Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
The monitor with no picture
I first had the problem where the capacitors weren't changing and fixed it. It worked for a while until one of the capacitors broke. I replaced it again and now it seems like the whole picture doesn't come up. Instead it just shows a few lines for a second until it goes blank. The light on the bottom of the screen also just turns orange after a while showing that its not picking up a signal. I'm really stumped on what the problem is other than maybe it being a burnt out screen.
  • 3 Answers
There are few possible reason that the screen doesn't comes properly. You should check these things carefully 1. Make sure the capacitor chipset is good . 2. Soldering need to be perfect ( because if you put more than it needed then sometimes it make problems). 3. Check the LCD paper displaced or not.
Posted on May 28, 2008
FIX THE COLOR, IT HAS A GREEN TINT THAT DOESN'T GO AWAY WHEN TRYING TO ADJUST COLORS FOR DISPLAY DON'T KNOW WHAT CAUSED IT
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Jan 19, 2015 | Sony BRAVIA KDL-40EX523 40" LED TV...
Luxor 40 914 tvb
- Flickering screen
- Dim screen
- Slow start
Apr 13, 2014 | Televison & Video
I need to replace the fluorescent panel starter in my flat panel monitor
The problem is not with the Fluorescent Backlight of the Monitor, it's the Capacitor! Replace the Capacitor on the Power Circuit Board of the Monitor. The Capacitor will be slightly bulged! Use the same ratings of the dead Capacitor like it's Volts and Micro Farads. After adding the new Capacitors your Monitor works like new one. Enjoy!
Dec 27, 2012 | Computers & Internet
Flatron L1732-s monitor is stuck in power saving mode. How can i fix this?
If you have a blinking power light and no picture or no power at all then the issue is not power save mode, it is a failure of the filter capacitors on the power supply board. The model monitor uses the AIP-0108 power board and when the filter capacitors go out you get the flashing power light. Here is a link to so information showing which capacitors will need to be replaced to rebuild the power supply board and get the unit back up and running.
http://www.ccl-la.com/catalog/product_info.php?products_id=246
And here is a picture of the power supply board with the capacitors circled in yellow.
Dec 06, 2012 | Computers & Internet
Flashing green light and no picture. Resetting the power source and the connections won't work.
Open the monitor and find the power PCB. Look for blown capacitors. Replace all low voltage capacitors even if they look OK.
The power PCB is overloaded by shortage in these old capacitors.
If the monitor is not fixed now, replace two more capacitors - the big one, on 400V and a very small one on 50V in the high voltage circuit.
Aug 15, 2010 | Acer V173B 17 inch LCD Monitor
The monitor powers on when the computer is turned on I have a perfect picture but the OSD keeps flashing and none of the buttons will respond
I had similar problems with my Monitor. Then eventually the monitor quit working completely. It is probably your capacitors. The reason you are still getting picture is because they are going out one by one if that makes any sense. If you search online for how to change the capacitors in a flat panel monitor there are a ton a very detailed videos and help files on how to do this. If you can solder it is a very easy fix and cheap none the less.
Nov 06, 2009 | Westinghouse LCM-22w2 Television
My 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this monitor ? how can i fix this ?? ive confirmed 120v at power inlet and some dc voltage on various mini pins on...
Same problem as above. Had mine for 2.5 years and worked fine until I tried to turn it on this morning - won't come on at all. I have tried another power cable and verified that another monitor works on the old one.
Oct 03, 2009 | LG L1915S 19" LCD Monitor
Monitor Blinking
hello guys
I had the same problem. My LCD ViewSonic VX 924 has been blinking
For repar it i changed the following capacitors : 100uF/400v
330uF/25v and 330uF/35v
if that always flickers you can also change the two 470uF/25v capacitors
The link for a pic Alime and Capacitors
http://img25.imageshack.us/my.php?image=alimefsp0351pi01.jpg
DO NOT TOUCH NOTHING D'OTHERS ANS DISCONNECT ELECTRICITY CABLE BEFORE PROCEEDING
Apr 08, 2007 | ViewSonic VX924 19" LCD Monitor
E153FP Monitor screen goes black light is green
The capacitors are probably bad. It is a common problem and easily fixed by taking it apart and replacing the capacitors. Try to find Rubycon Capacitors because they very rarely go bad. Do a search on google for bad caps. I have fixed about 30 monitors this way. Dell is a company well known for bad capacitors. It may not be your problem but replacing the capacitors should cost less than $10 if you do it yourself. www.photphot.com
Oct 23, 2006 | Dell E153FP 15" LCD Monitor
Computers & Internet Logo
62 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
