Question about LG WM-2277HW Front Load Washer
Code CE pops up and won't continue cycle. What needs to be fixed?
  • LG Master
  • 3,051 Answers
Hello there:
CE Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited.
further more
If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Posted on Oct 03, 2010
My Samsung dishwasher is blinki g with error code CE how can i fix it ,need help plz
That's a water temperature error. Try running the sink until the water is hot before you start the dishwasher..check the heater element for continuity and the thermister
Aug 29, 2016 | Samsung Dishwashers
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Flashing CE CODE
try to clear error code
Aug 20, 2017 | Hayward Pool & Spa
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
see this causes and fix it. God bless you
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the washer won't start the line fuse might have blown.
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Have a ce-3700 raized keyboard the till resets and can set date and time but the departments won't work one needs to open the department so that ne can work the till how
If you have performed a RAM (MAC) clear, then the departments should work as soon as the MAC code has been set. Make sure you aren't using a decimal point for prices. -----------------------------------------------------------
If anyone needs more information,
The Casio CE-3700 User and Programming manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_operators_and_programming_manual.html
The Casio CE-3700 Service (repair) manual is here: http://the-checkout-tech.com/manuals/cashregisters/Casio_CE-3700_and_CE-3750_service_manual.html
Aug 30, 2011 | Casio Parts Cash Register PC Desktop
I have a kenmore washer model #110 won't stop cycling and continuing to do next unwished operation. do i need to change whole timer or can it be fixed?
Is it a Kenmore Oasis? If so it could be a computer board problem. Depending on the code it may be covered by whirlpool through Sears. Whirlpool made the Oasis.
May 06, 2011 | Washing Machines
Not starting
when you start the cycle and does it beep once and then show "CE" .. There is a communication error between the machine control and motor control.
There may be some Conformal coating on serial communications pins between the machine controller and motor controller.
Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection. Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur. maybe the Drive motor thermal protector has opened.
Aug 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Need new codes for eurovoxmax need new codes dublin
codes for eurovox 5a01 6/5/09 aa b7 d1 d9 ce 8e 83 af a1 38 06 29 24 29 8d 2b should work ok bristol area
Jan 02, 2009 | Televison & Video
Error codes
Usally this is a bad control board or in some cases, a bad display board. they are fairly easy to replace and should be covered under a 5 year parts warranty (no labor). if its older than 5 years i would advise getting rid of it before putting any real money into it as Eurotechs are affectionatly know as Eurotrash in the industry and it WILL give you more problems. If you need a short dishwasher to fit under some shorter than standard counters, go with an ASKO. They are made by the same parent company, but are 50 times better. Good luck!
May 26, 2007 | EuroTech 24 in. EDW194E Built-in...
LG WM-2277HW Front Load Washer Logo
395 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
