Question about Hotpoint Ovens
I have a Hotpoint BD32 double oven. The top oven works properly but the bottom oven does not heat up although the fan and light work. Any idea about this fault and how it can be rectified?
  • Hotpoint Master
  • 3,463 Answers
You need to replace the oven element,, located at the rear of the bottom oven compartment behind a removeable panel.
Posted on Oct 03, 2010
Dose a BD32 oven have self cleaning
Posted on Oct 31, 2012
Hotpoint BD32 built in oven is not heating up anymore, top oven/grill works fine. When it's switched on it makes the right "noise" but there is no heat or light. Is this an element problem?
you can check the element, just get a volt ohm meter, set to ohm's and make sure it shows a short, otherwise you have an open or bad element.
Nov 06, 2013 | Ovens
Hotpoint BD32 element not working, How can I check if it is a faulty element
Assuming you are talking about the fan oven element, you should be able to feel heat from it , if you are not sure it is working, then you need to remove the rear cover of oven to expose the fan and the element, run it for a couple of minutes, then feel if it is hot, if not, it needs to be replaced.
Hope this helps.
Nov 27, 2009 | Hotpoint Ovens
Top oven on uy46 working, bottom oven light coming on but no heat coming in??
If the fan is working o/k, then you need to replace the oven element, located behind cover at rear of oven compartment, very straightforward repair to do.
Please rate my solution.
Thanks.
Nov 07, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Botom oven not working
Hi
The oven element is probably faulty, I assume the fan is still working.
Nov 23, 2008 | Ovens
HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Nov 23, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint double oven
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint bottom oven
Cooking is determined by 3 things so let's look at what they are and what they do.
They are:
  1. The Fan Oven Element - This is very much the same as a light bulb only instead of giving off light it gives off heat. Like a light that is switched On or Off by a wall switch, the Element is switched On or Off by a Thermostat according to the temperature required. In short if the element fails your oven will be cold.
  2. The Fan & Motor - This sucks the air in through the centre mesh and circulates it around the Element and pushes the heated air out of the top, bottom and sides of the back-plate. Fan ovens cannot heat properly if the fan is not running OR if the fan runs too slowly as the motor starts to fail.
  3. The Thermostat. - This is basically an On/Off Switch that responds to the temperature in the oven. If The Fan is running correctly and you are achieving some temperature in the oven, then the fault will be with the Thermostat.
I hope this Helps - Terry
ALWAYS ISOLATE THE POWER SUPPLY BEFORE WORKING ON THEI APPLIANCE!
May 06, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Dec 09, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
666 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
