Canon PIXMA IP4500 (printer) won't install properly. I followed all the correct steps up until it asks to perform a "Print Head Alignment", I click "EXCUTE" and it keeps saying the top cover is open, But its not? I don't understand whats going on :( Can anyone please help?
  • Crabsticks88 Jun 02, 2008
    Thank you for the reply. I found out that it did have a faulty cover sensor and swapped it out for another one back at the store. Printer works perfect :)
  • sunil_knd
    sunil_knd May 04, 2009
    how do you solve?
It may be because of the sensors. try to clean with sensors or maybe because the sensor wont reach its bottom, that is why the printer always recognizes that his cover were always open... try to push it hard..
Posted on May 28, 2008
Alignment on canon mp210 is off
You can try to do a power reset on the printer and if does the same, try to do a hardware reset. I found some steps on this site with specific error messages, How to reset Canon mp210. It has steps procedure you can follow.. :)
Aug 15, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error) What can I do?
Refer to Canon documentation
Five flashes: Print Head is not installed./ Print Head is defective
please check correct placement with your cartridge, maybe it's not installed properly
May 09, 2011 | Canon Pixma iP4500 InkJet Printer
Yellow light flashing saying replace cartridge that is flashing when I replace it the yellow light is still flashing
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Install the print head and ink tanks correctly iP4500
Reseat the Print Head and ink tanks iP4500
Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Jan 17, 2011 | Canon Pixma iP4500 InkJet Printer
Text and images in black are showing a partial double print and misalignment. What can I do? iP 4500 Printer about 6 months old.
the print head is not aligned. If you have your cd installer, run it again and install your printer driver. When installing make sure to turn off the printer and unplug the usb. during installation you will be asked to turn on your computer and connect the usb to your computer. After that the "Print Head Alignment" process. Load 2 sheets of paper on the printer and follow the steps on your screen. This process takes about 13 to 15 minutes, so do not try other operations other than this. After the alignment process continue with the installation. It will be easier if you have a user manual. If not try downloading on this link: http://safemanuals.com/414159.php?ID=228390&k=c1acdcca17513b4169fa0689567009cc&q=CANON%20PIXMA%20IP4500 ... input the 4 numbers on the box and click "Download The User Guide" button
May 17, 2010 | Canon Pixma iP4500 InkJet Printer
Even with brand new ink, my canon iP4500 won't work
A few basic causes.
1. The cartridges you bought iwere not proper HP ones and many "clone" cartridges are known to have problems with the ink level chips
Take them back and get them replaced with a different brand
2. They are original cartridges but may still be faulty (rare but possible)
3. Your print head is clogged or faulty
Run your printerthrough the head cleaning process a few times and see if it clears up.
4 your cartridges are out of alignment
run the cartridge alignment process
if this information was useful please click below
Aug 12, 2009 | Canon Pixma iP4500 InkJet Printer
A horizontal line appears on prints every 9/32 of an inch, especially on lighter prints
The following a step by step instructions for the printer issue:
Confirm the ink tank(s) are properly installed
Perform Print Head Cleaning - iP4500
If the prints are faint or streaks are printed, the print head nozzles may be clogged. Those phenomena can be improved by performing print head cleaning or print head deep cleaning. Also, you can check the cleaning results by printing the Nozzle Check Pattern after cleaning.
Remove tape from the ink tank and make sure the air hole is clear
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Aug 09, 2009 | Canon Pixma iP4500 InkJet Printer
My Canon iP4500 does not print with "black" cartridge
hi im josh in cebu phils. may i help you? Friend the problem is your cartridge and on the tank lever.it causes spoiled ink that stuck on it. To solve this problem. you may visit the Cannon Pixma support manual site and follow the steps there:here:
http://www.generalmanual.com/Printers/Canon-PIXMA-iP4500-Photo-Printer.htm
good luck friend hope i helped you.
Mar 14, 2009 | Canon Pixma iP4500 InkJet Printer
370 people viewed this question
jasbo
jasbo
