Question about HP Touchsmart IQ524 PC Desktop
It is stuck on the start-up i don't have a
It is stuck on the start-up i don't have a recovery disc when i turn it on, it is stuck on the hp logo screen. when i press esc, or f10 or any other option, it doesnt go to it, it stays at the logo screen
  • 50 Answers
SOURCE: Blue screen when starting up
Resolving the blank screen issue Follow the instructions below in order to fix this issue: 1. Remove any CDs, DVDs or memory cards from the computer. 2. Disconnect all devices from the computer leaving only the original mouse, monitor and keyboard and power cord connected. 3. Restart the PC. 4. Press the F1 key repeatedly during the first startup screen until the entering setup message appears. 5. Press the F5 key to restore the default settings. Use the arrow keys to select YES and press ENTER. 6. Press the F10 key to save the changes and exit. Use the arrow keys to select YES and press ENTER. The PC restarts. 7. When the system restarts select Last Known Configuration from the boot menu. The PC should now startup normally. If the blank screen persists continue with the following steps. 8. Select Safe Mode from the Windows Advanced Options Menu. 9. Use Microsoft's System Restore feature to restore your computer to an earlier time and correct the issue. If the blank screen persists or it is not possible to enter Safe Mode perform a system recovery Perform system recovery by visiting the given link for the steps. http://tinyurl.com/2hsjug To let you know I got this information from one of the geeks from ***
Posted on Jan 23, 2007
  • 166 Answers
SOURCE: i have a pavilion m7480n. didn't have the recovery
if you just want to back up your data you can actually borrow a friend computer and hook your harddrive
to his computer and get your files.or you can burn a live cd of linux and get the data that way.depending
on your operating system you should be able to get everything back.then you reload the machine with
any windows installation and use the cd key that was on the side of your comp.
for the recovery disk,it sounds like you registry is to corrupted or it is not compatible with your comp.it is
just easier to reload your machine
Posted on Jun 28, 2009
  • 12 Answers
SOURCE: I have a HP Touchsmart IQ500 that is a little
This might be an issue with the Hard drive or the operating system installed on the hard drive.
Try to access BIOS screen tapping on F10 on restart.
If you are able to access Bios try to run the Short smart self test on the Hard drive.
To run the test follow the steps as follows:
on the main window you will see 1 st drive 2nd drive 3rd drive 4th drive.
besides these drive letters you will find your Hard drive listed.
Highlight that and press enter.
on the next screen highlight Smart support and press enter.
on the next screen select Short smart self test and run the test.
If it gives an error code that means the hard drive has gone bad.
2)If not then come back on the main page by clicking on ESC button till you come back to the main page.then Press F5 select yes to load set up defaults and press enter.Press F10 once to save configuration changes and press enter.
It will boot to windows.
3)Still if you face the same issue then you need to perform the recovery using the recovery cds.
4)If you don't have the recovery cds then you can contact HP support and order the cds and perform the recovery.
This should resolve your issue.
Thanks.
Posted on Aug 21, 2010
shibuda
  • 1812 Answers
SOURCE: HP505N. Kids messed with computer and it shut
pres f 9 to choice boot menu. Or go F 10>go bios for set boot piority>and F 10> yes enter.if not work please re install xp .and create partion again ,because your kids can be delete the partion file (ntldr/boot.ini).
Posted on Nov 21, 2010
Factory reset an HP 255 windows pro 8.1 laptop
To launch the HP Recovery Manager, do any of the following
Click Start , type recovery in the search field, and select HP Recovery Manager to run recovery from the D drive.
Turn on power and press F11 key to run recovery without booting onto Windows (on some models esc key and then F11 key ).
Insert user-created Recovery disc in disc drive and turn on power to boot from the DVD disc.
Dec 19, 2014 | HP Computers & Internet
I dont have the password for my hp laptop, how do i factory reset without password?
To reset password for your hp laptop you can try bootable HP System Recovery Disc to do factory reset without password. If you don't have system recovery disc then you can use Stellar Phoenix password recovery software to reset password. Once you are able to login with new password then you can easily factory reset your laptop.
Nov 02, 2012 | Computers & Internet
Reinstall recovery
Make sure to download NIC drivers and save to pen drive or disc. Check HP site. Then you can install any OS if you don't have the recovery disc. Companies usually don't offer full downloads of recovery software.
Aug 26, 2012 | HP Computers & Internet
CANT RESTORE MY COMPUTER
It is asking for the recovery discs that should have been made in the event there was a problem with the recovery sector on drive D or the hard drive failed. The only option is go to www.hp.com contact customer support and the technical department to see if they can sell you the much needed discs.
May 08, 2012 | HP Pavilion a420n PC Desktop
Hp omnibook xe3 needs factory restore
You will need the recovery discs to do this. If you don't have them check this auction: http://www.cqout.com/item.asp?id=10419346
The reason the recovery disc is the best option is that it will have all the drivers for the machine included.
Before you start recovery, make sure you can read your COA licence on the bottom of the machine.
