DVD tray won't open
I have an omnitech DVD player - brand new, first time using it - the tray won't open to put the disk in - any thoughts? Thanks.
Jean
Look for a small pin hole in the front of the DVD player. Insert a pin into the hole to open the tray.
Also try right clicking the DVD icon, click 'eject', then insert the pin into the hole.
If the door only opens partially, grab it and pull it open. Then insert a blank DVD into the tray, then see if the tray will open automatically with the disk in the tray. If so, then keep a DVD in the tray at all times.
Posted on Oct 06, 2008
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
A disk is stuck in my blu ray player. I try to open the tray it says opening, then closing then loading, but then says no disk in player. I cannot open the tray at all and the disk icon doesn't show up...
Good day!!!
The problem could be on the DVD player and the lens of it.Please follow the D.I.Y procedures bellow:.
  1. Open the cover of your DVD by unscrewing it.
  2. Clean the DVD lens using CD cleaner.
  3. Try to use other new CD or the one with no scratch.
  4. Put an oil with the moving parts of it specially the side where the disc is stocked.
  5. If the steps # 1 to 3 are not successful.The problem could be on DVD lens.
  6. If the DVD lens is defective you better to buy a new player.Because the lens is expensive and it is not easy to install on DVD player.
Thank you!!!And hope to help you with all the best that I can...just consult or message me for any clarification or query..
and please don't forget to rate me and have testimonial....Thanks a lot..
Sep 12, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Sony RDR-GX360 won't respond to any buttons on unit or remote. Only function that works is power button. Disk tray won't even open.
Try unplug,replug the unit back like about an hour later for the unit for resetting itself back to factory setting.If getting the same result the unit might have a shorted motor drive for the disc tray.Or shorted control panel on the unit itself.Well,this thing a basic DVD player only wright?If u can tries take it aparts and check out tries to repair it ur self that great.If u tries the shops,not worth it.Trash it.These basic DVD player only are very cheap now.U can get one brand new like $40 dollars.
Aug 11, 2011 | Sony DVP-S360D DVD Player
I have a disc in my apex digital - 600 dvd player and it says not disc and when i open the tray to get the disc it's not there, its stuck in the drive.
unplug and open in up and retrieve the disk. should work again.
Apex is a crappy brand and is thought of as the one year throw away special.
Feb 14, 2011 | Apex Digital 600A DVD Player
This is a replacement player and it will not play some of my best disks I get 'wrong area code'.I live in Australia and bought the player from a reputable store.Thanks John Leigh.
Either the player or the disks are for a different region. The bright people who run the entertainment bussiness decide that it would be a good idea that only players and disks from certain areas of the world should only be used in their particular region. I quess they thought that no one moves or buys things through e-bay.
Try one of these resets
Open the tray.
- On your remote press '0000'.
- Press '0' to make it region free or whichever zone you want to set it to.
- The newly selected region will appear on the top left corner of the screen.
- Close the tray.
Turn on the player.
2. Open the tray.
3. Press the following sequence on the remote:
7 8 9 OK 0
4. The number 0 will appear on the lower left side of your screen.
5. Your player is now region free! Put in a DVD and enjoy! :)
Jan 14, 2011 | Philips DVP3560 DVD Player
My husband always operated the DVD player. He has died and now I'm at a loss what to do. I rented a DVD at the video store. I tried to put it into the tray on the DVD player. I had to pull the tray...
Hi, Very sorry for your loss. As always the first step is to make sure the player is connected to the wall outlet and turned on. To put a disk in the DVD you should push the "Eject" button to open and close the tray it looks like a home(a triangle over a dash) on the front side of the box down left corner of the tray. You have the same button on the remote marked "Eject". Push either once, put the disk with the shiny side down on the tray and push the Eject button again to feed the tray back into the player. Usually the disk starts automatically and you will see a menu on the TV with alternatives like "Play the movie", "Setup", "Scenes",... you may highlight the "Play the movie" alternative, using "Up", "Down", "Left" and "Right" and then press the "OK" button. Or just push the "Play" button either on the box or the remote control. If you click "Here "you can download the manual in PDF form. To open it in your pc you'll need "Adobe Acrobat Reader" (or any other PDF reader) installed.
I will gladly answer your questions Best Regards Bruce
Aug 23, 2010 | Amphion Mediaworks S99 DVD Player
Every time i try to put in a disk, it says its locked
Yes,Some one have set the child lock ON accidently.so it appears as LOCKED
As this child lock is ON you cannot open the tray.
Please follow the below steps to open child lock,
When player is in standby mode press RETURN,ENTER and then ON/STANBY BUTTON again.
You can open it.
If it appears as TRAY LOCKED ,You should contact your sony dealer or authiorised sony service centre.
Thanx
Jul 26, 2010 | Sony DVP-NS315 DVD Player
Pixellated and freezing
hi most of the time a cleaning disk or canned air is not enough but you can tray it, you have to open your dvd player and clean you laser lens whit a cotton swabs and alcohol do not use peroxide. Do it slowly and be careful
bye and good chance.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
DVD Tray will not open
Uhm..
Unplug it/turn it on and off
Try to press the eject button and lightly pry the tray open with your fingers.
Call support.
Good luck
Dec 21, 2007 | Jwin JD-VD130 DVD Player
Televison & Video Logo
1,708 people viewed this question
Top Televison & Video Experts
