Question about Ovens
Hi, I have a Whirlpool RBD275 wall oven. It has the e6 f2 error codes in combination. Could you please give me step by step instructions on how to replace? Also, any recommendations on where I can purchase the new board? Thank you so much for your help. Neil H.
  • 84 Answers
Hello these control boards can be fixed quickly and reliably at www.fixyourboard.com. The cost is lower and the warranty is longer that new.
Posted on Oct 30, 2010
I have an error code of E6 and F2 on my whirlpool accu-bake oven display panel. What do they mean.
Hi
F2-E6 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Ovens
WHIRLPOOL GOLD DOUBLE OVEN BEEPING WILL GO BLANK THEN WILL SHOW E6 F2 TROUBLE CODE
Hi dear.Please do the following if you know what you are doing.According to your explanation,F2E6 code on whirlpool oven related with following: F2 - E6
Cancel key drive line open
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
I hope that solves your issue.Thanks.
Aug 28, 2010 | Whirlpool GBD307PDS Electric Double Oven
I have a whirlpool oven rbs305 and the pannel shuts down and a code comes up E6 and F2 What can be done Thanks
F2 and e6 in combination indicate a cancel key open condition. What this means in layman's terms is that the key-panel Has a problem. If it was just recently cleaned with a wet cleaner, you can try drying the keypad off or even CAREFULLY warming it up with a hair dryer. Don't get it too hot so that you melt anything.
If this does not work, you will need to replace the key panel on the oven.
You can do this repair yourself and should you decide to, please just comment back with the full model number off the tag on the oven and I will give you step by step instructions on how to do it.
Good luck!!
Aug 14, 2010 | Whirlpool RBD305PD Electric Double Oven
Whirlpool double ovens error message e6 f2
good day,
hope this link below will solve your problem.
ovens
Mar 26, 2010 | Whirlpool RBD245PDS Electric Double Oven
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RbD275pdq10 double oven E6 F2 error
I have a "double oven", Model # RBD275PDQ10 and it has Error Code E6 F2, What is the part that I need to fix it?
Dec 20, 2008 | Whirlpool RBS245PDS Electric Single Oven
Error code E6 F2
hi there. i have located the manual and posted the link below.
PARTS MANUAL
Oct 23, 2008 | Whirlpool GBD307PD Electric Double Oven
Ovens Logo
338 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
