Question about Ovens
I have a Whirlpool Accubake double oven Model # GBD307PRB01. The panel display has just gone out. When I try to enter a command, such as to turn on the oven, I get one short beep, one long beep and three short beeps. As the display is out, I don't know what code this is. I'd like to get a description of this fault code, telling me if I need to replace the display or one of the boards. Also, I'd like to know if I have to pull the entire unit out of the wall (fully or partially) to disconnect the display. I've got the trim pieces off (covering the mounting screws on the sides of the oven front). Also, FYI, I have already turned off the breaker and let it sit for 5 mins, and then powered back on the unit. There was no change in the display
  • 2 more comments
  • prelosky Oct 03, 2010
    This is just what I needed to know. Thanks very much for your help
    thanks for the assistance. This is just the info I was looking for. I only wish Whirlpool was this helpful
  • prelosky Nov 16, 2010
    Of course the oven all of a sudden started working normally. i didn't want to change out the part until the problem re-appeared, which it finally did yesterday. i changed out the control board (Part # 6 on the diagram. ) The display is still dark and the oven is acting the same. Do you think it is the Control ***'y or the touchpad?.
    President:
  • 2,777 Answers
This is indicative of the control board failing on your unit, not the display itself. The unit can be found here and I will include a page that shows where it goes as well, you shouldn't need to pull it out too far to get to it.
Here is the part:
http://www.appliancepartspros.com/part_details.aspx?part_id=3598617&image=1
# 6 on this schematic:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133827&diagram_id=930365#d930365
Thanks Tim
Posted on Oct 03, 2010
  • BrokeOvenGuy Nov 30, 2010
    I had the same exact problem and let me tell you, it is not the control board. I bought a new one and replaced it and the problem persists. So unfortunately, I can't give you the solution but I can tell you it isn't the above suggestion...
E6 F2 Fault Code on left side Display panel of Whirlpool Accubake Upper oven. There is No Cancel Button on the Display Key pad. Double oven unit has just been cutting off in middle of Bake Cycle.
this is usually a problem with the keypad, most techs would say to replace the keypad, if that doesnt solve it, the main board will need to be replaced. make sure your connectors are tight if you decide to kill power and replace the keypad
Dec 20, 2016 | Whirlpool Ovens
I hav whirlpool accubake.oven wont stay lit.it ignites then flame goes right back out
Whirlpool oven won't light - Appliance Repair Forum
forum.appliancepartspros.com/oven.../225907-whirlpool-oven-wont-lig...
May 19, 2011 - 10 posts - ‎2 authors
I have a Whirlpool Accubake oven (SF362LXSS0) that doesn't seem to be consistently turning on, and the problem's getting worse. ... If I try to turn it on to bake, I hear several clicks, but not that "gas oven turning on" sound and no heat comes out (but a slight smell of gas is ... Whirlpool Gas Oven won't stay lit
1 post
Oct 25, 2012
whirlpool oven won't stay on
1 post
Aug 13, 2012
Whirlpool Gas Oven Will Not Stay Lit
Jun 20, 2012
whirlpool accubake oven will not stay lit
1 post
Nov 9, 2009
More results from forum.appliancepartspros.com
Whirlpool Accubake Model # GW395LEGQ4 - Oven won't Start ...
Dec 12, 2015 | Stoves Ovens
Whirlpool Gold Double Wall Oven will not heat
check the heating element for opening or cracks
Mar 17, 2014 | Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank then beeped. The oven does not turn on but when I tried to turn it on just to test it, it beeped once and then three short beeps. I have...
Hello Diana,
Their are a few things that should be checked. I know its going to be tough to check on a built in double wall oven but one thing that needs to be checked is if their is 240 volts ac entering the oven(i know the breaker is ok) but the connection at the back of the oven can burn,then the proper voltage wont enter the oven.
Another thing is a high limit thermostat thats inside of the control panel,need to checkif it has blown.
Last thing i can think to check is if 120 volts is at the clock, if not 120vac that explains the blank display
Aug 20, 2011 | Whirlpool GBD307PDS Electric Double Oven
Whirpool Accubake Control Panel
try turning power off and wait 10mins and see if it resets.
Sep 14, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
Jun 15, 2008 | Ovens
"loc" display
This just happened to me. I have whirlpool double oven accubake. The display went blank and i had to turn the breaker off. I left it off for several hours. When I turned the breaker back on my oven display read "Loc" in big letters to the right of the time. I held the start button down for 5 secs. The display went away and the oven started to work as if nothing had happened. I hope that is stays that way.
Dec 08, 2007 | Whirlpool Ovens
Ovens Logo
372 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
