Question about Home
MODEL V2094 RUNS INTERMITTENLY---RV BATHROOM EXHAUST FAN--- LOOKS LIKE THE MOTOR IS RIVETED ON.
    Champion:
  • 248 Answers
Usually you can drill out the rivets with an 1/8 inch drill bit and rerivet the motor back.you may have a loose wire or small short in wiring
Posted on Oct 06, 2010
Exhaust Fan does not work
Motors are divided into many categories. Most bathroom fans use a shaded pole motor (having a transformer on one side, a laminated yoke and 2 circles of copper shorting around the laminations to create a north and south pole) Another type is a compound wound motor (having brushes) A third type is an induction motor. the rotor of the motor is a series of laminations where a magnetic frequency in the stator windings induce magnetism in the rotor and they repel each other. A squirrel cage capacitor start induction run has a large capacitor on the side.
You can not mix and match what you want from one motor style to another motor style. If you have a brush type motor, perhaps the commutator needs cleaning and the commutator could be shorted with metal filings. The brushes may have failed and needs replacing. The bearings may have seized and the windings heated up blowing the thermal cutoff just under the tape of the windings. The windings may have burned through the varnish that coats the wires on the start winding (on motors with a centrifugal switch only) Centrifugal switches can fail to open or close. Only someone knowledgeable with motors can tell you what you have and what the problem is. It is far cheaper to replace a motor with a similar one on inexpensive devices such as a bathroom fan. A new fan may be cheaper than getting a new motor.
Nov 13, 2013 | Dryers
When Exhaust button pressed, vent fans not working, but microwave running for 30 seconds.
test the components and fix it. God bless you
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 24, 2013 | Frigidaire Microwave Ovens
Replacement Motor for Bathroom Exhaust Fan Need motor and blower assembly or just the motor for a Sears Roebuck Model 864.892 Motor is Universal Electric Co Model 118JF5 S/N 1T26714
Not sure what you are asking, but you can get a replacement directly from Sears. It is okay to replace just the motor, but be sure the fan blades are completely cleaned. When you are all done, verify good air flow outside of the building.
Sep 19, 2010 | Home
How to replace a motor on a nutone model 8663P bathroom exhaust fan
The motor assembly is held in place with tabs and possibly one screw. Remove the light assembly and once you get to the fan itself, unplug it, and push the side of the unit outward to release the tabs. You push the fan assembly up while pushing out on the side. If you look closely you can see the slots where the tabs go. There may or may not be a screw holding it in place. After you release one side, then rotate the fan assembly down and out.
http://coastaltechsupply.com/Direct%20Order%20Pages/Nutone%20Direct%20Orders/Fans/8663P.htm
Jun 06, 2010 | Home
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Bathroom exhaust fan 16 years old and noisy. How to fix?
One drop of 30 wt oil at each bearing will quiet the thing for a while, but you will eventually want to replace it. Also consider the whole fan is about the same cost as the motor, and easier to find.
May 16, 2009 | Broan-NuTone N-671R Exhaust Fan Exhaust...
The Fan in my Nutone bathroom light/fan is not working...
It is really easy to change the motor yourself. It is about a 15 minute job. You just need to find your model number and then you can buy the complete motor assembly. https://www.centralvacuumstores.com/model_number_help.php
Mar 28, 2009 | Broan-NuTone N-8663RP Combination Light...
Motor for bathroom exhaust fan
same problem but l thing l solved it by ordering a new replacement from globalindustrial.com if you need more help email me at hugo698@aol.com
Mar 01, 2009 | Marley PJ1257 Heater
Bathroom Ventilation Fan Motor Failures
I'm guessing that water isn't splashing up on this fan's motor, so the moisture that is causing the rust must be water vapor. The exact same water vapor that the fan is supposed to be removing. I have two suggestions before replacing the entire fan. One is to make sure that the ducting that carries the moist air out of the bathroom (and preferably out of the house altogether) is free of obstructions and that the fan can actually do it's job. Second is to actually run the fan, and run it a lot longer than you probably are right now. If it is running while you are in the shower and then you turn it off after you leave the bathroom, it can't possibly be removing that moisture. I'd invest in a countdown type timer and replace the existing switch with that. Set that thing for 30 or 60 minutes when you get in the shower and let it turn it off automatically.
Jan 28, 2009 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Noisey 8 x8 Broan Bathroom Exhaust Fan (With Light) (7 years old)
Mine was doing the same thing. I found it was coated with dust.
I took the blower out [unplugged it, and removed the single screw holding it to the box], took the face plate off [removed 4 or five screws] brushed the squirrel-cage fan blades using a narrow, long and stiff bristled brush, and reassembled it [used care to align the small plastic axle on the flap valve ] and reinstalled it. The vibration was greatly lessened and the fan was about as quiet as it had ever been.
Dec 23, 2008 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Home Logo
87 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
