise, there's not much other stuff besides the fan that's easily replaced.
Nov 25, 2013 | GE Profile Spacemaker Over-the-Range...
GE spacemaker profile xl 1800 moving vent will not close
I'm betting your base model number is JVM1860, JVM1861, JVM1870, JVM1871, JVM3660, or JVM3670.
That's the automatic louver you're having trouble with. There are micro switches in the louver assembly which tell the controller when the louver is open or closed.
If one of those switches or the louver motor fails, the louver will not work correctly.
Did your cooktop lights recently fail?
Sometimes the surge from them shorting will cause damage to the circuit board, which can be repaired.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl1800 vent fan
May 03, 2013 | GE Profile Spacemaker XL 1800 36"...
Locate the fuses in jvm2070
Fuse is located on the right side under the keypad, follow wiring to main board, should see a small fuse clipped in, pop it out and replace with same current rating. Before you do this unplug microwave, and discharge high voltage capacitor "silver and rectangular in shape" under plastic flap near fuse. One thought the voltages are lethal when running.
Mar 14, 2012 | GE Profile Spacemaker Over-the-Range...
My ge profile spacemaker II microwave went dark, no lights of any kind and no sound or response when pressing any button. tried resetting the circuit breaker but no change
Did you check the internal fuse? Often when everything is dark the fuse that protects the microwave is blown. Take the old fuse to your local hardware store and they will have a replacement for you. Should cost less than $5.
Nov 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave oven runs but does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ftsd
Jun 22, 2010 | GE JVM3670 Microwave Oven
I have a GE Profile spacemaker 2.0 microwave and it just quit working on me. Sounded like a fuse popped?? I verified that the electrical outlet was working. Is there a fuse to replace inside the microwave?
Hello. You have isolated the problem.
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Jun 23, 2009 | GE Profile Spacemaker Over-the-Range...
No heat in GE XL1800 1100 Watts microwave
model # JVM1870BF001 GE Profile spacemaker XL 1800 microwave
after episode of using defrost which burned food--now stopped heating--still has power/fan--don't know how to change fuse--please help
Jun 21, 2008 | GE XL1800 1100 Watts Microwave Oven
GE JVM3670 Microwave Oven Logo
661 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
