Toshiba 2060 Copier I PUT PAPER IN DRAWER AND IT CONTINUES TO SAY LOAD PAPER How do I check/clean sensor?
  • 320 Answers
Pull the paper tray from the printer turn the printer on its back to have an unobstructed veiw of the bottom on the left side of the pick wheel there is a paper out flag make sure that this moves freely. clean the pick wheels with aresol contact cleaner. this type of cleaner is good to clean all printer part as it leave no residue
Posted on Oct 04, 2010
My toshiba 2060 copier easy printing but print paper some line missing please or broken,please solved my prob.
if white lines appear in your toshiba 2060 inaccuracies.
almbres replace the corona charging and transfer, do not forget to check the development unit if turevelador is too old replace
Feb 25, 2015 | Toshiba 2060 Copier
My toshiba 2060 copier shows no paper when the drawer is full of paper.
check the paper size may be is wrong ,or paper detection
Jul 27, 2011 | Toshiba 2060 Copier
Toshiba 2060 gives Misfeed error. The copier is not picking the paper up out of the tray. There is no jam. What's going on ? Is there an easy fix?
sounds like the paper feed rollers are worn or dirty try cleaning the rollers if the problem persists then unfortunately you will have to replace the rollers
Apr 06, 2011 | Toshiba 2060 Copier
I have a Toshiba 2060. Runs great except for one issue. The cartridge has the paper oriented landscape with the label LTR. When I copy using the eith the ADF or platen glass and the paper is also...
As far as I know the Toshiba 2060 does not have an auto rotate function. This means that whatever drawer you pick to copy from is what the scanner will scan. To change which way you copy your sheets you will have to change the physical size of the drawer to copy the other way.
Aug 31, 2010 | Toshiba 2060 Copier
Toshiba 2060 copier shows paper jam at right side but I can not find any paper jam at all any other thing will cause to show paper jam? thanks mike
sometimes it does not sense that you opened the door that it says the jam was in. open and close the jam areas to see if it clears. if not restart the copier
May 17, 2010 | Toshiba 2060 Copier
Close drawer...
Take paper draw out of the machine you mite have paper behind the draw preventing sensor monitoring that draw from working properly. Mite get some can air an get any paper dust off the sensor for that draw. Is paper properly installed and are the paper guides securing the paper properly installed? Don't be storing additional paper in the draws. Is paper in the draw matching what is on the operators panel.
Aug 15, 2009 | Toshiba 2060 Copier
My toshiba 2060 copier starts knocking when warming up and then show the trays are empty , do you know what it could be?
the lift motor for the paper trays is faulty or if yu pull the trays out and look behind the tray there are som connection there check there aint no paper stuck there.. if you put the trays back in on at a time you should find the one causing the problem.. my money is on the lift motor as this lifts the tray up to the paper sensor to show paper in trays..
Aug 03, 2009 | Toshiba 2060 Copier
Paper jam on my toshiba 2060 model
Exactly where in the machine does the paper jam??If it jams when you hit the print button, try cleaning the paper feed tires with WD40.spray it on a clean cloth, clean the feed and pickup tires thoroughly and make sure to get ALL of the WD40 off the tires before using the machine.If you take the paper cassette out and look with a flashight you should be able to identify the paper feed tires.
Mar 24, 2009 | Toshiba 2060 Copier
Jaming on copier
there is the problem in the heater unit of your machine check it,open the front cover release the blue lock left side and take out the paper
Sep 11, 2007 | Toshiba 2060 Copier
24 people viewed this question
jasbo
jasbo
