What cause errer 000 canon np7161.when lit, it is E000 and it goes off after a few seconds.
  • 1,326 Answers
A error code of E000 means that the fuser unit is not turning "ON" or is not warming up correctly. You will need to fix the problem before you can reset it. You may have a blown fuser lamp or thirmister or thermal fuse or all three? Good Luck
Posted on Oct 04, 2010
How to reset error E000-000 for Canon ir2202
To help you understand and troubleshoot the error E000-000 for Canon ir2202 printer, please follow step-by-step instructions given below:
This error occurs due to high temperature readings on the printer. Occasionally, the fuser will run too hot. First thing is to perform factory reset on your canon printer but if it still show error code E000-000 again, then try to reset it in Service Mode. To do these, follow the steps below:
- Press ADDITIONAL FUNCTIONS, #
- Go to #7 Printer and Press OK.
- Go to #4 Printer Reset and Press OK.
- Yes = ( * )
- Power cycle unit.
Now check it the error is resolved. If issue persists, please try definitive reset. To do these, follow the steps below:
- Press Additional Functions key.
- Press #
- Press > to #7 Printer Function.
- Press Set.
- Press > to #4 Printer Reset.
- Press Set.
- Press <
Now restart the printer and check if it resolves the error. If issue persists, it is recommended to contact Cannon Support Center from the link given below:
https://www.usa.canon.com/internet/portal/us/home/contactus
GuruAid.com
Jun 14, 2016 | Canon Office Equipment & Supplies
CANON NP7161 WHAT IS THE PROBLEM OF ERROR CODE E71
Could be the following mate:
1- TD Sheet worn / Paper detect sensors and plates dusty.
2- Transfer driver pcb u/s - FG6-2579
3- Transfer cleaner motor M8 overloaded. Shafts dirty and causes load.
4- Transfer drawer connector - FG6-0948. (This is probably the cause!)
5- Fuse blown on Dc psu.
Also you can download a service manual for canon np7161 from below link:
http://goo.gl/IyMrd5
it will help you on disassembly or other stuff
Hope this helps!!
Dec 02, 2014 | Canon Office Equipment & Supplies
Canon e000 0000
Usually zeros means problems with fixing unit
Aug 11, 2014 | Canon imageCLASS Office Equipment &...
How can clear error e000 from my canon pc980 copier
Error 000-means an Error caused trough an ruined fixing unit. You have to Change the unit, the Mainboard or bring to a Repair Center, I am afraid...
Dec 22, 2010 | Canon PC-860 Black and White Copier
Canon D880 reads system error e000. How do I fix
Hello, sir. E001 is a high temp. error. My first advice would be to atempt to clear it in service mode:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 Printer and press OK
  3. Go to #4 Printer Reset and press OK
  4. Yes = ( * )
  5. Power cycle unit.
If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistors. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area. However, on this one, I would recomend replacing Fix Assy. as a whole if you can, FG6-8326-000 (for s/n starting with MQT/MQV/MRV/MRW) or FG6-8325-000 (for all other s/n). Don't see p/n for Thermistors. Also, heard of alot of other board and p/s issues with this model that can cause E001-E004 errors. See if you can clear it first. Good luck. Let me know how you make out.
Oct 12, 2009 | Canon imageCLASS D860 All-In-One Laser...
Canon IR 3030 error code 000 002-0000
This code is for the fixing area. I have found that most times it is the lower pressure roller bearings that have seized up and need to be replaced. it could also be the main thermistor has a problem, it would have to be replaced or cleaned ( try cleaning first). on the rare occasion a retaining clip has broken and had jammed the upper roller. The best thing would be to check everything in the fixing area. it is under the yellow cover that gets very hot.
Feb 23, 2009 | Canon imageRUNNER C3200 Copier
System error E000
E000 is a high temp. error. My first advice would be to atempt to clear it in service mode:
  4. Yes = ( * )
May 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Cannon np7161
go to servce mode by just press additional function key than 2& 8 no. key together than again additional function key. than by pressin light and dark button go to clear all option than press (A) in light dark button. now switch off your machine than on.
May 16, 2008 | Office Equipment & Supplies
164 people viewed this question
k24674
jasbo
jasbo
