Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Washer will not drain or go into spin mode - Whirlpool LTE6234D Top Load Stacked Washer/Dryer
    Sergeant:
    Champion:
  • 351 Answers
Check lid switch
Posted on Oct 03, 2010
Washer stuck in drain and spin mode
Hello. I need the model number to help you accurately. When the unit drains, can you verify water *is* actually being pumped out? This is important because no washer will spin if it can't pump all the water out--modern electronic washers have to balance the load and water is an unknown, shifting quantity. I need the model number to assist you in initiating the diagnostic mode and explaining the possible error code(s) you might be getting. I hope I helped you!
Sep 15, 2015 | Kenmore Washing Machines
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
WASHER SPIN CYCLE WON'T WORK. IN ANY CHOSEN SPIN CYCLE MODE. FILLS , WASHES BUT WON'T SPIN OR DRAIN WATER.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag Neptune Washer MAH8700AWW will not spin. It will fill, drain, tumble ect but will not spin. i tried a quick spin test and it sounds like it is trying to drain after all the water drains. I went...
You may have tried this, but check the door switch, and the pressure switch(water level switch) to see if either could be bad. both of those affect whether the washer spins or not.
Jun 12, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Won't drain or spin
the timer may need to be replaced.. it might not be clicking on the spin cycle. try moving the dial manually to the spin mode.
Jul 30, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Will not drain or spin
you need to check your lid switch it could be bad
Jan 02, 2009 | Kenmore 15864/15862 Top Load Washer
GE wpse4200aoww washer won't stay in spin mode
Thanks for the question On a ge washer If you over load or the washer did not drain fast enough or over suds ing , when the washer starts to spin the forse of the spin will push water up the pressure switch hose causing the washer to start & stop spinning Thanks for the question THe appliance doc
Aug 23, 2008 | GE WHRE5260E Top Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