You can still do a factory restore without recovery CD but you will need a copy of your operating system on disc, the licence key (COA) and prefferably, all of the system drivers copied to CD or stored on USB drive, these will be available on the HP support website.
Mar 14, 2012 | HP Computers & Internet
Hard disk error no recovery disc
@lizegim
HP laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the F10 key. After you press the power button, you need to simultaneously press the F10 key to start system recovery. If this one won't work and gave you like an "I/O Error" or "Error 0x000000E" or something similar then that means that the HDD is already defective and needs replacement and you need to order the recovery discs from HP at 1-800-474-6836. If you're still under warranty, they'll replace the HDD and give the Recovery Discs to you for free.
Good luck.
Sep 06, 2011 | HP Pavilion A250n (DF253A#ABA) PC Desktop
I want to know how to restore my hp mini 1000-1151 back to factory settings if the computer doesnt turn on
@ customersvcs
HP laptops have a built-in recovery mode on the system wherein you don't need to use a disc to restore it to factory default. The hotkey for the recovery is the F10 key. After you press the power button, you need to simultaneously press the F10 key to start system recovery. If this one won't work for you, you need to order the recovery discs from HP at 1-800-474-6836 (you need to have an external dvd reader to load the discs). If you're still under warranty, they'll give it to you for free.
Cheers
Sep 03, 2011 | HP Mini 1000 Netbook
I did not get a manual when I purchased my computer. I should not have to pay to get one. Model # p6716f
You don't have to pay, you can download it online. Most computer makers need to save money, and they do so by NOT including paper manuals that most people put on a shelf and never open. Many don't even include recovery discs, you'll have to use some backup software to make your own recovery discs. http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=5051498&
Jul 26, 2011 | Computers & Internet
My toshiba a205 s4607 is stuck at the welcome screen.. i tried pressing f12 but nothing happens. when i press f2 it just says please wait and never works. i dont know whats wrong. i want to reformat it but...
I don't think it is your hard drive but here is what you could do:
Press F8 at start up to enter start options, choose safe mode with networking or last known good configuration.
Use the built in system recovery, press F11 or F12 at start up to enter recovery partition.
Use a set of recovery disc to do a system repair or to install new original operating system.
Order the recovery disc set from the website by model and serial number.
PCHELPSTER007 from youtube
Jun 25, 2011 | Toshiba Satellite A205-S4607 Notebook PC
My pc is lock .my dauther try to many password
Some times the CAPS Lock key may be on, so please make sure that the CAPS Lock key is off.
If the issue still exists, I request you to perform the full system recovery using the recovery disks. To perform this full system recovery, you can use the recovery disks that you have created using the recovery partition.
Use the recovery discs to restore the PC by following the steps below:
1. Insert the recovery disc in the optical disc drive and start the computer.
If the computer is running, insert the recovery disc and immediately click Start and select Restart to force the computer to start from the recovery disc.
2. When prompted, Press any key to boot from CD or DVD, press any key on the keyboard.
3. Allow the recovery disc to start and load the required files while the Microsoft loading screen is displayed. It may take several minutes to load the required files.
4. When the HP Recovery Manager window displays, click Advanced options , System recovery , and then click Next to open the Recovery Manager.
5. Follow the on-screen instructions and perform the required actions.
NOTE: Do not interrupt the recovery process even though the computer may restart and the Windows desktop may display at various times.
· When prompted, follow the on-screen instructions to Backup the user files.
After performing the backup, when prompted, re-insert the recovery disc, and then click Next to continue the recovery process.
· A status box is displayed to indicate the status of the recovery and the estimated time remaining.
· If you used multiple discs when you created the personalized recovery discs, follow the prompts to remove the first disc and insert any requested discs.
6. When prompted to Insert the Supplemental driver disc , take one of the following actions:
· If you purchased a replacement recovery disc from HP, and it included a Supplemental driver disc, insert the disc and click OK or Next . The recovery program checks the supplemental disc and installs the specific needed files.
After the Supplemental files are installed, a prompt is displayed to remove the Supplemental disc and insert the original recovery disc.
· If you purchased a replacement recovery disc from HP, and it did not include a Supplemental driver disc, click Skip or Cancel . The recovery program will ignore the request and install the next file on the recovery disc.
· If you created a personal recovery disc, press Next to continue.
7. Continue following the on-screen instructions to complete the recovery process.
NOTE: If you have not created a personal recovery disc, or the recovery disc fails or become corrupted, see HP Notebook PCs - Order Recovery Discs for Vista as your notebook is preinstalled with Genuine Windows Vista Home Premium with Service Pack 1.
For detailed steps you can refer the provided web link:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00809678&product=18703
NOTE: Clicking the above link may give an error indicating that it is invalid. If this occurs, copy the link and paste it on the address bar in your browser until the complete address is displayed in the Address box.
If you do not have the recovery disks you can order these recovery disks from the local HP phone support. Please use the provided phone number to contact the local HP phone support.
Phone number: 800-474-6836
May 29, 2010 | HP Pavilion dv6000z Notebook
HP Touchsmart IQ524  PC Desktop Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
