Question about Intel Motherboard
Hanging after booting
The machine keep hanging each time you boot up the system, you might be working at times and it will just start hanging
  • Jamiell Joseph May 11, 2010
    what do you mean by it hangs?
Try running a diagnostic on the hard drive if it has come with one, or try to update the BIOS to make sure that the fan attached to the computer is running at the correct speed. Also try to disable some of the startup applications at startup using MSCONFIG command. Make sure that you do not disable any windows service.
Posted on Aug 21, 2008
  • 1,031 Answers
Whats the type of RAM in your system? DDR, SDRAM, etc are they the same speeds (ie DDR400 PC3200)? you know RAM runs better when in pairs and the same speed That could be your problem.
but You may get it to work from the BIOS settings by making sure all the RAM values are set to auto.
also verify from your manual. at times thre is a list of "prohibited" ways of filling RAM slots.
Your best bet would to get an identical piece and pair them just . That would probably work, although the mb would probably downshift the speed on the RAM .most DDR motherboard's are work best when all the RAM is identical
Posted on May 27, 2008
Hanging is just a minor problem of any pc. It just means that the system is hot. Just open up the system unit and make sure that the cpu, system and power pack fans are working. Also clean the system because of dust.
Hi, The situation is My system INTEL PENTIUM
Do you have any extra things plugged into the usb ports? (external hard drive,Ipod,Flash drive) anything like that can sometimes cause pc's to hang at boot they will try to boot to that device instead of your hard drive
Mar 07, 2011 | Dell Inspiron Desktop / Intel Pentium...
My acer travelmate 2420 is not booting. i just loaded pics from camera to print, it hang and now everytime i boot windows just keeps restarting over and over. what do i do?
Press F8 during boot this will take you to boot options select "Last Known Good Configuration" or select Safe Mode to perform a system repair.
To repair your system follow the steps below
1. Click Start and open Run on the Start menu.
2. Type (or copy and paste) C:\WINDOWS\system32\restore\rstrui.exe in the Run box.
3. This will open System Restore now select the first option (restore my computer to an earlier time) and click next.
4. Select a date when your network last worked and complete restoration.
Do not worry about selecting the wrong date you can always undo any restore within system restore you will select undo last restore.
Jan 30, 2010 | Acer TravelMate 270XV Notebook
Laptop sometimes take long to boot, cursor hangs after booting
well if u use internet on your laptop,i wold sujjst you to keep deleteing cookies from the internet web page,from tools,again perform this step
click start>all programs>accessories>system tools>disk clean up/disk defragmentation.....it shoud work for u.....
Aug 25, 2009 | HP Compaq nc6220 Notebook
My notebook Hangs Randomly...plz devote yr 5 min to assist me
hi
click on to start go to run and in run type in msconfig once u do that it will give you an option for system configuration utility.
click on to the services tab on top and then on the bottom click on to hide all microsoft services and then check that what all unwanted services are running uncheck the unwanted serivices and then apply it and restart the computer check that wether is works or not ,if it doesnot work mark me an email with your phone number so that i can call you and can troubleshoot on your computer my email address is ullekhtandon@gmail.com
Jul 09, 2009 | Computers & Internet
G620 boot problem
When you power up press F8 key then ente rin enable vga mdoe.
Then go to contro lpanel and then open dispaly property then change screen resolution to 1024*768 then apply and ok.
Then restart it.
Jun 23, 2009 | Computers & Internet
G620 boot problem
after ur long question the problem is the faulty RAM ... ur RAM is causing all this remove and replace your RAM . ur problem will get solved..
Jun 23, 2009 | E-Machines (308714) Motherboard
The recovery on my Toashiba Satellite A130/A135 doesn't work
Try to boot the machine in safe mode by pressing F8 as the computer starts up, if will let you boot into safe mode as it sounds like there could be some bad sectors on the drive causing it to hang on boot.
To check this right click on the C drive and select "properties", then select "tools" tab, in the tools option check the volume for errors.
This can take some time to perform so please be patient.
If you can't get the machine to boot into safe mode please post back
Jun 22, 2009 | Toshiba Satellite A130 A135 Notebook
About my Compaq Evo N800v Notebook PC laptop screen problem
My laptop is not working in the proper manner.Because for the screen the belt is may be some loose contact.some times the screen is shaking at the time of booting and immediately hanged.Then system is not working.Some times if we press upon the screen then it will work in good manner.If we remove the pressing hand,immediately the screen shakes and hanged the contents immediately.
Apr 06, 2009 | Compaq Evo N800v Notebook
Intel Dual Core 2.0 GHz Sytem hangs after boot
During your boot screen press the F8 key to boot into safe mode. If that gets you to the desktop run virus/spyware scans. Reply with any results.
Jan 12, 2009 | Bravo Intel Dual Core E2180-2.0GHz 2GB RAM...
PC is hang up about 5 mins after boot up.
heat sink problem or
ram problem
re assemble the system
Oct 26, 2007 | Acer Aspire™ T180 PC Desktop
Intel Motherboard Logo
64 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
