Question about Lowrance LGC-2000 GPS Unit GPS Receiver
Will a lgc 4000 work in place of a lgc2000 - Lowrance LGC-2000 GPS Unit GPS Receiver
2 Suggested Answers
GPSCity Mike
  • 464 Answers
SOURCE: replaced gps with lgc 4000 arial but comes up gps not responding can some body please help? les
You may want to contact Lowrance Support for assistance.
Posted on Feb 01, 2012
Toshiba photocopier solution error code E030
Open the cover of the unit/area whose picture is blinking on the control panel. Is there any paper on the transport path? (Refer to the following table.)
IF Yes Remove the paper.
No 2
2 Is the sensor in the
jamming area working?
IF No • Check if the connector of the sensor is
disconnected.
• Check if any of the connectors on the LGC
board is disconnected.
• Check if the connector pins are
disconnected and the harnesses are open
circuited.
• Check if the conductor pattern on the LGC
board is short circuited or open circuited.
• Replace the sensor
• Replace the LGC board.
3 LGC board • Replace the LGC board.
Jun 11, 2016 | Toshiba Office Equipment & Supplies
Toshiba E-Studio 3511 Color Copier code cea0
[CEA0] Revolver home position detection abnormality
Is the revolver home position sensor working properly? May need to be cleaned.(Perform the input check: 03-[FAX]ON/[2]/[C])
NO 1. Check if the connector or joint connector of the revolver home position sensor is
disconnected.
2. Check if the connector CN361 on the LGC board is disconnected.
3. Check if the connector pins are disconnected or the wires of harnesses are
open circuited.
4. Check if the conductor pattern on the LGC board is short circuited or open
circuited.
5. Replace the revolver home position sensor.
6. Replace the LGC board.
YES
1. Check if the conductor pattern on the LGC board is short circuited or open circuited.
2. Replace the LGC board.
Oct 26, 2011 | Toshiba Office Equipment & Supplies
Error C 950
This is ciricuit related problem. It can be 1) Connection error between SYS board and LGC
board. 2) Engine-CPU abnormality 3) LGC board memory abnormality or 4)
Connection error between LGC board and DRVboard, ID abnormality
Feb 18, 2011 | Toshiba e-Studio 350 Copier
Error code "CA10"
Hi how are you this is jack .....(jack_pak@hotmail.com).. my personal ID.
Laser optical unit related service call
[CA10] Polygonal motor abnormality
Is the polygonal motor rotating?
NO 1. Check if the connector CN352 on the LGC board is disconnected.
2. Check if the harness is open-circuited or the connector pin is disconnected.
3. Check if the conductor pattern on the LGC board is short- or open-circuited.
4. Replace the laser optical unit.
5. Replace the LGC board.
YES
Is the printed image distorted?
YES 1. Check if the connector CN352 on the LGC board is almost disconnected.
2. Check if the harness is almost open-circuited or the connector pin is almost
disconnected.
4. Check if the laser unit cooling fan is stopped.
5. Check if the suction area of laser unit cooling fan is plugged up.
6. Replace the laser optical unit.
7. Replace the LGC board.
Thanks
Best Regards,
Aug 05, 2010 | Toshiba E-Studio 3511 Color Copier
Misfeed in copier error E200
Hi how are you this is jack my personal ID
Paper transport jam
[E200] Upper drawer transport jam (not reaching the registration sensor)
Open the jam access cover. Is there paper in front of the registration sensor?
YES Remove the paper.
NO
Is the registration sensor working? (Perform the input check:
NO 1. Check if the connector of the registration sensor is disconnected.
2. Check if the connector CN345 on the LGC board is disconnected.
3. Check if the connector pins are disconnected or the harnesses are open-circuited.
4. Check if the conductor pattern on the LGC board is short- or open-circuited.
5. Replace the registration sensor.
YES
Are the upper transport clutches (high/low speed) working?
NO 1. Check if the connectors of the upper transport clutches (high/low speed) are
disconnected.
2. Check if the connector CN362 on the LGC board is disconnected.
5. Replace the upper transport clutches (high/low speed).
YES
1. Check the condition of the feed roller, separation roller and pickup roller of each paper source, and
replace them if they are worn out.
2. Check the transport roller. Replace it if it is worn out.
Thanks
Best Regards,
CEE0
Hi how are you this is jack my personal ID..(jack_pak@hotmail.com)
Dear follow the procedure step by step.
[CEE0] Transfer belt position detection abnormality (Normal speed)
If the error [CEE0] has occurred, check the transfer belt home position sensor-1. If the error [CEE1]
has occurred, check the transfer belt home position sensor-2.
Is there any stain or scratch on the reflection tape inside the transfer belt?
YES Clean the transfer belt or replace it.
Replace the cleaning pad if it is excessively stained.
NO
Are the transfer belt home position sensors-1 and -2 stained?
YES Clean them.
NO
Are the transfer belt home position sensors-1 and -2 working properly?
NO 1. Check if the connectors or joint connectors of the transfer belt home position
sensors-1 and -2 are disconnected.
3. Check if the connector pins are disconnected or the wires of harnesses are opencircuited.
5. Replace the transfer belt home position sensor-1 and -2.
YES
1. Check if the conductor pattern on the LGC board is short- or open-circuited.
More information please mail me ...
Thanks
Best Regards,
Jun 18, 2010 | Toshiba E-Studio 3511 Color Copier
Error cea0
Hi how are you this is jack ..jack_pak@hotmail.com
Dear Your copier e-studio 281c
Please follow the procedure.
5
is disconnected.
2) Check if the connector CN331 on the LGC board is disconnected.
3) Check if the connector pins are disconnected or the wires of harnesses are
open circuited.
4) Check if the conductor pattern on the LGC board is short circuited or open
circuited.
5) Replace the revolver home position sensor.
6) Replace the LGC board.
YES
PLEASE VOTE ME
Thanks
Best Regards,
May 24, 2010 | Toshiba E-studio 281c Copier
Lcx-15ct (gps module not responding)
Before you give up on the LGC-12S you have now though, try plugging the LGC-12S right into the LCX-15CT without an extension cable. If the module not responding goes away...you just need a new extension (GPSX-25G p/n 99-46).
The power cable has a set of yellow, blue, orange, and bare data wires. If these wires short together, you can get the module not responding error.
If all that doesn't help...the LGC-12S is bad.
The LGC-12W p/n 112-06 will work with the LCX-15CT. You probably get this at many marine electronics dealers or go to lei-extras.com and buy it straight from Lowrance. They cost $229 so you might want to shop around putting that money into a whole new system altogether.
Make sure you have the latest software updates if you get the newer LGC-12W. These can be downloaded at http://www.lowrance.com/en/Downloads/Product-Software-Updates/
Let me know if you need more help.
Jul 10, 2009 | Lowrance LGC-12S GPS Receiver GPS Receiver
E3co e3eo toshiba 451c
E3C0 indicates LCF transport jam (not reaching the registration sensor).
YES-> Remove the paper.
NO->Is the registration sensor working? (Perform the input check: 03-[FAX]ON/[9]/[E])
If NO ,
1) Check if the connector of the registration sensor is disconnected.
2) Check if the connector CN338 on the LGC board is disconnected.
3) Check if the connector pins are disconnected or the harnesses are open
circuited.
circuited.
5) Replace the registration sensor.
If YES:
(Perform the output check: 03-439, 440)
Feb 10, 2009 | Toshiba E-Studio 3511 Color Copier
Lowrance LGC-2000 GPS Unit GPS Receiver Logo
51 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
