Question about Toshiba Satellite (K000004080) Motherboard
My technician said that my processor is not heating up and that's why it isn't giving any display. He said I would have to replace the motherboard and that's the only solution. So, my problem is that my laptop powers up but no display. I want a TOSHIBA SATELLITE A200-1CR's motherboard which isn't available here in Pakistan. So, if you can be of any help?
SOURCE: toshiba replacment motherboard
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp..GO HERE.RICHARDM69
Posted on Dec 29, 2008
  • 77 Answers
SOURCE: TOSHIBA MB ASSY: 1397B0014520
search ebay for the lowest prices or try google shopping it usually brings up quite a few. But if its the bios just fix it.
Posted on Jan 31, 2009
  • 22 Answers
SOURCE: Laptop and Coca-cola
Yikes!
I'm really sorry but I'd say your laptop is damaged beyond repair. To try and identify and replace every component that suffered damage would most likely exceed the price of buying a new laptop.
Probably not what you wanted to hear, but that's my two cents worth.
Regards, ~ redqew ~
Posted on Mar 12, 2009
parrotheadpc
  • 2600 Answers
SOURCE: Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported adapter.click on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
Posted on Sep 07, 2009
AZBen
  • 194 Answers
SOURCE: i have a toshiba satellite p305d-s8828 laptop and
Since you have measured the voltage on the motherboard I must presume you are saying there is no power "indicator light" on computer. If this is not the case please clarify. If the light is absent please test the battery as these laptops are not designed to work without a battery or with a dead battery. Operating without a battery can spike the motherboard or other components and cause failure due to overvoltage. If you do have a power indicator light then next observe whether the bootup is proceeding with a beep after the POST (power on self test) and whether you can hear the movement of the hard disk drive... possibly indicating failed LCD display or display drivers/setup. Press F8 after the POST beep to get to safe mode display drivers.
Posted on Oct 07, 2009
Laptop when turned on display on screen "fan
When the laptop or PC is used, its processor and RAM gets heated. To keep it cool, a fan is used which circulates the air in the board. If there is no cooling system in the laptop, its circuit could be damaged by over heating. I think the fan in your laptop has malfunctioned or it is jammed by something. Turn over your laptop and try see if there is anything stuck in the blades of the fan. If there is anything, then take it out and then try to start your laptop. If there is nothing, then there is high possibility that the fan has malfunctioned. It would be better if you take it to service centre to get it repaired. Hope this helps you!!
Aug 16, 2011 | IBM ThinkPad T43 Notebook
Motherboard problem - no image display when turn on
please fix the processor fan properly.
this may not allow the processor to start
Mar 28, 2008 | HP (5185-6477) Motherboard
My foxconn 45CMV series continous on beepin g and no display, what i have to do?
When a motherboard beeps, it's usually because the memory is defective and isn't being recognized, or the processor isn't seated properly.
I'd remove the memory and reinstall it, in case in became unseated.
May 04, 2011 | Foxconn 45CMX socket LGA775 motherboard...
Pc running but wont recognize screen I have tried other screens but same result ,replaced video card still nothing on screen what else should I do
remove your memory card and wipe it clean with a clean cloth and insert the memory in the slot dont forget to remove all the addon card ide or sata cable power to hard his and cd drive restart the computer see if the display is ok if not remove the processor fan and the processor clean it with clean cloth and fix the processor to the socket also clean the heat sink and apply a thin layer of heat sink solvent and fix the heat sink tightly to the socket if the display doesnt come change your processor which suits the socket
Dec 15, 2010 | ASUS P5GC-MX/1333 Motherboard
No display but power on ram ok cmos battery ok cpu fan and cpu ok
first check ur display cable for breakr if you have built in display disable it in bios and and if you have addon display card remove them insrert a new addon diplay card if you have display the display section in you motherboard is faulty or diplay add on card is faulty if it still dont work the clock and reset section in your motherboard is fulty to find the at the above section if you have a multimeter check the pci slot A15 means the pci pins facing the processor must have 5v if this is ok your motherboard is ok and the problem is with your display card
Oct 07, 2010 | Intel D845GVSR Motherboard
Lga motherboard no display, processor doesn't heat
if your processor does not heat up it's probably dead.. try running it without the fan and see if the heat sink still doesn't heat up
Sep 07, 2009 | ASUS P5V800-MX Motherboard
No display
After all your troubleshooting, I think this is likely to be as a result of your processor over-heating, maybe because of your environment, or because the fan is not cooling the processor properly again. Therefore my suggestion would be for you to unscrew your system (If you can do it by yourself), and try to clean, or better still replace your processor fan.
If you cant do it by yourself, you can easily get a technician to do it for you. This solution is actually if your processor is not yet burnt.
But if your processor is burnt, then you might have to change it to a new compatible one. but before changing it, try to test the motherboard with another working, compatible processor first, just to be more sure.
Then always make sure that your PC is in a well ventilated, cool environment and that the environment is free from dusts.
Hope this helps you out.
Jul 15, 2009 | Foxconn NF4K8AC-RS-1.0 Motherboard
Intel D865GBF motherboard in not giveing beep,display
if your motherboard does not give beep and display; remove your processor and ram and try working processor and ram on your motherboard, should there be no beep and display, your motherboard is dead.
Uzowuanya
e-mail:uzowuanya@yahoo.ca
Feb 15, 2008 | Intel D865GBF Motherboard
Motherboard display problem
o that is simple bro, see whats happening is that the processor was in the process of burning as a result it would create alot if heat constantly so sometimes it would start and sometimes it wouldn't, so what u can do is replace it with one with the same socket size and that should do the trick.....
Dec 06, 2007 | Intel D865GBF Motherboard
No display
replace your motherboard
Jan 27, 2007 | Gigabyte GA-8VD667 Motherboard
Toshiba Satellite (K000004080) Motherboard Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
