Question about Kenmore 17459 Free-standing Dishwasher
Code e4 - Kenmore 17459 Free-standing Dishwasher
  • 5 more comments
  • tranquil105 Oct 03, 2010
    my kenmore model number is 46117352 free standing
    Code message for my kenmore dishwasher m # 46117352 is e4 how do i reset it or clear up the overflow sensor problem
    how do i clear the e4 problem
    What is the e4 code and how do i fix it
    Is this some thing I can do my self
    Can i fix this my self
    How can i corect the e4 code on my kenmore freestanding dish washer
  • 10,865 Answers
Hello. The e4 error code indicates that the dishwasher had water from the previous load still in it when a new load was begun. push the drain button and let all of the water drain out and then start again. J..
Posted on Oct 04, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the model no# of your Dishwasher and also elaborate so that I can further assist you.
Thanks
Rylee
Posted on Oct 03, 2010
  • Rylee Smith
    Rylee Smith Oct 03, 2010
    This issue is caused because of water-inlet valve going bad. This valve
    is usually at the bottom left or right of the dishwasher, behind the lower
    access panel. It's the device with the main water line from the house, a rubber
    tube to the dishwasher, and two wires attached to it. If the water-inlet valve
    is defective, you need to completely replace it.
    Please accept the solution if
    the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    This issue is caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Oct 04, 2010
    If you know about dishwasher and if you are technically enabled then you can do this yourself else get this done by a professional.
  • Kenmore Master
  • 3,051 Answers
Hello there:
The best way i can describe this error is as follows
Water that may leaks from anywhere inside the machine will go to the lowest area in the machine and down under the wash zone and into the area where all the workings of the machine are located.
A sensor that is located there consists of a float operated switch that detects this water that makes the machine empty itself out and thus giving the e4 code.
turn off power... at very bottom of appliance (behind kicker board if it is intergrated ) you will see 2 brown plates on the front . remove them and you will be able to see into the unit there will be puddle of water ? soak up this water with a sponge and dry the area best u can then set your appliance on usual setting and all should work properly.
ERROR CODE E4 ?
Go to utube https://www.youtube.com
and type in your brand of printer / copier and ask after that how to fix error code E4 .
Example : how to fix error code E4 on a HP model 2400
Aug 12, 2014 | Office Equipment & Supplies
Pioneer a/c E4 error code
review your manual about E4 code,you can fix it yourself.if not,ask for the assistance of customer service of that said brand
Apr 17, 2014 | Heating & Cooling
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Dec 13, 2013 | Simmons Beautyrest Microfleece Electric...
CODE E4 ELECTROLUX EWT64S FULLY AUTOMATIC WASHING MACHINE
In my experience, E4 is appear when spin is starting. Then I check the 'magnetic door safety switch' and gotcha, I find the problem --> 'magnetic door safety switch' is damage (always open). Because some reason, I am short-circuit it. Fixed.
Oct 11, 2012 | Washing Machines
We got this panasonic fp-7718 for free and have tried to get it to copie but the e4 code keeps and i have no idea how to reset this code or any of the other codes.
There will be more to it than just E4..........it will say E4-01, E4-10,11, OR 12.
If its e4-01...that means the machine is not warming up and may have a problem with the Fuser unit.
If its E4-10,11 or 12 it relates to a problem with a Fan motor.
Thats the best I can do given the information you have provided.
Feb 26, 2011 | Office Equipment & Supplies
Error code E4 is on our display of our KDW243A dishwasher - what does this mean please?
Error code E4 means there is an overflow. Water is probably trapped. If you get error code E4, just tilt the machine back about 45 degrees and let the water drain out. It should come out on both sides. Then, you should be good to go.
Dec 14, 2010 | Kenwood Dishwashers
Error code Df and e4
E4 Outdoor activation of low pressure switch/ less suction pressure.
Check back pressure, which should be 60 PSI when ambient temp 98 degree.If not Short of gas- find leak and arrest. And do gas charging. Even due to indoor coil dust blocked also e4 arise. Clean the coil and reset it.
Nov 25, 2010 | Napoleon NHPS12 Air Conditioner
E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Jul 12, 2009 | GE APH10AA Air Conditioner
Error code E4 for riso ks800
riso ks 800 error code c-7
Dec 06, 2008 | Riso RZ390 Duplicator
E4 Error
york hvac unit e4 error code Troubleshooting
Aug 05, 2008 | DeLonghi CF210 Portable Air Conditioner
Kenmore 17459 Free-standing Dishwasher Logo
111 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
