Question about Mitsubishi WD-60735 Projection Television
The lamp went out in my TV. I replaced the lamp and it worked fine. I moved the TV and when I went to turn it on it wouldn't stay on. It will come on for about 10 seconds and then shut back off. The red light keeps blinking after it goes off. I have to unplug the TV or hit reset to get the red light to stop blinking. I would really appreciate some help as I'm sick of looking at a 60 inch paper weight. Of course this problem happens just a couple months outside of my warranty.
  • kelley112571 Oct 03, 2010
    I ended up removing the lower rear panel to check the DMD fan. The fan didn't come on when I turned the TV on. I pushed the connector in and it was a little loose and that fixed my TV. A loose connection had me without my TV for 6 months because all the TV repairman in my area wanted $100 or more just to diagnose the problem and they were saying it would most likely run $400 or more to fix.
  • Mitsubishi Master
  • 8,457 Answers
Recheck all the projection lamp conections again.Still getting,the same result.Replace the projection lamp again,some how the move,it got the projection lamp shorted.
Posted on Oct 03, 2010
  • Chi Chu Oct 04, 2010
    That good,find out what happen.Moving,most of the times,just lose connections.
My 98 Sentra does not turn over
Has the battery been load tested? do that first.
Apr 30, 2017 | 1998 Nissan Sentra
Hitachi Ultravision 50V710. Replaced the lamp bulb with the correct part step by step. Even cleaned out the dust that was inside before replacing. It went in fine, I put everything back together, but when...
lamps going out are normal so don't worry. On this TV, if you replaced with an exact replacement then it's not the lamp. Something is not reattached properly or completely. Normally it pertains to ventilation or a lamp access panel being loose. Check those out and make sure everything is tight. if it still doesn't work then check for blown capacitors on the different boards. My Tv that is a samsung does this when the back panel is not secured properly. Ventilation and proper securing of panels are always important. BUT NORMAL!
Take a few deep breaths and check it all out step by step back tracking areas that you accessed. Sounds like something is definitely loose. Maybe ribbon cables loose, fans, screws, boards, etc. Something is loose in there. Let us know so it updates your solution if this info helps.
Mar 10, 2011 | Televison & Video
I bought a mitsubishi wd 52327 new several years ago. I've replaced the lamp once and it worked fine but now it needs to be replaced again. We bought a lamp off EBay w/housing. I installed it but the tv...
Hi Brent, Mitsubishi's have a problem with the power supply and the Light Engine which incorporates the Digital Module of which it has to be purchased as a complete assembly. I sincerely believe you should not put that kind of money into a dlp set. The cost of the light engine is in the area of $1100.00. Your last idea is the best one.
Mar 09, 2011 | Mitsubishi WD-52327 52" Rear Projection...
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
When I power up the TV, the fan turns on and I get the green blinking timer light as usual. Once the light turns off I manually boot the TV with the bypass switch and hear the second fan start up but the...
I would suggest it is a ballast problem. You can check supply of 5 volts to ballast's small 5 pin connector (trigger voltage) and about 300V-330V to large 2pin connector. If both voltages present at the start and lamp is working with in another TV - it is bad ballast.
Aug 11, 2010 | Mitsubishi WD-62725 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Jul 18, 2009 | Mitsubishi WD-52531 Television
52HM95 Lamp Issue
The Tv will shut off and sho error if the ballast is bad. Replace the ballast and you should be fine.
Mar 22, 2009 | Toshiba 52HM95 52" HDTV Projection...
TV on/off
How long is your TV on before it turns off? Check the fans and make sure they are all working. The TV may be shutting off due to overheating if a fan quit working.
If you think the lamp is still good maybe try replacing the lamp ballast.
Jan 16, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Mitsubishi WD-60735 Projection Television Logo
268 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
