Question about Toshiba Computers & Internet
How do i enable the buttons on the top of my keyboard. (toshiba qosmio - laptop) as my friend accedently disabled it and he doesn't know how to enable it?
  • 86 Answers
Http://www.ebookspdf.com/computers/2149/toshiba-qosmio-g30-users-manual/
Folow the link  and you will find user manual for your laptop and mozt important the solution for your problem
Have fun dude
Regards
Posted on May 27, 2008
Toshiba Qosmio x875 keyboard suddenly stops working
pls remove the key board ribbon cable and re seat again
Sep 08, 2017 | Toshiba Qosmio Computers & Internet
How can i enable/disable the internal wifi card on my toshiba l455d-s5976 notebook
Click on the wifi icon on bottom right hand side of screen,,go to network and sharing,,,right click your connection on the screen ,,go under properties,,disable ,,and enable options,,,also should have a wifi on off switch ,,be the best thing and easiest,,,should be on right hand side of laptop towords the front,,a switch ,,if not check on the top of keyboard,,either sAy wifi or have icon,,,good luck,,also,,toshiba website ,,support ,,can help ,,
Dec 21, 2011 | Toshiba Satellite L455D-S5976 Notebook
I bought a toshiba qosmio x775 and it's pretty cool, but i fully charge it and the next day it's battery is like 80% or 75% percent and it's weird and i don't like it, how can i make my...
Toshiba Qosmio has many advantages, eg tv, wifi, and the extra screen width...
Disable some features might reduce the power consumption.
Or you can try free trial BATTERY DOUBLER >
http://www.dachshundsoftware.com/buy.html
akee.4shared.com
Aug 16, 2011 | Toshiba Qosmio G25-AV513 Notebook
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
May 10, 2011 | Toshiba QOSMIO E15-AV101 Notebook
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
Touch pad will not work
Hold down the FN button and up on the top of the keyboard there will be a button with a picture of a mouse. As your holding down your FN button hit the other button and see if it enables your mouse. Something should come up on the screen showing you that its enabling or disabling the mouse.
Feb 11, 2009 | Toshiba Satellite A100-S8111TD Notebook
Disable onboard mouse
TouchPad Enable/Disable ( Fn+F9 )
Dec 24, 2008 | Toshiba Tecra A3 Notebook
Wireless connection on qosmio G25-513 not working
access your router with following link
http://192.168.0.1
then type user name:admin
password is:admin or blank
then enable DHCP.then u can get ip automatically
then enable in your intel pro ipaddress properties auto get ip addrese.
thats it.
Nov 13, 2008 | Toshiba Qosmio G25-AV513 Notebook
The microphone disabled and no command to be enabled
I redownload the driver for audio from system recovery .
Nov 08, 2008 | Computers & Internet
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
169 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
